RTEMS 6.1
Xbarb
#define FSL_XBARB_DRIVER_VERSION   (MAKE_VERSION(2, 0, 2))
#define XBARB_SELx(base, output)   (((volatile uint16_t *)(&((base)->SEL0)))[(uint32_t)(output) / 2UL])
#define XBARB_WR_SELx_SELx(base, input, output)   XBARB_SetSignalsConnection((base), (input), (output))
XBARB functional Operation.
void XBARB_Init (XBARB_Type *base)
 Initializes the XBARB module.
void XBARB_Deinit (XBARB_Type *base)
 Shuts down the XBARB module.
void XBARB_SetSignalsConnection (XBARB_Type *base, xbar_input_signal_t input, xbar_output_signal_t output)
 Configures a connection between the selected XBARB_IN[*] input and the XBARB_OUT[*] output signal.
◆ XBARB_Deinit()
void XBARB_Deinit ( XBARB_Type base)
This function disables XBARB clock.
Parameters
baseXBARB peripheral address.
brief Shuts down the XBARB module.
param base XBARB peripheral address.
◆ XBARB_Init()
void XBARB_Init ( XBARB_Type base)
This function un-gates the XBARB clock.
Parameters
brief Initializes the XBARB module.
◆ XBARB_SetSignalsConnection()
void XBARB_SetSignalsConnection ( XBARB_Type base,
This function configures which XBARB input is connected to the selected XBARB output. If more than one XBARB module is available, only the inputs and outputs from the same module can be connected.
Parameters
inputXBARB input signal.
outputXBARB output signal.
brief Configures a connection between the selected XBARB_IN[*] input and the XBARB_OUT[*] output signal.
param base XBARB peripheral address. param input XBARB input signal. param output XBARB output signal.
