RTEMS 6.1
Ieer
Driver version
enum  _iee_apc_region {
  kIEE_APC_Region0 = 0U , kIEE_APC_Region1 = 1U , kIEE_APC_Region2 = 2U , kIEE_APC_Region3 = 3U ,
  kIEE_APC_Region4 = 4U , kIEE_APC_Region5 = 5U , kIEE_APC_Region6 = 6U , kIEE_APC_Region7 = 7U
 APC IEE regions. More...
enum  _apc_iee_domain { kIEE_APC_Domain0 = 0U , kIEE_APC_Domain1 = 1U }
 APC IEE domains. More...
typedef enum _iee_apc_region iee_apc_region_t
 APC IEE regions.
typedef enum _apc_iee_domain iee_apc_domain_t
 APC IEE domains.
void IEE_APC_GlobalEnable (IEE_APC_Type *base)
 Enable the APC IEE Region setting.
void IEE_APC_GlobalDisable (IEE_APC_Type *base)
 Disables the APC IEE Region setting.
status_t IEE_APC_SetRegionConfig (IEE_APC_Type *base, iee_apc_region_t region, uint32_t startAddr, uint32_t endAddr)
 Sets the APC IEE Memory Region Descriptors.
status_t IEE_APC_LockRegionConfig (IEE_APC_Type *base, iee_apc_region_t region, iee_apc_domain_t domain)
 Lock the LPSR GPR and APC IEE configuration.
void IEE_APC_RegionEnable (IEE_APC_Type *base, iee_apc_region_t region)
 Enable the IEE encryption/decryption and can lock this setting.
#define FSL_IEE_APC_DRIVER_VERSION   (MAKE_VERSION(2, 0, 1))
 IEE_APC driver version. Version 2.0.1.
◆ FSL_IEE_APC_DRIVER_VERSION
Current version: 2.0.1
Change log:
  • Version 2.0.0
    • Initial version
  • Version 2.0.1
    • Fixed MISRA issues.
◆ _apc_iee_domain
APC IEE domains.
kIEE_APC_Domain0
APC IEE region 0
kIEE_APC_Domain1
APC IEE region 1
◆ _iee_apc_region
APC IEE regions.
kIEE_APC_Region0
APC IEE region 0
kIEE_APC_Region1
APC IEE region 1
kIEE_APC_Region2
APC IEE region 2
kIEE_APC_Region3
APC IEE region 3
kIEE_APC_Region4
APC IEE region 4
kIEE_APC_Region5
APC IEE region 5
kIEE_APC_Region6
APC IEE region 6
kIEE_APC_Region7
APC IEE region 7
◆ IEE_APC_GlobalDisable()
void IEE_APC_GlobalDisable ( IEE_APC_Type base)
This function disables IOMUXC LPSR GPR and APC IEE for setting the region.
Parameters
baseAPC IEE peripheral address.
brief Disables the APC IEE Region setting.
param base APC IEE peripheral address.
◆ IEE_APC_GlobalEnable()
void IEE_APC_GlobalEnable ( IEE_APC_Type base)
This function enables IOMUXC LPSR GPR and APC IEE for setting the region.
Parameters
brief Enable the APC IEE Region setting.
◆ IEE_APC_LockRegionConfig()
status_t IEE_APC_LockRegionConfig ( IEE_APC_Type base,
This function locks writting to IOMUXC LPSR GPR and APC IEE encryption region setting registers. Only system reset can clear the LPSR GPR and APC IEE-RDC_D0/1 Lock bit
Parameters
regionSelection of the APC IEE region to be locked.
domain
brief Lock the LPSR GPR and APC IEE configuration.
param base APC IEE peripheral address. param region Selection of the APC IEE region to be locked.
◆ IEE_APC_RegionEnable()
void IEE_APC_RegionEnable ( IEE_APC_Type base,
This function enables encryption/decryption by writting to IOMUXC LPSR GPR.
Parameters
regionSelection of the APC IEE region to be enabled.
brief Enable the IEE encryption/decryption for specific region.
param base APC IEE peripheral address. param region Selection of the APC IEE region to be enabled.
◆ IEE_APC_SetRegionConfig()
status_t IEE_APC_SetRegionConfig ( IEE_APC_Type base,
uint32_t  startAddr,
uint32_t  endAddr
This function configures APC IEE Memory Region Descriptor according to region configuration structure.
Parameters
regionSelection of the APC IEE region to be configured.
startAddrStart encryption adress for the selected APC IEE region.
endAddrEnd encryption adress for the selected APC IEE region.
brief Sets the APC IEE Memory Region setting.
This function configure IOMUXC LPSR GPR and APC IEE for the encryption region.
param base APC IEE peripheral address. param region Selection of the APC IEE region to be configured. param startAddr Start encryption adress for the selected APC IEE region. param endAddr End encryption adress for the selected APC IEE region.
