RTEMS 6.1
libpci.h
2
12/*
13 * Copyright (C) 2011 Cobham Gaisler AB
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_CONFDEFS_LIBPCI_H
38#define _RTEMS_CONFDEFS_LIBPCI_H
39
40#ifndef __CONFIGURATION_TEMPLATE_h
41#error "Do not include this file directly, use <rtems/confdefs.h> instead"
42#endif
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
48/*
49 * Select PCI Configuration Library
50 */
51#ifdef RTEMS_PCI_CONFIG_LIB
52 #ifdef CONFIGURE_INIT
53 #define PCI_LIB_NONE 0
54 #define PCI_LIB_AUTO 1
55 #define PCI_LIB_STATIC 2
56 #define PCI_LIB_READ 3
57 #define PCI_LIB_PERIPHERAL 4
58 #if CONFIGURE_PCI_LIB == PCI_LIB_AUTO
59 #define PCI_CFG_AUTO_LIB
60 #include <pci/cfg.h>
61 struct pci_bus pci_hb;
62 #define PCI_LIB_INIT pci_config_auto
63 #define PCI_LIB_CONFIG pci_config_auto_register
64 #elif CONFIGURE_PCI_LIB == PCI_LIB_STATIC
65 #define PCI_CFG_STATIC_LIB
66 #include <pci/cfg.h>
67 #define PCI_LIB_INIT pci_config_static
68 #define PCI_LIB_CONFIG NULL
69 /* Let user define PCI configuration (struct pci_bus pci_hb) */
70 #elif CONFIGURE_PCI_LIB == PCI_LIB_READ
71 #define PCI_CFG_READ_LIB
72 #include <pci/cfg.h>
73 #define PCI_LIB_INIT pci_config_read
74 #define PCI_LIB_CONFIG NULL
75 struct pci_bus pci_hb;
76 #elif CONFIGURE_PCI_LIB == PCI_LIB_PERIPHERAL
77 #define PCI_LIB_INIT pci_config_peripheral
78 #define PCI_LIB_CONFIG NULL
79 /* Let user define PCI configuration (struct pci_bus pci_hb) */
80 #elif CONFIGURE_PCI_LIB == PCI_LIB_NONE
81 #define PCI_LIB_INIT NULL
82 #define PCI_LIB_CONFIG NULL
83 /* No PCI Configuration at all, user can use/debug access routines */
84 #else
85 #error NO PCI LIBRARY DEFINED
86 #endif
87
88 const int pci_config_lib_type = CONFIGURE_PCI_LIB;
89 int (*pci_config_lib_init)(void) = PCI_LIB_INIT;
90 void (*pci_config_lib_register)(void *config) = PCI_LIB_CONFIG;
91 #endif
92#endif
93
94#ifdef __cplusplus
95}
96#endif /* __cplusplus */
97
98#endif /* _RTEMS_CONFDEFS_LIBPCI_H */
PCI Configuration Library.
Definition: deflate.c:114
Definition: pci.h:75
