RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Enumerator | Functions | Variables
Xrdc2
struct  _xrdc2_master_domain_assignment
 Domain assignment for the bus master. More...
struct  _xrdc2_periph_access_config
 XRDC2 peripheral domain access control configuration. More...
struct  _xrdc2_mem_access_config
 XRDC2 memory region domain access control configuration. More...
struct  _xrdc2_mem_slot_access_config
 XRDC2 memory slot domain access control configuration. More...
#define FSL_XRDC2_DRIVER_VERSION   (MAKE_VERSION(2, 0, 2))
 Driver version.
#define XRDC2_EAL_FORCE_RELEASE_MAGIC_0   0x02000046UL
#define XRDC2_EAL_FORCE_RELEASE_MAGIC_1   0x02000052UL
#define XRDC2_EAL_DISABLE   (0UL << XRDC2_MSC_MSAC_W1_EAL_SHIFT)
#define XRDC2_EAL_DISABLE_UNTIL_RESET   (1UL << XRDC2_MSC_MSAC_W1_EAL_SHIFT)
#define XRDC2_EAL_UNLOCKED   (2UL << XRDC2_MSC_MSAC_W1_EAL_SHIFT)
#define XRDC2_EAL_LOCKED   (3UL << XRDC2_MSC_MSAC_W1_EAL_SHIFT)
#define XRDC2_EAL_MASK   XRDC2_MSC_MSAC_W1_EAL_MASK
typedef enum _xrdc2_global_config_lock xrdc2_global_config_lock_t
 Global configuration lock.
typedef enum _xrdc2_secure_attr xrdc2_secure_attr_t
 XRDC2 secure attribute, the register bit MDACi_MDAj_W0[SA], secure/nonsecure attribute output on a hit.
typedef enum _xrdc2_privilege_attr xrdc2_privilege_attr_t
 XRDC2 privileged attribute, the register bit MDACi_MDAj_W0[PA], defines the privileged/user attribute on a hit.
typedef struct _xrdc2_master_domain_assignment xrdc2_master_domain_assignment_t
typedef enum _xrdc2_access_policy xrdc2_access_policy_t
 XRDC2 domain access control policy.
typedef enum _xrdc2_access_config_lock xrdc2_access_config_lock_t
 Access configuration lock mode, the register field PDAC and MRGD LK2.
typedef struct _xrdc2_periph_access_config xrdc2_periph_access_config_t
typedef struct _xrdc2_mem_access_config xrdc2_mem_access_config_t
typedef struct _xrdc2_mem_slot_access_config xrdc2_mem_slot_access_config_t
enum  _xrdc2_global_config_lock { kXRDC2_GlobalConfigLockDisabled , kXRDC2_GlobalConfigLockDisabledUntilReset , kXRDC2_GlobalConfigLockOwnerOnly , kXRDC2_GlobalConfigLockEnabledUntilReset }
 Global configuration lock. More...
enum  _xrdc2_secure_attr { kXRDC2_MasterSecure = 0 , kXRDC2_ForceSecure = 2 , kXRDC2_ForceNonSecure = 3 }
 XRDC2 secure attribute, the register bit MDACi_MDAj_W0[SA], secure/nonsecure attribute output on a hit. More...
enum  _xrdc2_privilege_attr { kXRDC2_MasterPrivilege = 0 , kXRDC2_ForceUser = 2 , kXRDC2_ForcePrivilege = 3 }
 XRDC2 privileged attribute, the register bit MDACi_MDAj_W0[PA], defines the privileged/user attribute on a hit. More...
enum  _xrdc2_access_policy {
  kXRDC2_AccessPolicyNone = 0U , kXRDC2_AccessPolicyAlt1 = 1U , kXRDC2_AccessPolicyAlt2 = 2U , kXRDC2_AccessPolicyAlt3 = 3U ,
  kXRDC2_AccessPolicyAlt4 = 4U , kXRDC2_AccessPolicyAlt5 = 5U , kXRDC2_AccessPolicyAlt6 = 6U , kXRDC2_AccessPolicyAll = 7U
enum  _xrdc2_access_config_lock { kXRDC2_AccessConfigLockDisabled = 0U , kXRDC2_AccessConfigLockDisabledUntilReset = 1U , kXRDC2_AccessConfigLockDomainXOnly = 2U , kXRDC2_AccessConfigLockEnabledUntilReset = 3U }
 Access configuration lock mode, the register field PDAC and MRGD LK2. More...
void XRDC2_Init (XRDC2_Type *base)
 Initializes the XRDC2 module.
void XRDC2_Deinit (XRDC2_Type *base)
 De-initializes the XRDC2 module.
bool _xrdc2_master_domain_assignment::lock
xrdc2_privilege_attr_t _xrdc2_master_domain_assignment::privilegeAttr
xrdc2_secure_attr_t _xrdc2_master_domain_assignment::secureAttr
uint8_t _xrdc2_master_domain_assignment::domainId
uint16_t _xrdc2_master_domain_assignment::mask
uint16_t _xrdc2_master_domain_assignment::match
xrdc2_access_config_lock_t _xrdc2_periph_access_config::lockMode
xrdc2_access_policy_t _xrdc2_periph_access_config::policy [FSL_FEATURE_XRDC2_DOMAIN_COUNT]
uint32_t _xrdc2_mem_access_config::startAddr
uint32_t _xrdc2_mem_access_config::endAddr
xrdc2_access_config_lock_t _xrdc2_mem_access_config::lockMode
xrdc2_access_policy_t _xrdc2_mem_access_config::policy [FSL_FEATURE_XRDC2_DOMAIN_COUNT]
xrdc2_access_config_lock_t _xrdc2_mem_slot_access_config::lockMode
xrdc2_access_policy_t _xrdc2_mem_slot_access_config::policy [FSL_FEATURE_XRDC2_DOMAIN_COUNT]
XRDC2 manager (XRDC2)
void XRDC2_SetGlobalValid (XRDC2_Type *base, bool valid)
 Sets the XRDC2 global valid.
XRDC2 Master Domain Assignment Controller (XRDC2_MDAC).
void XRDC2_GetDefaultMasterDomainAssignment (xrdc2_master_domain_assignment_t *assignment)
 Gets the default master domain assignment.
void XRDC2_SetMasterDomainAssignment (XRDC2_Type *base, xrdc2_master_t master, uint8_t assignIndex, const xrdc2_master_domain_assignment_t *assignment)
 Sets the processor bus master domain assignment.
XRDC2 Memory Slot Access Controller (XRDC2_MSC).
void XRDC2_GetMemSlotAccessDefaultConfig (xrdc2_mem_slot_access_config_t *config)
 Gets the default memory slot access configuration.
void XRDC2_SetMemSlotAccessConfig (XRDC2_Type *base, xrdc2_mem_slot_t memSlot, const xrdc2_mem_slot_access_config_t *config)
 Sets the memory slot access policy.
void XRDC2_SetMemSlotAccessValid (XRDC2_Type *base, xrdc2_mem_slot_t memSlot, bool valid)
 Sets the memory slot descriptor as valid or invalid.
void XRDC2_SetMemSlotAccessLockMode (XRDC2_Type *base, xrdc2_mem_slot_t memSlot, xrdc2_access_config_lock_t lockMode)
 Sets the memory slot descriptor lock mode.
void XRDC2_SetMemSlotDomainAccessPolicy (XRDC2_Type *base, xrdc2_mem_slot_t memSlot, uint8_t domainId, xrdc2_access_policy_t policy)
 Sets the memory slot access policy for specific domain.
void XRDC2_EnableMemSlotExclAccessLock (XRDC2_Type *base, xrdc2_mem_slot_t memSlot, bool enable)
 Enable or disable the memory slot exclusive access lock.
uint8_t XRDC2_GetMemSlotExclAccessLockDomainOwner (XRDC2_Type *base, xrdc2_mem_slot_t memSlot)
 Get current memory slot exclusive access lock owner.
status_t XRDC2_TryLockMemSlotExclAccess (XRDC2_Type *base, xrdc2_mem_slot_t memSlot)
 Try to lock the memory slot exclusive access.
void XRDC2_LockMemSlotExclAccess (XRDC2_Type *base, xrdc2_mem_slot_t memSlot)
 Lock the memory slot exclusive access using blocking method.
XRDC2 Memory Region Controller (XRDC2_MRC)
void XRDC2_GetMemAccessDefaultConfig (xrdc2_mem_access_config_t *config)
 Gets the default memory access configuration.
void XRDC2_SetMemAccessConfig (XRDC2_Type *base, xrdc2_mem_t mem, const xrdc2_mem_access_config_t *config)
 Sets the memory region access policy.
void XRDC2_SetMemAccessValid (XRDC2_Type *base, xrdc2_mem_t mem, bool valid)
 Sets the memory region descriptor as valid or invalid.
void XRDC2_SetMemAccessLockMode (XRDC2_Type *base, xrdc2_mem_t mem, xrdc2_access_config_lock_t lockMode)
 Sets the memory descriptor lock mode.
void XRDC2_SetMemDomainAccessPolicy (XRDC2_Type *base, xrdc2_mem_t mem, uint8_t domainId, xrdc2_access_policy_t policy)
 Sets the memory region access policy for specific domain.
void XRDC2_EnableMemExclAccessLock (XRDC2_Type *base, xrdc2_mem_t mem, bool enable)
 Enable or disable the memory region exclusive access lock.
uint8_t XRDC2_GetMemExclAccessLockDomainOwner (XRDC2_Type *base, xrdc2_mem_t mem)
 Get current memory region exclusive access lock owner.
status_t XRDC2_TryLockMemExclAccess (XRDC2_Type *base, xrdc2_mem_t mem)
 Try to lock the memory region exclusive access.
void XRDC2_LockMemExclAccess (XRDC2_Type *base, xrdc2_mem_t mem)
 Lock the memory region exclusive access using blocking method.
void XRDC2_UnlockMemExclAccess (XRDC2_Type *base, xrdc2_mem_t mem)
 Unlock the memory region exclusive access.
void XRDC2_ForceMemExclAccessLockRelease (XRDC2_Type *base, xrdc2_mem_t mem)
 Force the memory region exclusive access lock release.
XRDC2 Peripheral Access Controller (XRDC2_PAC)
void XRDC2_GetPeriphAccessDefaultConfig (xrdc2_periph_access_config_t *config)
 Gets the default peripheral access configuration.
void XRDC2_SetPeriphAccessConfig (XRDC2_Type *base, xrdc2_periph_t periph, const xrdc2_periph_access_config_t *config)
 Sets the peripheral access policy.
void XRDC2_SetPeriphAccessValid (XRDC2_Type *base, xrdc2_periph_t periph, bool valid)
 Sets the peripheral descriptor as valid or invalid.
void XRDC2_SetPeriphAccessLockMode (XRDC2_Type *base, xrdc2_periph_t periph, xrdc2_access_config_lock_t lockMode)
 Sets the peripheral descriptor lock mode.
void XRDC2_SetPeriphDomainAccessPolicy (XRDC2_Type *base, xrdc2_periph_t periph, uint8_t domainId, xrdc2_access_policy_t policy)
 Sets the peripheral access policy for specific domain.
void XRDC2_EnablePeriphExclAccessLock (XRDC2_Type *base, xrdc2_periph_t periph, bool enable)
 Disable the peripheral exclusive access lock.
uint8_t XRDC2_GetPeriphExclAccessLockDomainOwner (XRDC2_Type *base, xrdc2_periph_t periph)
 Get current peripheral exclusive access lock owner.
status_t XRDC2_TryLockPeriphExclAccess (XRDC2_Type *base, xrdc2_periph_t periph)
 Try to lock the peripheral exclusive access.
void XRDC2_LockPeriphExclAccess (XRDC2_Type *base, xrdc2_periph_t periph)
 Lock the peripheral exclusive access using blocking method.
void XRDC2_UnlockPeriphExclAccess (XRDC2_Type *base, xrdc2_periph_t periph)
 Unlock the peripheral exclusive access.
void XRDC2_ForcePeriphExclAccessLockRelease (XRDC2_Type *base, xrdc2_periph_t periph)
 Force the peripheral exclusive access lock release.
Typedef Documentation
◆ xrdc2_master_domain_assignment_t
XRDC2 compares the bus master match input with the parameter mask and match in this structure. If hit, the domain ID, privilege attribute, and secure attribute are used for the access.
◆ _xrdc2_access_config_lock
Entire PDACn/MRGDn/MSC can be written.
Entire PDACn/MRGDn/MSC can be written until next reset.
Domain x only write the DxACP field.
PDACn/MRGDn/MSC is read-only until the next reset.
◆ _xrdc2_global_config_lock
Lock disabled, registers can be written by any domain.
Lock disabled until the next reset.
Lock enabled, only the lock owner can write.
Lock enabled, all registers are read only until the next reset.
◆ _xrdc2_privilege_attr
Use the bus master's attribute directly.
kXRDC2_ForceUser
Force the bus attribute for this master to user.
Force the bus attribute for this master to privileged.
◆ _xrdc2_secure_attr
kXRDC2_MasterSecure
Use the bus master's secure/nonsecure attribute directly.
kXRDC2_ForceSecure
Force the bus attribute for this master to secure.
Force the bus attribute for this master to non-secure.
◆ XRDC2_Deinit()
void XRDC2_Deinit ( XRDC2_Type base)
Parameters
baseXRDC2 peripheral base address.
brief De-initializes the XRDC2 module.
This function disables the XRDC2 clock.
param base XRDC2 peripheral base address.
◆ XRDC2_EnableMemExclAccessLock()
void XRDC2_EnableMemExclAccessLock ( XRDC2_Type base,
xrdc2_mem_t  mem,
bool  enable
Once disabled, it could not be enabled until reset.
Parameters
memThe memory region to operate.
enableTrue to enable, false to disable.
brief Disable the memory region exclusive access lock.
param base XRDC2 peripheral base address. param mem The memory region to operate.
◆ XRDC2_EnableMemSlotExclAccessLock()
void XRDC2_EnableMemSlotExclAccessLock ( XRDC2_Type base,
bool  enable
The lock must be enabled first before use. Once disabled, it could not be enabled until reset.
Parameters
memSlotThe memory slot to operate.
brief Enable or disable the memory slot exclusive access lock.
param base XRDC2 peripheral base address. param memSlot The memory slot to operate. param enable True to enable, false to disable.
◆ XRDC2_EnablePeriphExclAccessLock()
void XRDC2_EnablePeriphExclAccessLock ( XRDC2_Type base,
bool  enable
Parameters
periphThe peripheral to operate.
brief Disable the peripheral exclusive access lock.
param base XRDC2 peripheral base address. param periph The peripheral to operate. param enable True to enable, false to disable.
◆ XRDC2_ForceMemExclAccessLockRelease()
void XRDC2_ForceMemExclAccessLockRelease ( XRDC2_Type base,
xrdc2_mem_t  mem
The master does not own the lock could call this function to force release the lock.
Parameters
brief Force the memory region exclusive access lock release.
◆ XRDC2_ForcePeriphExclAccessLockRelease()
void XRDC2_ForcePeriphExclAccessLockRelease ( XRDC2_Type base,
Parameters
brief Force the peripheral exclusive access lock release.
◆ XRDC2_GetDefaultMasterDomainAssignment()
void XRDC2_GetDefaultMasterDomainAssignment ( xrdc2_master_domain_assignment_t assignment)
This function sets the assignment as follows:
config->lock = false;
config->privilegeAttr = kXRDC2_MasterPrivilege;
config->domainId = 0U;
config->mask = 0U;
config->match = 0U;
@ kXRDC2_MasterPrivilege
Definition: fsl_xrdc2.h:63
@ kXRDC2_MasterSecure
Definition: fsl_xrdc2.h:52
Definition: deflate.c:114
Parameters
assignmentPointer to the assignment structure.
brief Gets the default master domain assignment.
code config->lock = false; config->privilegeAttr = kXRDC2_MasterPrivilege; config->secureAttr = kXRDC2_MasterSecure; config->domainId = 0U; config->mask = 0U; config->match = 0U; endcode
param assignment Pointer to the assignment structure.
◆ XRDC2_GetMemAccessDefaultConfig()
void XRDC2_GetMemAccessDefaultConfig ( xrdc2_mem_access_config_t config)
config->startAddr = 0U;
config->endAddr = 0xFFFFFFFFU;
config->policy[0] = kXRDC2_AccessPolicyNone;
config->policy[1] = kXRDC2_AccessPolicyNone;
@ kXRDC2_AccessConfigLockDisabled
Definition: fsl_xrdc2.h:106
Parameters
configPointer to the configuration.
brief Gets the default memory access configuration.
code config->startAddr = 0U; config->endAddr = 0xFFFFFFFFU; config->lockMode = kXRDC2_AccessConfigLockDisabled; config->policy[0] = kXRDC2_AccessPolicyNone; config->policy[1] = kXRDC2_AccessPolicyNone; ... endcode
param config Pointer to the configuration.
◆ XRDC2_GetMemExclAccessLockDomainOwner()
uint8_t XRDC2_GetMemExclAccessLockDomainOwner ( XRDC2_Type base,
xrdc2_mem_t  mem
Parameters
Returns
The domain ID of the lock owner.
brief Get current memory region exclusive access lock owner.
param base XRDC2 peripheral base address. param mem The memory region to operate. param The domain ID of the lock owner.
◆ XRDC2_GetMemSlotAccessDefaultConfig()
void XRDC2_GetMemSlotAccessDefaultConfig ( xrdc2_mem_slot_access_config_t config)
Parameters
brief Gets the default memory slot access configuration.
code config->lockMode = kXRDC2_AccessConfigLockDisabled; config->policy[0] = kXRDC2_AccessPolicyNone; config->policy[1] = kXRDC2_AccessPolicyNone; ... endcode
◆ XRDC2_GetMemSlotExclAccessLockDomainOwner()
uint8_t XRDC2_GetMemSlotExclAccessLockDomainOwner ( XRDC2_Type base,
Parameters
Returns
Parameters
Returns
◆ XRDC2_GetPeriphAccessDefaultConfig()
void XRDC2_GetPeriphAccessDefaultConfig ( xrdc2_periph_access_config_t config)
The default configuration is set as follows:
config->lockMode = kXRDC2_AccessConfigLockWritable;
config->policy[15] = kXRDC2_AccessPolicyNone;
Parameters
configPointer to the configuration structure.
brief Gets the default peripheral access configuration.
The default configuration is set as follows: code config->lockMode = kXRDC2_AccessConfigLockWritable; config->policy[0] = kXRDC2_AccessPolicyNone; config->policy[1] = kXRDC2_AccessPolicyNone; ... config->policy[15] = kXRDC2_AccessPolicyNone; endcode
param config Pointer to the configuration structure.
◆ XRDC2_GetPeriphExclAccessLockDomainOwner()
uint8_t XRDC2_GetPeriphExclAccessLockDomainOwner ( XRDC2_Type base,
Parameters
Returns
brief Get current peripheral exclusive access lock owner.
param base XRDC2 peripheral base address. param periph The peripheral to operate. param The domain ID of the lock owner.
◆ XRDC2_Init()
void XRDC2_Init ( XRDC2_Type base)
Parameters
brief Initializes the XRDC2 module.
This function enables the XRDC2 clock.
◆ XRDC2_LockMemExclAccess()
void XRDC2_LockMemExclAccess ( XRDC2_Type base,
xrdc2_mem_t  mem
Parameters
Note
This function must be called when the lock is not disabled.
brief Lock the memory region exclusive access using blocking method.
note This function must be called when the lock is not disabled.
◆ XRDC2_LockMemSlotExclAccess()
void XRDC2_LockMemSlotExclAccess ( XRDC2_Type base,
Parameters
Note
brief Lock the memory slot exclusive access using blocking method.
◆ XRDC2_LockPeriphExclAccess()
void XRDC2_LockPeriphExclAccess ( XRDC2_Type base,
Parameters
Note
brief Lock the peripheral exclusive access using blocking method.
◆ XRDC2_SetGlobalValid()
void XRDC2_SetGlobalValid ( XRDC2_Type base,
bool  valid
This function sets the XRDC2 global valid or invalid. When the XRDC2 is global invalid, all accesses from all bus masters to all slaves are allowed.
Parameters
validTrue to valid XRDC2.
brief Sets the XRDC2 global valid.
param base XRDC2 peripheral base address. param valid True to valid XRDC2.
◆ XRDC2_SetMasterDomainAssignment()
void XRDC2_SetMasterDomainAssignment ( XRDC2_Type base,
const xrdc2_master_domain_assignment_t assignment
Parameters
masterWhich master to configure.
assignIndexWhich assignment register to set.
brief Sets the processor bus master domain assignment.
param base XRDC2 peripheral base address. param master Which master to configure. param assignIndex Which assignment register to set. param assignment Pointer to the assignment structure.
◆ XRDC2_SetMemAccessConfig()
void XRDC2_SetMemAccessConfig ( XRDC2_Type base,
xrdc2_mem_t  mem,
const xrdc2_mem_access_config_t config
Parameters
memWhich memory region descriptor to set.
configPointer to the access policy configuration structure.
brief Sets the memory region access policy.
param base XRDC2 peripheral base address. param config Pointer to the access policy configuration structure.
◆ XRDC2_SetMemAccessLockMode()
void XRDC2_SetMemAccessLockMode ( XRDC2_Type base,
xrdc2_mem_t  mem,
Parameters
memWhich memory descriptor to set.
lockModeThe lock mode to set.
brief Sets the memory descriptor lock mode.
param base XRDC2 peripheral base address. param mem Which memory descriptor to set. param lockMode The lock mode to set.
◆ XRDC2_SetMemAccessValid()
void XRDC2_SetMemAccessValid ( XRDC2_Type base,
xrdc2_mem_t  mem,
bool  valid
Parameters
validTrue to set valid, false to set invalid.
brief Sets the memory region descriptor as valid or invalid.
param base XRDC2 peripheral base address. param mem Which memory region descriptor to set. param valid True to set valid, false to set invalid.
◆ XRDC2_SetMemDomainAccessPolicy()
void XRDC2_SetMemDomainAccessPolicy ( XRDC2_Type base,
xrdc2_mem_t  mem,
uint8_t  domainId,
Parameters
domainIdThe ID of the domain whose policy will be changed.
policyThe access policy to set.
brief Sets the memory region access policy for specific domain.
param base XRDC2 peripheral base address. param mem The memory region to operate. param domainId The ID of the domain whose policy will be changed. param policy The access policy to set.
◆ XRDC2_SetMemSlotAccessConfig()
void XRDC2_SetMemSlotAccessConfig ( XRDC2_Type base,
const xrdc2_mem_slot_access_config_t config
Parameters
memSlotWhich memory slot descriptor to set.
brief Sets the memory slot access policy.
◆ XRDC2_SetMemSlotAccessLockMode()
void XRDC2_SetMemSlotAccessLockMode ( XRDC2_Type base,
Parameters
brief Sets the memory slot descriptor lock mode.
param base XRDC2 peripheral base address. param memSlot Which memory slot descriptor to set. param lockMode The lock mode to set.
◆ XRDC2_SetMemSlotAccessValid()
void XRDC2_SetMemSlotAccessValid ( XRDC2_Type base,
bool  valid
Parameters
brief Sets the memory slot descriptor as valid or invalid.
param base XRDC2 peripheral base address. param memSlot Which memory slot descriptor to set. param valid True to set valid, false to set invalid.
◆ XRDC2_SetMemSlotDomainAccessPolicy()
void XRDC2_SetMemSlotDomainAccessPolicy ( XRDC2_Type base,
uint8_t  domainId,
Parameters
brief Sets the memory slot access policy for specific domain.
param base XRDC2 peripheral base address. param memSlot The memory slot to operate. param domainId The ID of the domain whose policy will be changed. param policy The access policy to set.
◆ XRDC2_SetPeriphAccessConfig()
void XRDC2_SetPeriphAccessConfig ( XRDC2_Type base,
const xrdc2_periph_access_config_t config
Parameters
periphWhich peripheral descriptor to set.
brief Sets the peripheral access policy.
◆ XRDC2_SetPeriphAccessLockMode()
void XRDC2_SetPeriphAccessLockMode ( XRDC2_Type base,
Parameters
brief Sets the peripheral descriptor lock mode.
param base XRDC2 peripheral base address. param periph Which peripheral descriptor to set. param lockMode The lock mode to set.
◆ XRDC2_SetPeriphAccessValid()
void XRDC2_SetPeriphAccessValid ( XRDC2_Type base,
bool  valid
Parameters
brief Sets the peripheral descriptor as valid or invalid.
param base XRDC2 peripheral base address. param periph Which peripheral descriptor to set. param valid True to set valid, false to set invalid.
◆ XRDC2_SetPeriphDomainAccessPolicy()
void XRDC2_SetPeriphDomainAccessPolicy ( XRDC2_Type base,
uint8_t  domainId,
Parameters
brief Sets the peripheral access policy for specific domain.
param base XRDC2 peripheral base address. param periph The peripheral to operate. param domainId The ID of the domain whose policy will be changed. param policy The access policy to set.
◆ XRDC2_TryLockMemExclAccess()
status_t XRDC2_TryLockMemExclAccess ( XRDC2_Type base,
xrdc2_mem_t  mem
Parameters
Return values
kStatus_FailFailed to lock.
kStatus_SuccessLocked succussfully.
brief Try to lock the memory region exclusive access.
param base XRDC2 peripheral base address. param mem The memory region to operate. retval kStatus_Fail Failed to lock. retval kStatus_Success Locked succussfully.
◆ XRDC2_TryLockMemSlotExclAccess()
status_t XRDC2_TryLockMemSlotExclAccess ( XRDC2_Type base,
Parameters
Return values
brief Try to lock the memory slot exclusive access.
param base XRDC2 peripheral base address. param memSlot The memory slot to operate. retval kStatus_Fail Failed to lock. retval kStatus_Success Locked succussfully.
◆ XRDC2_TryLockPeriphExclAccess()
status_t XRDC2_TryLockPeriphExclAccess ( XRDC2_Type base,
Parameters
Return values
brief Try to lock the peripheral exclusive access.
param base XRDC2 peripheral base address. param periph The peripheral to operate. retval kStatus_Fail Failed to lock. retval kStatus_Success Locked succussfully.
◆ XRDC2_UnlockMemExclAccess()
void XRDC2_UnlockMemExclAccess ( XRDC2_Type base,
xrdc2_mem_t  mem
Parameters
Note
This function must be called by the lock owner.
brief Unlock the memory region exclusive access.
note This function must be called by the lock owner.
◆ XRDC2_UnlockPeriphExclAccess()
void XRDC2_UnlockPeriphExclAccess ( XRDC2_Type base,
Parameters
Note
brief Unlock the peripheral exclusive access.
Variable Documentation
◆ domainId
Domain ID used when this descriptor hit.
◆ endAddr
Memory region end address, (endAddr + 1) should be 4k aligned.
◆ lock
Set true to lock the descriptor.
◆ lockMode [1/3]
PDACn lock configuration.
◆ lockMode [2/3]
MRGDn lock configuration.
◆ lockMode [3/3]
Descriptor lock configuration.
◆ mask
Mask used for descriptor hit.
◆ match
Match used for descriptor hit.
◆ policy [1/3]
xrdc2_access_policy_t _xrdc2_periph_access_config::policy[FSL_FEATURE_XRDC2_DOMAIN_COUNT]
Access policy for each domain.
◆ policy [2/3]
xrdc2_access_policy_t _xrdc2_mem_access_config::policy[FSL_FEATURE_XRDC2_DOMAIN_COUNT]
◆ policy [3/3]
xrdc2_access_policy_t _xrdc2_mem_slot_access_config::policy[FSL_FEATURE_XRDC2_DOMAIN_COUNT]
◆ privilegeAttr
Privilege attribute.
◆ secureAttr
Secure attribute.
◆ startAddr
Memory region start address, should be 4k aligned.
