RTEMS 6.1
crc.h
2
12/*
13 * Copyright (C) 2024 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_CRC_H
38#define _RTEMS_CRC_H
39
40#include <stddef.h>
41#include <stdint.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
62#define CRC24Q_SEED 0U
63
68#define CRC24Q_MASK 0xffffffU
69
80uint32_t _CRC24Q_Update( uint32_t crc, uint8_t byte );
81
95 uint32_t crc,
96 const void *bytes,
97 size_t size_in_bytes
98);
99
102#ifdef __cplusplus
103}
104#endif /* __cplusplus */
105
106#endif /* _RTEMS_CRC_H */
uint32_t _CRC24Q_Sequence_update(uint32_t crc, const void *bytes, size_t size_in_bytes)
Updates the CRC-24Q state using a sequence of bytes.
Definition: crc24q.c:138
uint32_t _CRC24Q_Update(uint32_t crc, uint8_t byte)
Updates the CRC-24Q state using a byte.
Definition: crc24q.c:134
