This group contains functions to calculate Cyclic Redundancy Check (CRC) values.
More...
#define | CRC24Q_SEED 0U |
| | This constant represents the default CRC-24Q seed state.
#define | CRC24Q_MASK 0xffffffU |
| | This constant provides a mask to get a valid CRC-24Q value from the integers returned by _CRC24Q_Update() and _CRC24Q_Sequence_update().
| uint32_t | _CRC24Q_Update (uint32_t crc, uint8_t byte) |
| | Updates the CRC-24Q state using a byte.
| uint32_t | _CRC24Q_Sequence_update (uint32_t crc, const void *bytes, size_t size_in_bytes) |
| | Updates the CRC-24Q state using a sequence of bytes.
◆ _CRC24Q_Sequence_update()
| uint32_t _CRC24Q_Sequence_update |
uint32_t |
crc, |
const void * |
bytes, |
size_t |
size_in_bytes |
- Parameters
| crc | is the input CRC-24Q state. |
| bytes[in] | is the sequence of bytes updating the input CRC-24Q state. |
| size_in_bytes | is the size in bytes of the byte sequence. |
- Returns
- Returns the updated CRC-24Q state. Use the CRC24Q_MASK to get a valid CRC-24Q value.
◆ _CRC24Q_Update()
| uint32_t _CRC24Q_Update |
uint32_t |
crc, |
uint8_t |
byte |
- Parameters
| byte | is the byte updating the input CRC-24Q state. |
- Returns
