RTEMS 6.1
Data Structures | Enumerator | Functions | Variables
Puf_driver
struct  puf_config_t
void PUF_GetDefaultConfig (puf_config_t *conf)
 Sets the default configuration of PUF.
status_t PUF_Init (PUF_Type *base, puf_config_t *conf)
 Initialize PUF.
void PUF_Deinit (PUF_Type *base, puf_config_t *conf)
 Denitialize PUF.
status_t PUF_Enroll (PUF_Type *base, uint8_t *activationCode, size_t activationCodeSize)
 Enroll PUF.
status_t PUF_Start (PUF_Type *base, const uint8_t *activationCode, size_t activationCodeSize)
 Start PUF.
status_t PUF_SetIntrinsicKey (PUF_Type *base, puf_key_index_register_t keyIndex, size_t keySize, uint8_t *keyCode, size_t keyCodeSize)
 Set intrinsic key.
status_t PUF_SetUserKey (PUF_Type *base, puf_key_index_register_t keyIndex, const uint8_t *userKey, size_t userKeySize, uint8_t *keyCode, size_t keyCodeSize)
 Set user key.
status_t PUF_GetKey (PUF_Type *base, const uint8_t *keyCode, size_t keyCodeSize, uint8_t *key, size_t keySize)
 Reconstruct key from a key code.
status_t PUF_GetHwKey (PUF_Type *base, const uint8_t *keyCode, size_t keyCodeSize, puf_key_slot_t keySlot, uint32_t keyMask)
 Reconstruct hw bus key from a key code.
status_t PUF_Zeroize (PUF_Type *base)
 Zeroize PUF.
bool PUF_IsGetKeyAllowed (PUF_Type *base)
 Checks if Get Key operation is allowed.
status_t PUF_PowerCycle (PUF_Type *base, puf_config_t *conf)
 Powercycle PUF.
uint32_t puf_config_t::dischargeTimeMsec
uint32_t puf_config_t::coreClockFrequencyHz
Driver version
enum  _puf_key_index_register {
  kPUF_KeyIndex_00 = 0x00U , kPUF_KeyIndex_01 = 0x01U , kPUF_KeyIndex_02 = 0x02U , kPUF_KeyIndex_03 = 0x03U ,
  kPUF_KeyIndex_04 = 0x04U , kPUF_KeyIndex_05 = 0x05U , kPUF_KeyIndex_06 = 0x06U , kPUF_KeyIndex_07 = 0x07U ,
  kPUF_KeyIndex_08 = 0x08U , kPUF_KeyIndex_09 = 0x09U , kPUF_KeyIndex_10 = 0x0AU , kPUF_KeyIndex_11 = 0x0BU ,
  kPUF_KeyIndex_12 = 0x0CU , kPUF_KeyIndex_13 = 0x0DU , kPUF_KeyIndex_14 = 0x0EU , kPUF_KeyIndex_15 = 0x0FU
enum  _puf_min_max { kPUF_KeySizeMin = 8u , kPUF_KeySizeMax = 512u , kPUF_KeyIndexMax = kPUF_KeyIndex_15 }
enum  _puf_key_slot { kPUF_KeySlot0 = 0U , kPUF_KeySlot1 = 1U }
 PUF key slot. More...
enum  { kStatus_EnrollNotAllowed = MAKE_STATUS(kStatusGroup_PUF, 1) , kStatus_StartNotAllowed = MAKE_STATUS(kStatusGroup_PUF, 2) }
typedef enum _puf_key_index_register puf_key_index_register_t
typedef enum _puf_min_max puf_min_max_t
typedef enum _puf_key_slot puf_key_slot_t
 PUF key slot.
#define FSL_PUF_DRIVER_VERSION   (MAKE_VERSION(2, 1, 6))
 PUF driver version. Version 2.1.6.
#define PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(x)   ((160u + (((((x) << 3) + 255u) >> 8) << 8)) >> 3)
 Get Key Code size in bytes from key size in bytes at compile time.
#define PUF_MIN_KEY_CODE_SIZE   PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(8UL)
#define PUF_ACTIVATION_CODE_SIZE   1192U
#define KEYSTORE_PUF_DISCHARGE_TIME_FIRST_TRY_MS   50
#define KEYSTORE_PUF_DISCHARGE_TIME_MAX_MS   400
◆ FSL_PUF_DRIVER_VERSION
Current version: 2.1.6
Change log:
  • 2.0.0
    • Initial version.
  • 2.0.1
    • Fixed puf_wait_usec function optimization issue.
  • 2.0.2
    • Add PUF configuration structure and support for PUF SRAM controller. Remove magic constants.
  • 2.0.3
    • Fix MISRA C-2012 issue.
  • 2.1.0
    • Align driver with PUF SRAM controller registers on LPCXpresso55s16.
    • Update initizalition logic .
  • 2.1.1
    • Fix ARMGCC build warning .
  • 2.1.2
    • Update: Add automatic big to little endian swap for user (pre-shared) keys destinated to secret hardware bus (PUF key index 0).
  • 2.1.3
  • 2.1.4
    • Replace register uint32_t ticksCount with volatile uint32_t ticksCount in puf_wait_usec() to prevent optimization out delay loop.
  • 2.1.5
    • Use common SDK delay in puf_wait_usec()
  • 2.1.6
    • Changed wait time in PUF_Init(), when initialization fails it will try PUF_Powercycle() with shorter time. If this shorter time will also fail, initialization will be tried with worst case time as before.
◆ anonymous enum
anonymous enum
PUF status return codes.
◆ _puf_key_slot
PUF key slot.
kPUF_KeySlot0
PUF key slot 0
kPUF_KeySlot1
PUF key slot 1
◆ PUF_Deinit()
void PUF_Deinit ( PUF_Type base,
puf_config_t conf
Denitialize PUF.
This function disables power to PUF SRAM and peripheral clock.
Parameters
basePUF peripheral base address
confPUF configuration structure
brief Denitialize PUF
param base PUF peripheral base address param conf PUF configuration structure
◆ PUF_Enroll()
status_t PUF_Enroll ( PUF_Type base,
uint8_t *  activationCode,
Enroll PUF.
This function derives a digital fingerprint, generates the corresponding Activation Code (AC) and returns it to be stored in an NVM or a file. This step needs to be performed only once for each device. This function may be permanently disallowed by a fuse.
Parameters
[out]activationCodeWord aligned address of the resulting activation code.
activationCodeSizeSize of the activationCode buffer in bytes. Shall be 1192 bytes.
Returns
Status of enroll operation.
brief Enroll PUF
param base PUF peripheral base address param[out] activationCode Word aligned address of the resulting activation code. param activationCodeSize Size of the activationCode buffer in bytes. Shall be 1192 bytes. return Status of enroll operation.
◆ PUF_GetDefaultConfig()
void PUF_GetDefaultConfig ( puf_config_t conf)
This function initialize PUF config structure to default values.
Parameters
brief Sets the default configuration of PUF
◆ PUF_GetHwKey()
status_t PUF_GetHwKey ( PUF_Type base,
const uint8_t *  keyCode,
size_t  keyCodeSize,
uint32_t  keyMask
The digital fingerprint generated during the Start operation and the KC generated during a Set Key operation (Set intrinsic key or Set user key) are used to retrieve a stored key. This operation needs to be done every time a key is needed. This function accepts only Key Codes created for PUF index register kPUF_KeyIndex_00. Such a key is output directly to a dedicated hardware bus. The reconstructed key is not exposed to system memory.
Parameters
keyCodeWord aligned address of the input key code.
keyCodeSizeSize of the keyCode buffer in bytes. Shall be PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(keySize).
keySlotkey slot to output on hw bus. Parameter is ignored on devices with less than two key slots.
keyMaskkey masking value. Shall be random for each POR/reset. Value does not have to be cryptographicaly secure.
Returns
Status of get key operation.
brief Reconstruct hw bus key from a key code
param base PUF peripheral base address param keyCode Word aligned address of the input key code. param keyCodeSize Size of the keyCode buffer in bytes. Shall be PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(keySize). param keySlot key slot to output on hw bus. Parameter is ignored on devices with less than two key slots. param keyMask key masking value. Shall be random for each POR/reset. Value does not have to be cryptographicaly secure. return Status of get key operation.
◆ PUF_GetKey()
status_t PUF_GetKey ( PUF_Type base,
size_t  keyCodeSize,
uint8_t *  key,
size_t  keySize
The digital fingerprint generated during the Start operation and the KC generated during a Set Key operation (Set intrinsic key or Set user key) are used to retrieve a stored key. This operation needs to be done every time a key is needed. This function accepts only Key Codes created for PUF index registers kPUF_KeyIndex_01 to kPUF_KeyIndex_15.
Parameters
[out]keyWord aligned address of output key.
keySizeSize of the output key in bytes.
Returns
brief Reconstruct key from a key code
param base PUF peripheral base address param keyCode Word aligned address of the input key code. param keyCodeSize Size of the keyCode buffer in bytes. Shall be PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(keySize). param[out] key Word aligned address of output key. param keySize Size of the output key in bytes. return Status of get key operation.
◆ PUF_Init()
status_t PUF_Init ( PUF_Type base,
puf_config_t conf
Initialize PUF.
This function enables power to PUF block and waits until the block initializes.
Parameters
Returns
Status of the init operation
brief Initialize PUF
param base PUF peripheral base address param conf PUF configuration structure return Status of the init operation
◆ PUF_IsGetKeyAllowed()
bool PUF_IsGetKeyAllowed ( PUF_Type base)
This function returns true if get key operation is allowed.
Parameters
Returns
brief Checks if Get Key operation is allowed.
param base PUF peripheral base address return true if get key operation is allowed
◆ PUF_PowerCycle()
status_t PUF_PowerCycle ( PUF_Type base,
puf_config_t conf
Powercycle PUF.
This function make powercycle.
Parameters
Returns
Status of the powercycle operation.
brief Powercycle PUF
This function make powercycle of PUF.
param base PUF peripheral base address param conf PUF configuration structure return Status of the powercycle operation.
◆ PUF_SetIntrinsicKey()
status_t PUF_SetIntrinsicKey ( PUF_Type base,
size_t  keySize,
uint8_t *  keyCode,
size_t  keyCodeSize
Set intrinsic key.
The digital fingerprint generated during the Enroll/Start operations is used to generate a Key Code (KC) that defines a unique intrinsic key. This KC is returned to be stored in an NVM or a file. This operation needs to be done only once for each intrinsic key. Each time a Set Intrinsic Key operation is executed a new unique key is generated.
Parameters
keyIndexPUF key index register
keySizeSize of the intrinsic key to generate in bytes.
[out]keyCodeWord aligned address of the resulting key code.
Returns
Status of set intrinsic key operation.
brief Set intrinsic key
param base PUF peripheral base address param keyIndex PUF key index register param keySize Size of the intrinsic key to generate in bytes. param[out] keyCode Word aligned address of the resulting key code. param keyCodeSize Size of the keyCode buffer in bytes. Shall be PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(keySize). return Status of set intrinsic key operation.
◆ PUF_SetUserKey()
status_t PUF_SetUserKey ( PUF_Type base,
const uint8_t *  userKey,
size_t  userKeySize,
uint8_t *  keyCode,
size_t  keyCodeSize
Set user key.
The digital fingerprint generated during the Enroll/Start operations and a user key (UK) provided as input are used to generate a Key Code (KC). This KC is sent returned to be stored in an NVM or a file. This operation needs to be done only once for each user key.
Parameters
userKeyWord aligned address of input user key.
userKeySizeSize of the input user key in bytes.
keyCodeSizeSize of the keyCode buffer in bytes. Shall be PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(userKeySize).
Returns
Status of set user key operation.
brief Set user key
param base PUF peripheral base address param keyIndex PUF key index register param userKey Word aligned address of input user key. param userKeySize Size of the input user key in bytes. param[out] keyCode Word aligned address of the resulting key code. param keyCodeSize Size of the keyCode buffer in bytes. Shall be PUF_GET_KEY_CODE_SIZE_FOR_KEY_SIZE(userKeySize). return Status of set user key operation.
◆ PUF_Start()
status_t PUF_Start ( PUF_Type base,
const uint8_t *  activationCode,
Start PUF.
The Activation Code generated during the Enroll operation is used to reconstruct the digital fingerprint. This needs to be done after every power-up and reset.
Parameters
activationCodeWord aligned address of the input activation code.
Returns
Status of start operation.
brief Start PUF
param base PUF peripheral base address param activationCode Word aligned address of the input activation code. param activationCodeSize Size of the activationCode buffer in bytes. Shall be 1192 bytes. return Status of start operation.
◆ PUF_Zeroize()
status_t PUF_Zeroize ( PUF_Type base)
Zeroize PUF.
This function clears all PUF internal logic and puts the PUF to error state.
Parameters
Returns
Status of the zeroize operation.
brief Zeroize PUF
param base PUF peripheral base address return Status of the zeroize operation.
