RTEMS 6.1
lpc-gpio.h File Reference
API of the GPIO driver for the lpc176x bsp in RTEMS. More...
#include <bsp/lpc176x.h>
#include <bsp/gpio-defs.h>
rtems_status_code lpc176x_gpio_config (lpc176x_pin_number pin, lpc176x_gpio_direction dir)
 Configures the pin as input or output GPIO.
rtems_status_code lpc176x_gpio_config_input_with_interrupt (lpc176x_pin_number pin, lpc176x_gpio_interrupt edge, lpc176x_gpio_interrupt_function isrfunct)
 Configures the pin as input, enables interrupt for an edge/s and sets isrfunct as the function to call when that interrupt occurs.
rtems_status_code lpc176x_gpio_set_pin (lpc176x_pin_number pin)
 Sets the output pin to 1.
rtems_status_code lpc176x_gpio_clear_pin (lpc176x_pin_number pin)
 Sets the output pin to 0.
rtems_status_code lpc176x_gpio_write_pin (lpc176x_pin_number pin, bool value)
 Sets the output pin to 0 or 1 according to value.
rtems_status_code lpc176x_gpio_get_pin_value (lpc176x_pin_number pin, bool *pin_value)
 Returns the value at the given input pin.
◆ lpc176x_gpio_clear_pin()
rtems_status_code lpc176x_gpio_clear_pin ( lpc176x_pin_number  pin)
Parameters
pinThe pin to set
◆ lpc176x_gpio_config()
rtems_status_code lpc176x_gpio_config ( lpc176x_pin_number  pin,
Parameters
pinThe pin to configure
dirInput or output.
◆ lpc176x_gpio_config_input_with_interrupt()
rtems_status_code lpc176x_gpio_config_input_with_interrupt ( lpc176x_pin_number  pin,
Parameters
pinThe pin to configure.
edgeWhich edge or edges will activate the interrupt.
isrfunctThe function that is called when the interrupt occurs.
Returns
RTEMS_SUCCESSFULL if the configurations was success.
◆ lpc176x_gpio_get_pin_value()
rtems_status_code lpc176x_gpio_get_pin_value ( lpc176x_pin_number  pin,
bool *  pin_value
inline
Parameters
pinThe pin where to read the value.
pin_valueTRUE if the pin value was getted successfuly.
Returns
RTEMS_SUCCESSFUL if the pin value was getted successfuly.
◆ lpc176x_gpio_set_pin()
rtems_status_code lpc176x_gpio_set_pin ( lpc176x_pin_number  pin)
Parameters
pinThe pin to set
◆ lpc176x_gpio_write_pin()
rtems_status_code lpc176x_gpio_write_pin ( lpc176x_pin_number  pin,
bool  value
Parameters
pinThe pin to set
valuethe value to set.
