RTEMS 6.1
| #define | ctz(u) |
| Counts the trailing zero bits of the given value considered as a 32-bit integer. | |
Interrupt Service Routine definition | |
| #define | Enable_global_interrupt() cpu_irq_enable() |
| #define | Disable_global_interrupt() cpu_irq_disable() |
| #define | Is_global_interrupt_enabled() cpu_irq_is_enabled() |
| #define ctz | ( | u | ) |
| u | Value of which to count the trailing zero bits. |
