RTEMS 6.1
Data Structures | Variables
Lpspi_edma_driver
struct  _lpspi_master_edma_handle
 LPSPI master eDMA transfer handle structure used for transactional API. More...
struct  _lpspi_slave_edma_handle
 LPSPI slave eDMA transfer handle structure used for transactional API. More...
volatile bool _lpspi_master_edma_handle::isPcsContinuous
volatile bool _lpspi_master_edma_handle::isByteSwap
volatile uint8_t _lpspi_master_edma_handle::fifoSize
volatile uint8_t _lpspi_master_edma_handle::rxWatermark
volatile uint8_t _lpspi_master_edma_handle::bytesEachWrite
volatile uint8_t _lpspi_master_edma_handle::bytesEachRead
volatile uint8_t _lpspi_master_edma_handle::bytesLastRead
volatile bool _lpspi_master_edma_handle::isThereExtraRxBytes
uint8_t *volatile _lpspi_master_edma_handle::txData
uint8_t *volatile _lpspi_master_edma_handle::rxData
volatile size_t _lpspi_master_edma_handle::txRemainingByteCount
volatile size_t _lpspi_master_edma_handle::rxRemainingByteCount
volatile uint32_t _lpspi_master_edma_handle::writeRegRemainingTimes
volatile uint32_t _lpspi_master_edma_handle::readRegRemainingTimes
uint32_t _lpspi_master_edma_handle::totalByteCount
uint32_t _lpspi_master_edma_handle::txBuffIfNull
uint32_t _lpspi_master_edma_handle::rxBuffIfNull
uint32_t _lpspi_master_edma_handle::transmitCommand
volatile uint8_t _lpspi_master_edma_handle::state
uint8_t _lpspi_master_edma_handle::nbytes
lpspi_master_edma_transfer_callback_t _lpspi_master_edma_handle::callback
void * _lpspi_master_edma_handle::userData
edma_handle_t_lpspi_master_edma_handle::edmaRxRegToRxDataHandle
edma_handle_t_lpspi_master_edma_handle::edmaTxDataToTxRegHandle
edma_tcd_t _lpspi_master_edma_handle::lpspiSoftwareTCD [3]
volatile bool _lpspi_slave_edma_handle::isByteSwap
volatile uint8_t _lpspi_slave_edma_handle::fifoSize
volatile uint8_t _lpspi_slave_edma_handle::rxWatermark
volatile uint8_t _lpspi_slave_edma_handle::bytesEachWrite
volatile uint8_t _lpspi_slave_edma_handle::bytesEachRead
volatile uint8_t _lpspi_slave_edma_handle::bytesLastRead
volatile bool _lpspi_slave_edma_handle::isThereExtraRxBytes
uint8_t _lpspi_slave_edma_handle::nbytes
uint8_t *volatile _lpspi_slave_edma_handle::txData
uint8_t *volatile _lpspi_slave_edma_handle::rxData
volatile size_t _lpspi_slave_edma_handle::txRemainingByteCount
volatile size_t _lpspi_slave_edma_handle::rxRemainingByteCount
volatile uint32_t _lpspi_slave_edma_handle::writeRegRemainingTimes
volatile uint32_t _lpspi_slave_edma_handle::readRegRemainingTimes
uint32_t _lpspi_slave_edma_handle::totalByteCount
uint32_t _lpspi_slave_edma_handle::txBuffIfNull
uint32_t _lpspi_slave_edma_handle::rxBuffIfNull
volatile uint8_t _lpspi_slave_edma_handle::state
uint32_t _lpspi_slave_edma_handle::errorCount
lpspi_slave_edma_transfer_callback_t _lpspi_slave_edma_handle::callback
void * _lpspi_slave_edma_handle::userData
edma_handle_t_lpspi_slave_edma_handle::edmaRxRegToRxDataHandle
edma_handle_t_lpspi_slave_edma_handle::edmaTxDataToTxRegHandle
edma_tcd_t _lpspi_slave_edma_handle::lpspiSoftwareTCD [2]
Driver version
typedef struct _lpspi_master_edma_handle lpspi_master_edma_handle_t
 Forward declaration of the _lpspi_master_edma_handle typedefs.
typedef struct _lpspi_slave_edma_handle lpspi_slave_edma_handle_t
 Forward declaration of the _lpspi_slave_edma_handle typedefs.
typedef void(* lpspi_master_edma_transfer_callback_t) (LPSPI_Type *base, lpspi_master_edma_handle_t *handle, status_t status, void *userData)
 Completion callback function pointer type.
typedef void(* lpspi_slave_edma_transfer_callback_t) (LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, status_t status, void *userData)
void LPSPI_MasterTransferCreateHandleEDMA (LPSPI_Type *base, lpspi_master_edma_handle_t *handle, lpspi_master_edma_transfer_callback_t callback, void *userData, edma_handle_t *edmaRxRegToRxDataHandle, edma_handle_t *edmaTxDataToTxRegHandle)
 Initializes the LPSPI master eDMA handle.
status_t LPSPI_MasterTransferEDMA (LPSPI_Type *base, lpspi_master_edma_handle_t *handle, lpspi_transfer_t *transfer)
 LPSPI master transfer data using eDMA.
void LPSPI_MasterTransferAbortEDMA (LPSPI_Type *base, lpspi_master_edma_handle_t *handle)
 LPSPI master aborts a transfer which is using eDMA.
status_t LPSPI_MasterTransferGetCountEDMA (LPSPI_Type *base, lpspi_master_edma_handle_t *handle, size_t *count)
 Gets the master eDMA transfer remaining bytes.
void LPSPI_SlaveTransferCreateHandleEDMA (LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, lpspi_slave_edma_transfer_callback_t callback, void *userData, edma_handle_t *edmaRxRegToRxDataHandle, edma_handle_t *edmaTxDataToTxRegHandle)
 Initializes the LPSPI slave eDMA handle.
status_t LPSPI_SlaveTransferEDMA (LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, lpspi_transfer_t *transfer)
 LPSPI slave transfers data using eDMA.
void LPSPI_SlaveTransferAbortEDMA (LPSPI_Type *base, lpspi_slave_edma_handle_t *handle)
 LPSPI slave aborts a transfer which is using eDMA.
status_t LPSPI_SlaveTransferGetCountEDMA (LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, size_t *count)
 Gets the slave eDMA transfer remaining bytes.
#define FSL_LPSPI_EDMA_DRIVER_VERSION   (MAKE_VERSION(2, 3, 1))
 LPSPI EDMA driver version.
Typedef Documentation
◆ lpspi_master_edma_transfer_callback_t
Parameters
baseLPSPI peripheral base address.
handlePointer to the handle for the LPSPI master.
statusSuccess or error code describing whether the transfer completed.
userDataArbitrary pointer-dataSized value passed from the application.
◆ lpspi_slave_edma_transfer_callback_t
Parameters
handlePointer to the handle for the LPSPI slave.
◆ LPSPI_MasterTransferAbortEDMA()
void LPSPI_MasterTransferAbortEDMA ( LPSPI_Type base,
lpspi_master_edma_handle_t handle
This function aborts a transfer which is using eDMA.
Parameters
handlepointer to lpspi_master_edma_handle_t structure which stores the transfer state.
brief LPSPI master aborts a transfer which is using eDMA.
param base LPSPI peripheral base address. param handle pointer to lpspi_master_edma_handle_t structure which stores the transfer state.
◆ LPSPI_MasterTransferCreateHandleEDMA()
void LPSPI_MasterTransferCreateHandleEDMA ( LPSPI_Type base,
lpspi_master_edma_handle_t handle,
void *  userData,
edma_handle_t edmaRxRegToRxDataHandle,
edma_handle_t edmaTxDataToTxRegHandle
This function initializes the LPSPI eDMA handle which can be used for other LPSPI transactional APIs. Usually, for a specified LPSPI instance, call this API once to get the initialized handle.
Note that the LPSPI eDMA has a separated (Rx and Tx as two sources) or shared (Rx and Tx are the same source) DMA request source. (1) For a separated DMA request source, enable and set the Rx DMAMUX source for edmaRxRegToRxDataHandle and Tx DMAMUX source for edmaTxDataToTxRegHandle. (2) For a shared DMA request source, enable and set the Rx/Tx DMAMUX source for edmaRxRegToRxDataHandle.
Parameters
handleLPSPI handle pointer to lpspi_master_edma_handle_t.
callbackLPSPI callback.
userDatacallback function parameter.
edmaRxRegToRxDataHandleedmaRxRegToRxDataHandle pointer to edma_handle_t.
edmaTxDataToTxRegHandleedmaTxDataToTxRegHandle pointer to edma_handle_t.
brief Initializes the LPSPI master eDMA handle.
Note that the LPSPI eDMA has a separated (Rx and Rx as two sources) or shared (Rx and Tx are the same source) DMA request source. (1) For a separated DMA request source, enable and set the Rx DMAMUX source for edmaRxRegToRxDataHandle and Tx DMAMUX source for edmaIntermediaryToTxRegHandle. (2) For a shared DMA request source, enable and set the Rx/Rx DMAMUX source for edmaRxRegToRxDataHandle.
param base LPSPI peripheral base address. param handle LPSPI handle pointer to lpspi_master_edma_handle_t. param callback LPSPI callback. param userData callback function parameter. param edmaRxRegToRxDataHandle edmaRxRegToRxDataHandle pointer to edma_handle_t. param edmaTxDataToTxRegHandle edmaTxDataToTxRegHandle pointer to edma_handle_t.
◆ LPSPI_MasterTransferEDMA()
status_t LPSPI_MasterTransferEDMA ( LPSPI_Type base,
lpspi_transfer_t transfer
This function transfers data using eDMA. This is a non-blocking function, which returns right away. When all data is transferred, the callback function is called.
Note: The transfer data size should be an integer multiple of bytesPerFrame if bytesPerFrame is less than or equal to 4. For bytesPerFrame greater than 4: The transfer data size should be equal to bytesPerFrame if the bytesPerFrame is not an integer multiple of 4. Otherwise, the transfer data size can be an integer multiple of bytesPerFrame.
Parameters
transferpointer to lpspi_transfer_t structure.
Returns
status of status_t.
brief LPSPI master transfer data using eDMA.
param base LPSPI peripheral base address. param handle pointer to lpspi_master_edma_handle_t structure which stores the transfer state. param transfer pointer to lpspi_transfer_t structure. return status of status_t.
◆ LPSPI_MasterTransferGetCountEDMA()
status_t LPSPI_MasterTransferGetCountEDMA ( LPSPI_Type base,
size_t *  count
This function gets the master eDMA transfer remaining bytes.
Parameters
countNumber of bytes transferred so far by the EDMA transaction.
Returns
status of status_t.
brief Gets the master eDMA transfer remaining bytes.
param base LPSPI peripheral base address. param handle pointer to lpspi_master_edma_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the EDMA transaction. return status of status_t.
◆ LPSPI_SlaveTransferAbortEDMA()
void LPSPI_SlaveTransferAbortEDMA ( LPSPI_Type base,
lpspi_slave_edma_handle_t handle
Parameters
handlepointer to lpspi_slave_edma_handle_t structure which stores the transfer state.
brief LPSPI slave aborts a transfer which is using eDMA.
param base LPSPI peripheral base address. param handle pointer to lpspi_slave_edma_handle_t structure which stores the transfer state.
◆ LPSPI_SlaveTransferCreateHandleEDMA()
void LPSPI_SlaveTransferCreateHandleEDMA ( LPSPI_Type base,
lpspi_slave_edma_handle_t handle,
void *  userData,
Note that LPSPI eDMA has a separated (Rx and Tx as two sources) or shared (Rx and Tx as the same source) DMA request source.
(1) For a separated DMA request source, enable and set the Rx DMAMUX source for edmaRxRegToRxDataHandle and Tx DMAMUX source for edmaTxDataToTxRegHandle. (2) For a shared DMA request source, enable and set the Rx/Rx DMAMUX source for edmaRxRegToRxDataHandle .
Parameters
handleLPSPI handle pointer to lpspi_slave_edma_handle_t.
brief Initializes the LPSPI slave eDMA handle.
param base LPSPI peripheral base address. param handle LPSPI handle pointer to lpspi_slave_edma_handle_t. param callback LPSPI callback. param userData callback function parameter. param edmaRxRegToRxDataHandle edmaRxRegToRxDataHandle pointer to edma_handle_t. param edmaTxDataToTxRegHandle edmaTxDataToTxRegHandle pointer to edma_handle_t.
◆ LPSPI_SlaveTransferEDMA()
status_t LPSPI_SlaveTransferEDMA ( LPSPI_Type base,
This function transfers data using eDMA. This is a non-blocking function, which return right away. When all data is transferred, the callback function is called.
Parameters
Returns
status of status_t.
brief LPSPI slave transfers data using eDMA.
param base LPSPI peripheral base address. param handle pointer to lpspi_slave_edma_handle_t structure which stores the transfer state. param transfer pointer to lpspi_transfer_t structure. return status of status_t.
◆ LPSPI_SlaveTransferGetCountEDMA()
status_t LPSPI_SlaveTransferGetCountEDMA ( LPSPI_Type base,
size_t *  count
This function gets the slave eDMA transfer remaining bytes.
Parameters
countNumber of bytes transferred so far by the eDMA transaction.
Returns
status of status_t.
brief Gets the slave eDMA transfer remaining bytes.
param base LPSPI peripheral base address. param handle pointer to lpspi_slave_edma_handle_t structure which stores the transfer state. param count Number of bytes transferred so far by the eDMA transaction. return status of status_t.
Variable Documentation
◆ bytesEachRead [1/2]
Bytes for each read RDR.
◆ bytesEachRead [2/2]
◆ bytesEachWrite [1/2]
Bytes for each write TDR.
◆ bytesEachWrite [2/2]
◆ bytesLastRead [1/2]
Bytes for last read RDR.
◆ bytesLastRead [2/2]
◆ callback [1/2]
Completion callback.
◆ callback [2/2]
◆ edmaRxRegToRxDataHandle [1/2]
edma_handle_t* _lpspi_master_edma_handle::edmaRxRegToRxDataHandle
edma_handle_t handle point used for RxReg to RxData buff
◆ edmaRxRegToRxDataHandle [2/2]
edma_handle_t* _lpspi_slave_edma_handle::edmaRxRegToRxDataHandle
◆ edmaTxDataToTxRegHandle [1/2]
edma_handle_t* _lpspi_master_edma_handle::edmaTxDataToTxRegHandle
edma_handle_t handle point used for TxData to TxReg buff
◆ edmaTxDataToTxRegHandle [2/2]
edma_handle_t* _lpspi_slave_edma_handle::edmaTxDataToTxRegHandle
◆ errorCount
Error count for slave transfer.
◆ fifoSize [1/2]
FIFO dataSize.
◆ fifoSize [2/2]
FIFO dataSize.
◆ isByteSwap [1/2]
A flag that whether should byte swap.
◆ isByteSwap [2/2]
◆ isPcsContinuous
Is PCS continuous in transfer.
◆ isThereExtraRxBytes [1/2]
Is there extra RX byte.
◆ isThereExtraRxBytes [2/2]
◆ lpspiSoftwareTCD [1/2]
edma_tcd_t _lpspi_slave_edma_handle::lpspiSoftwareTCD[2]
SoftwareTCD, internal used
◆ lpspiSoftwareTCD [2/2]
edma_tcd_t _lpspi_master_edma_handle::lpspiSoftwareTCD[3]
◆ nbytes [1/2]
eDMA minor byte transfer count initially configured.
◆ nbytes [2/2]
◆ readRegRemainingTimes [1/2]
Read RDR register remaining times.
◆ readRegRemainingTimes [2/2]
◆ rxBuffIfNull [1/2]
Used if there is not rxData for DMA purpose.
◆ rxBuffIfNull [2/2]
◆ rxData [1/2]
uint8_t* volatile _lpspi_master_edma_handle::rxData
Receive buffer.
◆ rxData [2/2]
uint8_t* volatile _lpspi_slave_edma_handle::rxData
Receive buffer.
◆ rxRemainingByteCount [1/2]
Number of bytes remaining to receive.
◆ rxRemainingByteCount [2/2]
◆ rxWatermark [1/2]
Rx watermark.
◆ rxWatermark [2/2]
Rx watermark.
◆ state [1/2]
LPSPI transfer state , _lpspi_transfer_state.
◆ state [2/2]
LPSPI transfer state.
◆ totalByteCount [1/2]
Number of transfer bytes
◆ totalByteCount [2/2]
◆ transmitCommand
Used to write TCR for DMA purpose.
◆ txBuffIfNull [1/2]
Used if there is not txData for DMA purpose.
◆ txBuffIfNull [2/2]
◆ txData [1/2]
uint8_t* volatile _lpspi_master_edma_handle::txData
Send buffer.
◆ txData [2/2]
uint8_t* volatile _lpspi_slave_edma_handle::txData
Send buffer.
◆ txRemainingByteCount [1/2]
Number of bytes remaining to send.
◆ txRemainingByteCount [2/2]
◆ userData [1/2]
void* _lpspi_master_edma_handle::userData
Callback user data.
◆ userData [2/2]
void* _lpspi_slave_edma_handle::userData
Callback user data.
◆ writeRegRemainingTimes [1/2]
Write TDR register remaining times.
◆ writeRegRemainingTimes [2/2]
