RTEMS 6.1
Mips CPU Dependent Header File. More...
| struct | Context_Control |
| Thread register context. More... | |
| struct | Context_Control_fp |
| SPARC basic context. More... | |
| struct | CPU_Interrupt_frame |
| Interrupt stack frame (ISF). More... | |
| #define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
| #define | CPU_ISR_PASSES_FRAME_POINTER TRUE |
| #define | CPU_HARDWARE_FP FALSE |
| #define | CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP |
| #define | CPU_IDLE_TASK_IS_FP FALSE |
| #define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
| #define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
| #define | CPU_STACK_GROWS_UP FALSE |
| #define | CPU_CACHE_LINE_BYTES 16 |
| #define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
| #define | CPU_MODES_INTERRUPT_MASK 0x000000ff |
| #define | CPU_SIZEOF_POINTER 4 |
| #define | CPU_MAXIMUM_PROCESSORS 32 |
| #define | _CPU_Context_Get_SP(_context) (uintptr_t) (_context)->sp |
| #define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
| #define | CPU_STACK_MINIMUM_SIZE (8 * 1024) |
| #define | CPU_ALIGNMENT 8 |
| #define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_STACK_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
| #define | _CPU_ISR_Disable(_level) |
| #define | _CPU_ISR_Enable(_level) |
| #define | _CPU_ISR_Flash(_xlevel) |
| #define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Context_Initialize_fp(_destination) |
| #define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
| #define | CPU_USE_LIBC_INIT_FINI_ARRAY FALSE |
| #define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
| typedef CPU_Interrupt_frame | CPU_Exception_frame |
| typedef uint32_t | CPU_Counter_ticks |
| typedef uintptr_t | CPU_Uint32ptr |
| void | mips_vector_exceptions (CPU_Interrupt_frame *frame) |
| uint32_t | mips_interrupt_mask (void) |
| uint32_t | _CPU_ISR_Get_level (void) |
| void | _CPU_ISR_Set_level (uint32_t) |
| Sets the hardware interrupt level by the level value. | |
| void | _CPU_Context_Initialize (Context_Control *the_context, uintptr_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
| void | mips_break (int error) |
| void | _CPU_Initialize (void) |
| CPU initialization. | |
| RTEMS_NO_RETURN void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context. | |
| RTEMS_NO_RETURN void | _CPU_Context_restore (Context_Control *new_context) |
| void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
| void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| uint32_t | _CPU_Counter_frequency (void) |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| Context_Control_fp | _CPU_Null_fp_context |
