RTEMS 6.1
mips.h
2
16/*
17 * COPYRIGHT (c) 1989-2001.
18 * On-Line Applications Research Corporation (OAR).
19 *
20 * Redistribution and use in source and binary forms, with or without
21 * modification, are permitted provided that the following conditions
22 * are met:
23 * 1. Redistributions of source code must retain the above copyright
24 * notice, this list of conditions and the following disclaimer.
25 * 2. Redistributions in binary form must reproduce the above copyright
26 * notice, this list of conditions and the following disclaimer in the
27 * documentation and/or other materials provided with the distribution.
28 *
29 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
30 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
31 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
32 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
33 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
34 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
35 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
36 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
37 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
38 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
39 * POSSIBILITY OF SUCH DAMAGE.
40 */
41
42#ifndef _RTEMS_SCORE_MIPS_H
43#define _RTEMS_SCORE_MIPS_H
44
53#ifdef __cplusplus
54extern "C" {
55#endif
56
57#ifndef ASM
58#include <rtems/mips/idtcpu.h>
59#endif
60
61/*
62 * SR bits that enable/disable interrupts
63 *
64 * NOTE: XXX what about SR_ERL?
65 */
66
67#if (__mips == 3) || (__mips == 32)
68#ifdef ASM
69#define SR_INTERRUPT_ENABLE_BITS 0x01
70#else
71#define SR_INTERRUPT_ENABLE_BITS SR_IE
72#endif
73
74#elif __mips == 1
75#define SR_INTERRUPT_ENABLE_BITS SR_IEC
76
77#else
78#error "mips interrupt enable bits: unknown architecture level!"
79#endif
80
81/*
82 * This file contains the information required to build
83 * RTEMS for a particular member of the "no cpu"
84 * family when executing in protected mode. It does
85 * this by setting variables to indicate which implementation
86 * dependent features are present in a particular member
87 * of the family.
88 */
89
90#if defined(__mips_soft_float)
91#define MIPS_HAS_FPU 0
92#else
93#define MIPS_HAS_FPU 1
94#endif
95
96
97#if (__mips == 1)
98#define CPU_MODEL_NAME "ISA Level 1 or 2"
99#elif (__mips == 3) || (__mips == 32)
100#if defined(__mips64)
101#define CPU_MODEL_NAME "ISA Level 4"
102#else
103#define CPU_MODEL_NAME "ISA Level 3"
104#endif
105#else
106#error "Unknown MIPS ISA level"
107#endif
108
109/*
110 * Define the name of the CPU family.
111 */
112
113#define CPU_NAME "MIPS"
114
115/*
116 * RTEMS Vector numbers for exception conditions. This is a direct
117 * map to the causes.
118 */
119
120#define MIPS_EXCEPTION_BASE 0
121
122#define MIPS_EXCEPTION_INT MIPS_EXCEPTION_BASE+0
123#define MIPS_EXCEPTION_MOD MIPS_EXCEPTION_BASE+1
124#define MIPS_EXCEPTION_TLBL MIPS_EXCEPTION_BASE+2
125#define MIPS_EXCEPTION_TLBS MIPS_EXCEPTION_BASE+3
126#define MIPS_EXCEPTION_ADEL MIPS_EXCEPTION_BASE+4
127#define MIPS_EXCEPTION_ADES MIPS_EXCEPTION_BASE+5
128#define MIPS_EXCEPTION_IBE MIPS_EXCEPTION_BASE+6
129#define MIPS_EXCEPTION_DBE MIPS_EXCEPTION_BASE+7
130#define MIPS_EXCEPTION_SYSCALL MIPS_EXCEPTION_BASE+8
131#define MIPS_EXCEPTION_BREAK MIPS_EXCEPTION_BASE+9
132#define MIPS_EXCEPTION_RI MIPS_EXCEPTION_BASE+10
133#define MIPS_EXCEPTION_CPU MIPS_EXCEPTION_BASE+11
134#define MIPS_EXCEPTION_OVERFLOW MIPS_EXCEPTION_BASE+12
135#define MIPS_EXCEPTION_TRAP MIPS_EXCEPTION_BASE+13
136#define MIPS_EXCEPTION_VCEI MIPS_EXCEPTION_BASE+14
137/* FPE only on mips2 and higher */
138#define MIPS_EXCEPTION_FPE MIPS_EXCEPTION_BASE+15
139#define MIPS_EXCEPTION_C2E MIPS_EXCEPTION_BASE+16
140/* 17-22 reserved */
141#define MIPS_EXCEPTION_WATCH MIPS_EXCEPTION_BASE+23
142/* 24-30 reserved */
143#define MIPS_EXCEPTION_VCED MIPS_EXCEPTION_BASE+31
144
145#define MIPS_INTERRUPT_BASE MIPS_EXCEPTION_BASE+32
146
147/*
148 * Some macros to access registers
149 */
150
151#define mips_get_sr( _x ) \
152 do { \
153 __asm__ volatile( "mfc0 %0, $12; nop" : "=r" (_x) : ); \
154 } while (0)
155
156#define mips_set_sr( _x ) \
157 do { \
158 unsigned int __x = (_x); \
159 __asm__ volatile( "mtc0 %0, $12; nop" : : "r" (__x) ); \
160 } while (0)
161
162
163/*
164 * Access the Cause register
165 */
166
167#define mips_get_cause( _x ) \
168 do { \
169 __asm__ volatile( "mfc0 %0, $13; nop" : "=r" (_x) : ); \
170 } while (0)
171
172
173#define mips_set_cause( _x ) \
174 do { \
175 unsigned int __x = (_x); \
176 __asm__ volatile( "mtc0 %0, $13; nop" : : "r" (__x) ); \
177 } while (0)
178
179
180
181
182/*
183 * Access the Debug Cache Invalidate Control register
184 */
185
186#define mips_get_dcic( _x ) \
187 do { \
188 __asm__ volatile( "mfc0 %0, $7; nop" : "=r" (_x) : ); \
189 } while (0)
190
191
192#define mips_set_dcic( _x ) \
193 do { \
194 unsigned int __x = (_x); \
195 __asm__ volatile( "mtc0 %0, $7; nop" : : "r" (__x) ); \
196 } while (0)
197
198
199
200
201/*
202 * Access the Breakpoint Program Counter & Mask registers
203 * (_x for BPC, _y for mask)
204 */
205
206#define mips_get_bpcrm( _x, _y ) \
207 do { \
208 __asm__ volatile( "mfc0 %0, $3; nop" : "=r" (_x) : ); \
209 __asm__ volatile( "mfc0 %0, $11; nop" : "=r" (_y) : ); \
210 } while (0)
211
212
213#define mips_set_bpcrm( _x, _y ) \
214 do { \
215 unsigned int __x = (_x); \
216 unsigned int __y = (_y); \
217 __asm__ volatile( "mtc0 %0, $11; nop" : : "r" (__y) ); \
218 __asm__ volatile( "mtc0 %0, $3; nop" : : "r" (__x) ); \
219 } while (0)
220
221
222
223
224
225
226/*
227 * Access the Breakpoint Data Address & Mask registers
228 * (_x for BDA, _y for mask)
229 */
230
231#define mips_get_bdarm( _x, _y ) \
232 do { \
233 __asm__ volatile( "mfc0 %0, $5; nop" : "=r" (_x) : ); \
234 __asm__ volatile( "mfc0 %0, $9; nop" : "=r" (_y) : ); \
235 } while (0)
236
237
238#define mips_set_bdarm( _x, _y ) \
239 do { \
240 unsigned int __x = (_x); \
241 unsigned int __y = (_y); \
242 __asm__ volatile( "mtc0 %0, $9; nop" : : "r" (__y) ); \
243 __asm__ volatile( "mtc0 %0, $5; nop" : : "r" (__x) ); \
244 } while (0)
245
246
247
248
249
250
251
252/*
253 * Access FCR31
254 */
255
256#if ( MIPS_HAS_FPU == 1 )
257
258#define mips_get_fcr31( _x ) \
259 do { \
260 __asm__ volatile( "cfc1 %0, $31; nop" : "=r" (_x) : ); \
261 } while(0)
262
263
264#define mips_set_fcr31( _x ) \
265 do { \
266 unsigned int __x = (_x); \
267 __asm__ volatile( "ctc1 %0, $31; nop" : : "r" (__x) ); \
268 } while(0)
269
270#else
271
272#define mips_get_fcr31( _x )
273#define mips_set_fcr31( _x )
274
275#endif
276
277/*
278 * Manipulate interrupt mask
279 *
280 * mips_unmask_interrupt( _mask)
281 * enables interrupts - mask is positioned so it only needs to be or'ed
282 * into the status reg. This also does some other things !!!! Caution
283 * should be used if invoking this while in the middle of a debugging
284 * session where the client may have nested interrupts.
285 *
286 * mips_mask_interrupt( _mask )
287 * disable the interrupt - mask is the complement of the bits to be
288 * cleared - i.e. to clear ext int 5 the mask would be - 0xffff7fff
289 *
290 *
291 * NOTE: mips_mask_interrupt() used to be disable_int().
292 * mips_unmask_interrupt() used to be enable_int().
293 *
294 */
295
296#define mips_enable_in_interrupt_mask( _mask ) \
297 do { \
298 unsigned int _sr; \
299 mips_get_sr( _sr ); \
300 _sr |= (_mask); \
301 mips_set_sr( _sr ); \
302 } while (0)
303
304#define mips_disable_in_interrupt_mask( _mask ) \
305 do { \
306 unsigned int _sr; \
307 mips_get_sr( _sr ); \
308 _sr &= ~(_mask); \
309 mips_set_sr( _sr ); \
310 } while (0)
311
312#ifdef __cplusplus
313}
314#endif
315
317#endif /* _RTEMS_SCORE_MIPS_H */
318/* end of include file */
CPU Related Definitions.
