RTEMS 6.1
Data Structures | Enumerator | Variables
Smartcard
struct  _smartcard_card_params
 Defines card-specific parameters for Smart card driver. More...
struct  _smartcard_timers_state
 Smart card defines the state of the EMV timers in the Smart card driver. More...
struct  _smartcard_interface_config
 Defines user specified configuration of Smart card interface. More...
struct  _smartcard_xfer
 Defines user transfer structure used to initialize transfer. More...
struct  _smartcard_context
 Runtime state of the Smart card driver. More...
uint16_t _smartcard_card_params::Fi
uint8_t _smartcard_card_params::fMax
uint8_t _smartcard_card_params::WI
uint8_t _smartcard_card_params::Di
uint8_t _smartcard_card_params::BWI
uint8_t _smartcard_card_params::CWI
uint8_t _smartcard_card_params::BGI
uint8_t _smartcard_card_params::GTN
uint8_t _smartcard_card_params::IFSC
uint8_t _smartcard_card_params::modeNegotiable
uint8_t _smartcard_card_params::currentD
uint8_t _smartcard_card_params::status
bool _smartcard_card_params::t0Indicated
bool _smartcard_card_params::t1Indicated
bool _smartcard_card_params::atrComplete
bool _smartcard_card_params::atrValid
bool _smartcard_card_params::present
bool _smartcard_card_params::active
bool _smartcard_card_params::faulty
smartcard_card_convention_t _smartcard_card_params::convention
volatile bool _smartcard_timers_state::adtExpired
volatile bool _smartcard_timers_state::wwtExpired
volatile bool _smartcard_timers_state::cwtExpired
volatile bool _smartcard_timers_state::bwtExpired
volatile bool _smartcard_timers_state::initCharTimerExpired
uint32_t _smartcard_interface_config::smartCardClock
uint32_t _smartcard_interface_config::clockToResetDelay
uint8_t _smartcard_interface_config::clockModule
uint8_t _smartcard_interface_config::clockModuleChannel
uint8_t _smartcard_interface_config::clockModuleSourceClock
smartcard_card_voltage_class_t _smartcard_interface_config::vcc
uint8_t _smartcard_interface_config::controlPort
uint8_t _smartcard_interface_config::controlPin
uint8_t _smartcard_interface_config::irqPort
uint8_t _smartcard_interface_config::irqPin
uint8_t _smartcard_interface_config::resetPort
uint8_t _smartcard_interface_config::resetPin
uint8_t _smartcard_interface_config::vsel0Port
uint8_t _smartcard_interface_config::vsel0Pin
uint8_t _smartcard_interface_config::vsel1Port
uint8_t _smartcard_interface_config::vsel1Pin
uint8_t _smartcard_interface_config::dataPort
uint8_t _smartcard_interface_config::dataPin
uint8_t _smartcard_interface_config::dataPinMux
uint8_t _smartcard_interface_config::tsTimerId
smartcard_direction_t _smartcard_xfer::direction
uint8_t * _smartcard_xfer::buff
size_t _smartcard_xfer::size
void * _smartcard_context::base
smartcard_direction_t _smartcard_context::direction
uint8_t * _smartcard_context::xBuff
volatile size_t _smartcard_context::xSize
volatile bool _smartcard_context::xIsBusy
uint8_t _smartcard_context::txFifoEntryCount
uint8_t _smartcard_context::rxFifoThreshold
smartcard_interface_callback_t _smartcard_context::interfaceCallback
smartcard_transfer_callback_t _smartcard_context::transferCallback
void * _smartcard_context::interfaceCallbackParam
void * _smartcard_context::transferCallbackParam
smartcard_time_delay_t _smartcard_context::timeDelay
smartcard_reset_type_t _smartcard_context::resetType
smartcard_transport_type_t _smartcard_context::tType
volatile smartcard_transfer_state_t _smartcard_context::transferState
smartcard_timers_state_t _smartcard_context::timersState
smartcard_card_params_t _smartcard_context::cardParams
uint8_t _smartcard_context::IFSD
smartcard_parity_type_t _smartcard_context::parity
volatile bool _smartcard_context::rxtCrossed
volatile bool _smartcard_context::txtCrossed
volatile bool _smartcard_context::wtxRequested
volatile bool _smartcard_context::parityError
uint8_t _smartcard_context::statusBytes [2]
smartcard_interface_config_t _smartcard_context::interfaceConfig
bool _smartcard_context::abortTransfer
Driver version
enum  {
  kStatus_SMARTCARD_Success = MAKE_STATUS(kStatusGroup_SMARTCARD, 0) , kStatus_SMARTCARD_TxBusy = MAKE_STATUS(kStatusGroup_SMARTCARD, 1) , kStatus_SMARTCARD_RxBusy = MAKE_STATUS(kStatusGroup_SMARTCARD, 2) , kStatus_SMARTCARD_NoTransferInProgress = MAKE_STATUS(kStatusGroup_SMARTCARD, 3) ,
  kStatus_SMARTCARD_Timeout = MAKE_STATUS(kStatusGroup_SMARTCARD, 4) , kStatus_SMARTCARD_Initialized , kStatus_SMARTCARD_PhyInitialized , kStatus_SMARTCARD_CardNotActivated = MAKE_STATUS(kStatusGroup_SMARTCARD, 7) ,
  kStatus_SMARTCARD_InvalidInput , kStatus_SMARTCARD_OtherError = MAKE_STATUS(kStatusGroup_SMARTCARD, 9)
 Smart card Error codes. More...
enum  _smartcard_control {
  kSMARTCARD_EnableADT = 0x0u , kSMARTCARD_DisableADT = 0x1u , kSMARTCARD_EnableGTV = 0x2u , kSMARTCARD_DisableGTV = 0x3u ,
  kSMARTCARD_ResetWWT = 0x4u , kSMARTCARD_EnableWWT = 0x5u , kSMARTCARD_DisableWWT = 0x6u , kSMARTCARD_ResetCWT = 0x7u ,
  kSMARTCARD_EnableCWT = 0x8u , kSMARTCARD_DisableCWT = 0x9u , kSMARTCARD_ResetBWT = 0xAu , kSMARTCARD_EnableBWT = 0xBu ,
  kSMARTCARD_DisableBWT = 0xCu , kSMARTCARD_EnableInitDetect = 0xDu , kSMARTCARD_EnableAnack = 0xEu , kSMARTCARD_DisableAnack = 0xFu ,
  kSMARTCARD_ConfigureBaudrate = 0x10u , kSMARTCARD_SetupATRMode = 0x11u , kSMARTCARD_SetupT0Mode = 0x12u , kSMARTCARD_SetupT1Mode = 0x13u ,
  kSMARTCARD_EnableReceiverMode = 0x14u , kSMARTCARD_DisableReceiverMode = 0x15u , kSMARTCARD_EnableTransmitterMode = 0x16u , kSMARTCARD_DisableTransmitterMode = 0x17u ,
  kSMARTCARD_ResetWaitTimeMultiplier = 0x18u
 Control codes for the Smart card protocol timers and misc.
enum  _smartcard_card_voltage_class { kSMARTCARD_VoltageClassUnknown = 0x0u , kSMARTCARD_VoltageClassA5_0V = 0x1u , kSMARTCARD_VoltageClassB3_3V = 0x2u , kSMARTCARD_VoltageClassC1_8V = 0x3u }
 Defines Smart card interface voltage class values.
enum  _smartcard_transfer_state {
  kSMARTCARD_IdleState = 0x0u , kSMARTCARD_WaitingForTSState = 0x1u , kSMARTCARD_InvalidTSDetecetedState = 0x2u , kSMARTCARD_ReceivingState = 0x3u ,
  kSMARTCARD_TransmittingState = 0x4u
 Defines Smart card I/O transfer states.
enum  _smartcard_reset_type { kSMARTCARD_ColdReset = 0x0u , kSMARTCARD_WarmReset = 0x1u , kSMARTCARD_NoColdReset = 0x2u , kSMARTCARD_NoWarmReset = 0x3u }
 Defines Smart card reset types.
enum  _smartcard_transport_type { kSMARTCARD_T0Transport = 0x0u , kSMARTCARD_T1Transport = 0x1u }
 Defines Smart card transport protocol types.
enum  _smartcard_parity_type { kSMARTCARD_EvenParity = 0x0u , kSMARTCARD_OddParity = 0x1u }
 Defines Smart card data parity types.
enum  _smartcard_card_convention { kSMARTCARD_DirectConvention = 0x0u , kSMARTCARD_InverseConvention = 0x1u }
 Defines data Convention format.
enum  _smartcard_interface_control { kSMARTCARD_InterfaceSetVcc = 0x00u , kSMARTCARD_InterfaceSetClockToResetDelay = 0x01u , kSMARTCARD_InterfaceReadStatus = 0x02u }
 Defines Smart card interface IC control types.
enum  _smartcard_direction { kSMARTCARD_Receive = 0u , kSMARTCARD_Transmit = 1u }
 Defines transfer direction.
typedef enum _smartcard_control smartcard_control_t
typedef enum _smartcard_card_voltage_class smartcard_card_voltage_class_t
typedef enum _smartcard_transfer_state smartcard_transfer_state_t
typedef enum _smartcard_reset_type smartcard_reset_type_t
typedef enum _smartcard_transport_type smartcard_transport_type_t
typedef enum _smartcard_parity_type smartcard_parity_type_t
typedef enum _smartcard_card_convention smartcard_card_convention_t
typedef enum _smartcard_interface_control smartcard_interface_control_t
typedef enum _smartcard_direction smartcard_direction_t
typedef void(* smartcard_interface_callback_t) (void *smartcardContext, void *param)
 Smart card interface interrupt callback function type.
typedef void(* smartcard_transfer_callback_t) (void *smartcardContext, void *param)
 Smart card transfer interrupt callback function type.
typedef void(* smartcard_time_delay_t) (uint32_t us)
 Time Delay function used to passive waiting using RTOS [us].
typedef struct _smartcard_card_params smartcard_card_params_t
typedef struct _smartcard_timers_state smartcard_timers_state_t
typedef struct _smartcard_interface_config smartcard_interface_config_t
typedef struct _smartcard_xfer smartcard_xfer_t
typedef struct _smartcard_context smartcard_context_t
#define FSL_SMARTCARD_DRIVER_VERSION   (MAKE_VERSION(2, 2, 2))
 Smart card driver version 2.2.2.
#define SMARTCARD_INIT_DELAY_CLOCK_CYCLES   (42000u)
 Smart card global define which specify number of clock cycles until initial 'TS' character has to be received.
#define SMARTCARD_EMV_ATR_DURATION_ETU   (20150u)
 Smart card global define which specify number of clock cycles during which ATR string has to be received.
#define SMARTCARD_TS_DIRECT_CONVENTION   (0x3Bu)
 Smart card specification initial TS character definition of direct convention.
#define SMARTCARD_TS_INVERSE_CONVENTION   (0x3Fu)
 Smart card specification initial TS character definition of inverse convention.
◆ anonymous enum
anonymous enum
Transfer ends successfully
Transmit in progress
Receiving in progress
No transfer in progress
Transfer ends with time-out
Smart card driver is already initialized
Smart card PHY drive is already initialized
Smart card is not activated
Function called with invalid input arguments
Some other error occur
Variable Documentation
◆ abortTransfer
Used to abort transfer.
◆ active
Indicates if the smart card is activated
◆ adtExpired
Indicates whether ADT timer expired
◆ atrComplete
Indicates whether the ATR received from the card was complete or not
◆ atrValid
Indicates whether the ATR received from the card was valid or not
◆ base
void* _smartcard_context::base
Smart card module base address
◆ BGI
4 bits BGI - block guard time integer
◆ buff
uint8_t* _smartcard_xfer::buff
The buffer of data.
◆ BWI
4 bits BWI - block wait time integer
◆ bwtExpired
Indicates whether BWT timer expired
◆ cardParams
Smart card parameters(ATR and current) and interface slots states(ATR and current)
◆ clockModule
Smart card clock module number
◆ clockModuleChannel
Smart card clock module channel number
◆ clockModuleSourceClock
Smart card clock module source clock [e.g., BusClk]
◆ clockToResetDelay
Indicates clock to RST apply delay [smart card clock cycles]
◆ controlPin
Smart card PHY control pin instance
◆ controlPort
Smart card PHY control port instance
◆ convention
Card convention, kSMARTCARD_DirectConvention for direct convention, kSMARTCARD_InverseConvention for inverse convention
◆ currentD
4 bits DI - current baud rate divisor
◆ CWI
4 bits CWI - character wait time integer
◆ cwtExpired
Indicates whether CWT timer expired
◆ dataPin
Smart card PHY data pin instance
◆ dataPinMux
Smart card PHY data pin mux option
◆ dataPort
Smart card PHY data port instance
◆ Di
4 bits DI - baud rate divisor
◆ direction [1/2]
Direction of communication. (RX/TX)
◆ direction [2/2]
◆ faulty
Indicates whether smart card/interface is faulty
◆ Fi
4 bits Fi - clock rate conversion integer
◆ fMax
Maximum Smart card frequency in MHz
◆ GTN
8 bits GTN - extended guard time integer
◆ IFSC
Indicates IFSC value of the card
◆ IFSD
Indicates the terminal IFSD
◆ initCharTimerExpired
Indicates whether reception timer for initialization character (TS) after the RST has expired
◆ interfaceCallback
Callback to invoke after interface IC raised interrupt.
◆ interfaceCallbackParam
void* _smartcard_context::interfaceCallbackParam
Interface callback parameter pointer.
◆ interfaceConfig
Smart card interface configuration structure
◆ irqPin
Smart card PHY Interrupt pin instance
◆ irqPort
Smart card PHY Interrupt port instance
◆ modeNegotiable
Indicates if the card acts in negotiable or a specific mode.
◆ parity
Indicates current parity even/odd
◆ parityError
Indicates whether a parity error has been detected
◆ present
Indicates if a smart card is present
◆ resetPin
Smart card reset pin instance
◆ resetPort
Smart card reset port instance
◆ resetType
Indicates whether a Cold reset or Warm reset was requested.
◆ rxFifoThreshold
The max value of the receiver FIFO threshold.
◆ rxtCrossed
Indicates whether RXT thresholds has been crossed
◆ size
The number of transferred units.
◆ smartCardClock
Smart card interface clock [Hz]
◆ status
Indicates smart card status
◆ statusBytes
uint8_t _smartcard_context::statusBytes[2]
Used to store Status bytes SW1, SW2 of the last executed card command response
◆ t0Indicated
Indicates ff T=0 indicated in TD1 byte
◆ t1Indicated
Indicates if T=1 indicated in TD2 byte
◆ timeDelay
Function which handles time delay defined by user or RTOS.
◆ timersState
Indicates the state of different protocol timers used in driver
◆ transferCallback
Callback to invoke after transfer event occur.
◆ transferCallbackParam
void* _smartcard_context::transferCallbackParam
Transfer callback parameter pointer.
◆ transferState
Indicates the current transfer state
◆ tsTimerId
Numerical identifier of the External HW timer for Initial character detection
◆ tType
Indicates current transfer protocol (T0 or T1)
◆ txFifoEntryCount
Number of data word entries in transmit FIFO.
◆ txtCrossed
Indicates whether TXT thresholds has been crossed
◆ vcc
Smart card voltage class
◆ vsel0Pin
Smart card PHY Vsel0 control pin instance
◆ vsel0Port
Smart card PHY Vsel0 control port instance
◆ vsel1Pin
Smart card PHY Vsel1 control pin instance
◆ vsel1Port
Smart card PHY Vsel1 control port instance
◆ WI
8 bits WI - work wait time integer
◆ wtxRequested
Indicates whether WTX has been requested or not
◆ wwtExpired
Indicates whether WWT timer expired
◆ xBuff
uint8_t* _smartcard_context::xBuff
The buffer of data being transferred.
◆ xIsBusy
True if there is an active transfer.
◆ xSize
The number of bytes to be transferred.
