RTEMS 6.1
MicroBlaze AXI GPIO implementation. More...
#include <assert.h>#include <bsp/fatal.h>#include <bsp/fdt.h>#include <bsp/microblaze-gpio.h>#include <libfdt.h>Functions | |
| void | microblaze_gpio_set_data_direction (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask) |
| Set pin configuration for the specified GPIO channel. | |
| uint32_t | microblaze_gpio_get_data_direction (Microblaze_GPIO_context *ctx, uint32_t channel) |
| Get pin configuration for specified GPIO channel. | |
| uint32_t | microblaze_gpio_discrete_read (Microblaze_GPIO_context *ctx, uint32_t channel) |
| Reads data for specified GPIO channel. | |
| void | microblaze_gpio_discrete_write (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask) |
| Writes to data register for specified GPIO channel. | |
| void | microblaze_gpio_discrete_set (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask) |
| Set bits to 1 on specified GPIO channel. | |
| void | microblaze_gpio_discrete_clear (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask) |
| Set bits to 0 on specified GPIO channel. | |
| rtems_vector_number | microblaze_gpio_get_irq (Microblaze_GPIO_context *ctx) |
| Returns the vector number of the interrupt handler. | |
| void | microblaze_gpio_interrupt_global_enable (Microblaze_GPIO_context *ctx) |
| Turns on interrupts globally. | |
| void | microblaze_gpio_interrupt_global_disable (Microblaze_GPIO_context *ctx) |
| Turns off interrupts globally. | |
| void | microblaze_gpio_interrupt_enable (Microblaze_GPIO_context *ctx, uint32_t channel) |
| Enables interrupts on specified channel. | |
| void | microblaze_gpio_interrupt_disable (Microblaze_GPIO_context *ctx, uint32_t channel) |
| Disables interrupts on specified channel. | |
| void | microblaze_gpio_interrupt_clear (Microblaze_GPIO_context *ctx, uint32_t channel) |
| Clear status of interrupt signals on a specific channel. | |
| uint32_t | microblaze_gpio_interrupt_get_enabled (Microblaze_GPIO_context *ctx) |
| Return a bitmask of the interrupts that are enabled. | |
| uint32_t | microblaze_gpio_interrupt_get_status (Microblaze_GPIO_context *ctx) |
| Return a bitmask of the status of the interrupt signals. | |
| void microblaze_gpio_discrete_clear | ( | Microblaze_GPIO_context * | ctx, |
| uint32_t | channel, | ||
| uint32_t | mask | ||
| [in] | ctx | the GPIO context |
| [in] | channel | the GPIO channel |
| [in] | mask | the mask to be applied to @ channel |
| None |
| uint32_t microblaze_gpio_discrete_read | ( | Microblaze_GPIO_context * | ctx, |
| uint32_t | channel | ||
| Current | values in discretes register. |
| void microblaze_gpio_discrete_set | ( | Microblaze_GPIO_context * | ctx, |
| None |
| void microblaze_gpio_discrete_write | ( | Microblaze_GPIO_context * | ctx, |
| None |
| uint32_t microblaze_gpio_get_data_direction | ( | Microblaze_GPIO_context * | ctx, |
Gets the current pin configuration for a specified GPIO channel. Bits set to 0 are output, and bits set to 1 are input.
| bitmask | specifiying which pins on a channel are input or output |
| rtems_vector_number microblaze_gpio_get_irq | ( | Microblaze_GPIO_context * | ctx | ) |
| the | vector number |
| void microblaze_gpio_interrupt_clear | ( | Microblaze_GPIO_context * | ctx, |
| [in] | channel | the channel to clear the interrupt pending status from |
| None |
| void microblaze_gpio_interrupt_disable | ( | Microblaze_GPIO_context * | ctx, |
| [in] | channel | the channel to turn interrupts on for |
| None |
| void microblaze_gpio_interrupt_enable | ( | Microblaze_GPIO_context * | ctx, |
| [in] | channel | the channel to enable interrupts on |
| None |
| uint32_t microblaze_gpio_interrupt_get_enabled | ( | Microblaze_GPIO_context * | ctx | ) |
| the | bitmask of enabled interrupts |
| uint32_t microblaze_gpio_interrupt_get_status | ( | Microblaze_GPIO_context * | ctx | ) |
| bitmask | containing statuses of interrupt signals |
| void microblaze_gpio_interrupt_global_disable | ( | Microblaze_GPIO_context * | ctx | ) |
| None |
| void microblaze_gpio_interrupt_global_enable | ( | Microblaze_GPIO_context * | ctx | ) |
| None |
| void microblaze_gpio_set_data_direction | ( | Microblaze_GPIO_context * | ctx, |
Changes the pin configuration for a channel. Bits set to 0 are output, and bits set to 1 are input.
| None |
