#define | M302_BAR (*((volatile uint16_t *) 0xf2)) |
#define | M302_SCR (*((volatile uint32_t *) 0xf4)) |
#define | RBIT_SCR_IPA 0x08000000 |
#define | RBIT_SCR_HWT 0x04000000 |
#define | RBIT_SCR_WPV 0x02000000 |
#define | RBIT_SCR_ADC 0x01000000 |
#define | RBIT_SCR_ERRE 0x00400000 |
#define | RBIT_SCR_VGE 0x00200000 |
#define | RBIT_SCR_WPVE 0x00100000 |
#define | RBIT_SCR_RMCST 0x00080000 |
#define | RBIT_SCR_EMWS 0x00040000 |
#define | RBIT_SCR_ADCE 0x00020000 |
#define | RBIT_SCR_BCLM 0x00010000 |
#define | RBIT_SCR_FRZW 0x00008000 |
#define | RBIT_SCR_FRZ2 0x00004000 |
#define | RBIT_SCR_FRZ1 0x00002000 |
#define | RBIT_SCR_SAM 0x00001000 |
#define | RBIT_SCR_HWDEN 0x00000800 |
#define | RBIT_SCR_HWDCN2 0x00000400 |
#define | RBIT_SCR_HWDCN1 0x00000200 /* 512 clocks */ |
#define | RBIT_SCR_HWDCN0 0x00000100 /* 128 clocks */ |
#define | RBIT_SCR_LPREC 0x00000080 |
#define | RBIT_SCR_LPP16 0x00000040 |
#define | RBIT_SCR_LPEN 0x00000020 |
#define | RBIT_SCR_LPCLKDIV 0x0000001f |
#define | M68K_IVEC_BUS_ERROR 2 |
#define | M68K_IVEC_ADDRESS_ERROR 3 |
#define | M68K_IVEC_ILLEGAL_OPCODE 4 |
#define | M68K_IVEC_ZERO_DIVIDE 5 |
#define | M68K_IVEC_CHK 6 |
#define | M68K_IVEC_TRAPV 7 |
#define | M68K_IVEC_PRIVILEGE 8 |
#define | M68K_IVEC_TRACE 9 |
#define | M68K_IVEC_LINE_A 10 |
#define | M68K_IVEC_LINE_F 11 |
#define | M68K_IVEC_UNINITIALIZED_INT 15 |
#define | M68K_IVEC_SPURIOUS_INT 24 |
#define | M68K_IVEC_LEVEL1_AUTOVECTOR 25 |
#define | M68K_IVEC_LEVEL2_AUTOVECTOR 26 |
#define | M68K_IVEC_LEVEL3_AUTOVECTOR 27 |
#define | M68K_IVEC_LEVEL4_AUTOVECTOR 28 |
#define | M68K_IVEC_LEVEL5_AUTOVECTOR 29 |
#define | M68K_IVEC_LEVEL6_AUTOVECTOR 30 |
#define | M68K_IVEC_LEVEL7_AUTOVECTOR 31 |
#define | M68K_IVEC_TRAP0 32 |
#define | M68K_IVEC_TRAP1 33 |
#define | M68K_IVEC_TRAP2 34 |
#define | M68K_IVEC_TRAP3 35 |
#define | M68K_IVEC_TRAP4 36 |
#define | M68K_IVEC_TRAP5 37 |
#define | M68K_IVEC_TRAP6 38 |
#define | M68K_IVEC_TRAP7 39 |
#define | M68K_IVEC_TRAP8 40 |
#define | M68K_IVEC_TRAP9 41 |
#define | M68K_IVEC_TRAP10 42 |
#define | M68K_IVEC_TRAP11 43 |
#define | M68K_IVEC_TRAP12 44 |
#define | M68K_IVEC_TRAP13 45 |
#define | M68K_IVEC_TRAP14 46 |
#define | M68K_IVEC_TRAP15 47 |
#define | RBIT_GIMR_MOD (1<<15) |
#define | RBIT_GIMR_IV7 (1<<14) |
#define | RBIT_GIMR_IV6 (1<<13) |
#define | RBIT_GIMR_IV1 (1<<12) |
#define | RBIT_GIMR_ET7 (1<<10) |
#define | RBIT_GIMR_ET6 (1<<9) |
#define | RBIT_GIMR_ET1 (1<<8) |
#define | RBIT_GIMR_VECTOR (7<<5) |
#define | RBIT_IPR_PB11 (1<<15) |
#define | RBIT_IPR_PB10 (1<<14) |
#define | RBIT_IPR_SCC1 (1<<13) |
#define | RBIT_IPR_SDMA (1<<12) |
#define | RBIT_IPR_IDMA (1<<11) |
#define | RBIT_IPR_SCC2 (1<<10) |
#define | RBIT_IPR_TIMER1 (1<<9) |
#define | RBIT_IPR_SCC3 (1<<8) |
#define | RBIT_IPR_PB9 (1<<7) |
#define | RBIT_IPR_TIMER2 (1<<6) |
#define | RBIT_IPR_SCP (1<<5) |
#define | RBIT_IPR_TIMER3 (1<<4) |
#define | RBIT_IPR_SMC1 (1<<3) |
#define | RBIT_IPR_SMC2 (1<<2) |
#define | RBIT_IPR_PB8 (1<<1) |
#define | RBIT_IPR_ERR (1<<0) |
#define | RBIT_ISR_PB11 (1<<15) |
#define | RBIT_ISR_PB10 (1<<14) |
#define | RBIT_ISR_SCC1 (1<<13) |
#define | RBIT_ISR_SDMA (1<<12) |
#define | RBIT_ISR_IDMA (1<<11) |
#define | RBIT_ISR_SCC2 (1<<10) |
#define | RBIT_ISR_TIMER1 (1<<9) |
#define | RBIT_ISR_SCC3 (1<<8) |
#define | RBIT_ISR_PB9 (1<<7) |
#define | RBIT_ISR_TIMER2 (1<<6) |
#define | RBIT_ISR_SCP (1<<5) |
#define | RBIT_ISR_TIMER3 (1<<4) |
#define | RBIT_ISR_SMC1 (1<<3) |
#define | RBIT_ISR_SMC2 (1<<2) |
#define | RBIT_ISR_PB8 (1<<1) |
#define | RBIT_IMR_PB11 (1<<15) /* PB11 Interrupt Mask */ |
#define | RBIT_IMR_PB10 (1<<14) /* PB10 Interrupt Mask */ |
#define | RBIT_IMR_SCC1 (1<<13) /* SCC1 Interrupt Mask */ |
#define | RBIT_IMR_SDMA (1<<12) /* SDMA Interrupt Mask */ |
#define | RBIT_IMR_IDMA (1<<11) /* IDMA Interrupt Mask */ |
#define | RBIT_IMR_SCC2 (1<<10) /* SCC2 Interrupt Mask */ |
#define | RBIT_IMR_TIMER1 (1<<9) /* TIMER1 Interrupt Mask */ |
#define | RBIT_IMR_SCC3 (1<<8) /* SCC3 Interrupt Mask */ |
#define | RBIT_IMR_PB9 (1<<7) /* PB9 Interrupt Mask */ |
#define | RBIT_IMR_TIMER2 (1<<6) /* TIMER2 Interrupt Mask */ |
#define | RBIT_IMR_SCP (1<<5) /* SCP Interrupt Mask */ |
#define | RBIT_IMR_TIMER3 (1<<4) /* TIMER3 Interrupt Mask */ |
#define | RBIT_IMR_SMC1 (1<<3) /* SMC1 Interrupt Mask */ |
#define | RBIT_IMR_SMC2 (1<<2) /* SMC2 Interrupt Mask */ |
#define | RBIT_IMR_PB8 (1<<1) /* PB8 Interrupt Mask */ |
#define | RBIT_TMR_ICLK_STOP (0<<1) |
#define | RBIT_TMR_ICLK_MASTER (1<<1) |
#define | RBIT_TMR_ICLK_MASTER16 (2<<1) |
#define | RBIT_TMR_ICLK_TIN (3<<1) |
#define | RBIT_TMR_OM (1<<5) |
#define | RBIT_TMR_ORI (1<<4) |
#define | RBIT_TMR_FRR (1<<3) |
#define | RBIT_TMR_RST (1<<0) |
#define | RBIT_TER_REF (1<<1) /* Output Reference Event */ |
#define | RBIT_TER_CAP (1<<0) /* Capture Event */ |
#define | RCV_ERR 0x003F |
#define | RBIT_UART_CTRL (1<<11) /* buffer contains a control char */ |
#define | RBIT_UART_ADDR (1<<10) /* first byte contains an address */ |
#define | RBIT_UART_MATCH (1<<9) /* indicates which addr char matched */ |
#define | RBIT_UART_IDLE (1<<8) /* buffer closed due to IDLE sequence */ |
#define | RBIT_UART_BR (1<<5) /* break sequence was received */ |
#define | RBIT_UART_FR (1<<4) /* framing error was received */ |
#define | RBIT_UART_PR (1<<3) /* parity error was received */ |
#define | RBIT_UART_OV (1<<1) /* receiver overrun occurred */ |
#define | RBIT_UART_CD (1<<0) /* carrier detect lost */ |
#define | RBIT_UART_STATUS 0x003B /* all status bits */ |
| #define | RBIT_UART_CR |
| #define | RBIT_UART_A |
#define | RBIT_UART_PREAMBLE (1<<9) /* send preamble before data */ |
#define | RBIT_UART_CTS_LOST (1<<0) /* CTS lost */ |
#define | M302_UART_EV_CTS (1<<7) /* CTS status changed */ |
#define | M302_UART_EV_CD (1<<6) /* carrier detect status changed */ |
#define | M302_UART_EV_IDL (1<<5) /* IDLE sequence status changed */ |
#define | M302_UART_EV_BRK (1<<4) /* break character was received */ |
#define | M302_UART_EV_CCR (1<<3) /* control character received */ |
#define | M302_UART_EV_TX (1<<1) /* buffer has been transmitted */ |
#define | M302_UART_EV_RX (1<<0) /* buffer has been received */ |
#define | RBIT_HDLC_EMPTY_BIT 0x8000 /* buffer associated with BD is empty */ |
#define | RBIT_HDLC_LAST_BIT 0x0800 /* buffer is last in a frame */ |
#define | RBIT_HDLC_FIRST_BIT 0x0400 /* buffer is first in a frame */ |
#define | RBIT_HDLC_FRAME_LEN 0x0020 /* receiver frame length violation */ |
#define | RBIT_HDLC_NONOCT_Rx 0x0010 /* received non-octet aligned frame */ |
#define | RBIT_HDLC_ABORT_SEQ 0x0008 /* received abort sequence */ |
#define | RBIT_HDLC_CRC_ERROR 0x0004 /* frame contains a CRC error */ |
#define | RBIT_HDLC_OVERRUN 0x0002 /* receiver overrun occurred */ |
#define | RBIT_HDLC_CD_LOST 0x0001 /* carrier detect lost */ |
#define | RBIT_HDLC_READY_BIT 0x8000 /* buffer is ready to transmit */ |
#define | RBIT_HDLC_EXT_BUFFER 0x4000 /* buffer is in external memory */ |
#define | RBIT_HDLC_WRAP_BIT 0x2000 /* last buffer in bd table, so wrap */ |
#define | RBIT_HDLC_WAKE_UP 0x1000 /* interrupt when buffer serviced */ |
#define | RBIT_HDLC_LAST_BIT 0x0800 /* buffer is last in the frame */ |
#define | RBIT_HDLC_TxCRC_BIT 0x0400 /* transmit a CRC sequence */ |
#define | RBIT_HDLC_UNDERRUN 0x0002 /* transmitter underrun */ |
#define | RBIT_HDLC_CTS_LOST 0x0001 /* CTS lost */ |
#define | RBIT_HDLC_CTS 0x80 /* CTS status changed */ |
#define | RBIT_HDLC_CD 0x40 /* carrier detect status changed */ |
#define | RBIT_HDLC_IDL 0x20 /* IDLE sequence status changed */ |
#define | RBIT_HDLC_TXE 0x10 /* transmit error */ |
#define | RBIT_HDLC_RXF 0x08 /* received frame */ |
| #define | RBIT_HDLC_BSY |
#define | RBIT_HDLC_TXB 0x02 /* buffer has been transmitted */ |
#define | RBIT_HDLC_RXB 0x01 /* received buffer */ |
| #define | RBIT_SCON_WOMS |
#define | RBIT_SCON_EXTC (1<<14) /* External Clock Source */ |
#define | RBIT_SCON_TCS (1<<13) /* Transmit Clock Source */ |
#define | RBIT_SCON_RCS (1<<12) /* Receive Clock Source */ |
#define | RBIT_SCM_ENR (1<<3) /* Enable receiver */ |
#define | RBIT_SCM_ENT (1<<2) /* Enable transmitter */ |
#define | BR_ENABLED 1 |
#define | BR_DISABLED 0 |
#define | BR_FC_NULL 0 |
#define | BR_READ_ONLY 0 |
#define | BR_READ_WRITE 2 |
#define | OR_DTACK_0 0x0000 |
#define | OR_DTACK_1 0x2000 |
#define | OR_DTACK_2 0x4000 |
#define | OR_DTACK_3 0x6000 |
#define | OR_DTACK_4 0x8000 |
#define | OR_DTACK_5 0xA000 |
#define | OR_DTACK_6 0xC000 |
#define | OR_DTACK_EXT 0xE000 |
#define | OR_SIZE_64K 0x1FE0 |
#define | OR_SIZE_128K 0x1FC0 |
#define | OR_SIZE_256K 0x1F80 |
#define | OR_SIZE_512K 0x1F00 |
#define | OR_SIZE_1M 0x1E00 |
#define | OR_SIZE_2M 0x1C00 |
#define | OR_MASK_RW 0x0000 |
#define | OR_NO_MASK_RW 0x0002 |
#define | OR_MASK_FC 0x0000 |
#define | OR_NO_MASK_FC 0x0001 |
#define | MAKE_BR(base_address, enable, rw, fc) ((base_address >> 11) | fc | rw | enable) |
#define | MAKE_OR(bsize, DtAck, RW_Mask, FC_Mask) (DtAck | ((~(bsize - 1) & 0x00FFFFFF) >> 11) | FC_Mask | RW_Mask) |
#define | __REG_CAT(r, n) r ## n |
#define | WRITE_BR(csel, base_address, enable, rw, fc) __REG_CAT(m302.reg.br, csel) = MAKE_BR(base_address, enable, rw, fc) |
#define | WRITE_OR(csel, bsize, DtAck, RW_Mask, FC_Mask) __REG_CAT(m302.reg.or, csel) = MAKE_OR(bsize, DtAck, RW_Mask, FC_Mask) |
#define | WATCHDOG_ENABLE (1) |
#define | WATCHDOG_TRIGGER() (m302.reg.wrr = 0x10 | WATCHDOG_ENABLE, m302.reg.wcn = 0) |
#define | WATCHDOG_TOGGLE() (m302.reg.wcn = WATCHDOG_TIMEOUT_PERIOD) |
#define | DISABLE_WATCHDOG() (m302.reg.wrr = 0) |
Definitions for Motorola MC68302 Processor.
Section references in this file refer to revision 2 of Motorola's "MC68302 Integrated Multiprotocol Processor User's Manual". (Motorola document MC68302UM/AD REV 2.)
Based on Don Meyer's cpu68302.h that was posted in comp.sys.m68k on 17 February, 1993.
