RTEMS 6.1
XilinxZynqMP QSPI JFFS2 flash driver definitions. More...
#include <dev/spi/xqspipsu.h>Go to the source code of this file.
| int | xilinx_zynqmp_nor_jffs2_initialize (const char *mount_dir, XQspiPsu *qspipsu_ptr) |
| Mount jffs2 filesystem. | |
| int xilinx_zynqmp_nor_jffs2_initialize | ( | const char * | mount_dir, |
| XQspiPsu * | qspipsu_ptr | ||
| [in] | mount_dir | The directory to mount the filesystem at. |
| [in] | qspipsu_ptr | A pointer to an initialized QSPI instance. |
| 0 | Successful operation. Negative number otherwise. |
