RTEMS 6.1
void HSMCI_Enable (Hsmci *pRMci)
 Enable Multi-Media Interface.
void HSMCI_Disable (Hsmci *pRMci)
 Disable Multi-Media Interface.
void HSMCI_Reset (Hsmci *pRMci, uint8_t bBackup)
 Reset (& Disable) Multi-Media Interface.
void HSMCI_Select (Hsmci *pRMci, uint8_t bSlot, uint8_t bBusWidth)
 Select slot.
void HSMCI_SetSlot (Hsmci *pRMci, uint8_t bSlot)
 Set slot.
void HSMCI_SetBusWidth (Hsmci *pRMci, uint8_t bBusWidth)
 Set bus width of MCI.
uint8_t HSMCI_GetBusWidth (Hsmci *pRMci)
 Return bus width setting.
void HSMCI_ConfigureMode (Hsmci *pRMci, uint32_t dwMode)
 Configures a MCI peripheral as specified.
uint32_t HSMCI_GetMode (Hsmci *pRMci)
 Return mode register.
void HSMCI_ProofEnable (Hsmci *pRMci, uint8_t bRdProof, uint8_t bWrProof)
 Enable/Disable R/W proof.
void HSMCI_PadvCtl (Hsmci *pRMci, uint8_t bPadv)
 Padding value setting.
void HSMCI_FByteEnable (Hsmci *pRMci, uint8_t bFByteEn)
 Force byte transfer enable/disable.
uint8_t HSMCI_IsFByteEnabled (Hsmci *pRMci)
 Check if Force Byte mode enabled.
void HSMCI_DivCtrl (Hsmci *pRMci, uint32_t bClkDiv, uint8_t bPwsDiv)
 Set Clock Divider & Power save divider for MCI.
void HSMCI_EnableIt (Hsmci *pRMci, uint32_t dwSources)
 Enables one or more interrupt sources of MCI peripheral.
void HSMCI_DisableIt (Hsmci *pRMci, uint32_t dwSources)
 Disable one or more interrupt sources of MCI peripheral.
uint32_t HSMCI_GetItMask (Hsmci *pRMci)
 Return the interrupt mask register.
void HSMCI_ConfigureTransfer (Hsmci *pRMci, uint16_t wBlkLen, uint16_t wCnt)
 Set block len & count for transfer.
void HSMCI_SetBlockLen (Hsmci *pRMci, uint16_t wBlkSize)
 Set block length.
void HSMCI_SetBlockCount (Hsmci *pRMci, uint16_t wBlkCnt)
 Set block (byte) count.
void HSMCI_ConfigureCompletionTO (Hsmci *pRMci, uint32_t dwConfigure)
 Configure the Completion Signal Timeout.
void HSMCI_ConfigureDataTO (Hsmci *pRMci, uint32_t dwConfigure)
 Configure the Data Timeout.
void HSMCI_SendCmd (Hsmci *pRMci, uint32_t dwCmd, uint32_t dwArg)
 Send command.
uint32_t HSMCI_GetResponse (Hsmci *pRMci)
 Return the response register.
uint32_t HSMCI_Read (Hsmci *pRMci)
 Return the receive data register.
void HSMCI_ReadFifo (Hsmci *pRMci, uint8_t *pdwData, uint32_t dwSize)
 Read from FIFO.
void HSMCI_Write (Hsmci *pRMci, uint32_t dwData)
 Sends data through MCI peripheral.
void HSMCI_WriteFifo (Hsmci *pRMci, uint8_t *pdwData, uint32_t dwSize)
 Write to FIFO.
uint32_t HSMCI_GetStatus (Hsmci *pRMci)
 Return the status register.
void HSMCI_ConfigureDma (Hsmci *pRMci, uint32_t dwConfigure)
 Configure the HSMCI DMA.
void HSMCI_EnableDma (Hsmci *pRMci, uint8_t bEnable)
 Enable the HSMCI DMA.
void HSMCI_Configure (Hsmci *pRMci, uint32_t dwConfigure)
 Configure the HSMCI.
void HSMCI_HsEnable (Hsmci *pRMci, uint8_t bHsEnable)
 Enable/Disable High-Speed mode for MCI.
uint8_t HSMCI_IsHsEnabled (Hsmci *pRMci)
 Check if High-speed mode is enabled on MCI.
void HSMCI_ConfigureWP (Hsmci *pRMci, uint32_t dwConfigure)
 Configure the Write Protection Mode.
uint32_t HSMCI_GetWPStatus (Hsmci *pRMci)
 Return the write protect status register.
void HSMCI_BusWidthCtl (Hsmci *pRMci, uint8_t bBusWidth)
void HSMCI_SlotCtl (Hsmci *pRMci, uint8_t bSlot)
uint8_t HSMCI_GetSlot (Hsmci *pRMci)
◆ HSMCI_Configure()
void HSMCI_Configure ( Hsmci pRMci,
Parameters
pRMciPointer to an Hsmci instance.
dwConfigureConfigure value.
◆ HSMCI_ConfigureCompletionTO()
void HSMCI_ConfigureCompletionTO ( Hsmci pRMci,
Parameters
dwConfigureCompletion Signal Timeout configure.
◆ HSMCI_ConfigureDataTO()
void HSMCI_ConfigureDataTO ( Hsmci pRMci,
Parameters
dwConfigureData Timeout configure.
◆ HSMCI_ConfigureDma()
void HSMCI_ConfigureDma ( Hsmci pRMci,
Parameters
◆ HSMCI_ConfigureMode()
void HSMCI_ConfigureMode ( Hsmci pRMci,
uint32_t  dwMode
Parameters
pRMciPointer to an MCI instance.
dwModeValue of the MCI Mode register.
◆ HSMCI_ConfigureTransfer()
void HSMCI_ConfigureTransfer ( Hsmci pRMci,
uint16_t  wBlkLen,
uint16_t  wCnt
Parameters
wBlkLenBlock size.
wCntBlock(byte) count.
◆ HSMCI_ConfigureWP()
void HSMCI_ConfigureWP ( Hsmci pRMci,
Parameters
dwConfigureWP mode configure value.
◆ HSMCI_Disable()
void HSMCI_Disable ( Hsmci pRMci)
Parameters
pRMciPointer to a Hsmci instance
◆ HSMCI_DisableIt()
void HSMCI_DisableIt ( Hsmci pRMci,
uint32_t  dwSources
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ HSMCI_DivCtrl()
void HSMCI_DivCtrl ( Hsmci pRMci,
uint32_t  bClkDiv,
uint8_t  bPwsDiv
Parameters
bClkDivClock Divider value (0 ~ 255).
bPwsDivPower Saving Divider (1 ~ 7).
◆ HSMCI_Enable()
void HSMCI_Enable ( Hsmci pRMci)
Parameters
◆ HSMCI_EnableDma()
void HSMCI_EnableDma ( Hsmci pRMci,
uint8_t  bEnable
Parameters
bEnable1 to enable, 0 to disable.
◆ HSMCI_EnableIt()
void HSMCI_EnableIt ( Hsmci pRMci,
uint32_t  dwSources
Parameters
◆ HSMCI_FByteEnable()
void HSMCI_FByteEnable ( Hsmci pRMci,
uint8_t  bFByteEn
Parameters
bFByteEnFBYTE enable/disable.
◆ HSMCI_GetBusWidth()
uint8_t HSMCI_GetBusWidth ( Hsmci pRMci)
Parameters
Returns
1, 4 or 8.
◆ HSMCI_GetItMask()
uint32_t HSMCI_GetItMask ( Hsmci pRMci)
Parameters
Returns
MCI interrupt mask register.
◆ HSMCI_GetMode()
uint32_t HSMCI_GetMode ( Hsmci pRMci)
Parameters
◆ HSMCI_GetResponse()
uint32_t HSMCI_GetResponse ( Hsmci pRMci)
Parameters
Returns
MCI response register.
◆ HSMCI_GetStatus()
uint32_t HSMCI_GetStatus ( Hsmci pRMci)
Parameters
Returns
MCI status register.
◆ HSMCI_GetWPStatus()
uint32_t HSMCI_GetWPStatus ( Hsmci pRMci)
Parameters
Returns
MCI write protect status register.
◆ HSMCI_HsEnable()
void HSMCI_HsEnable ( Hsmci pRMci,
uint8_t  bHsEnable
Parameters
bHsEnableEnable/Disable high-speed.
◆ HSMCI_IsFByteEnabled()
uint8_t HSMCI_IsFByteEnabled ( Hsmci pRMci)
Parameters
Returns
1 if _FBYTE is enabled.
◆ HSMCI_IsHsEnabled()
uint8_t HSMCI_IsHsEnabled ( Hsmci pRMci)
Parameters
Returns
1
◆ HSMCI_PadvCtl()
void HSMCI_PadvCtl ( Hsmci pRMci,
uint8_t  bPadv
Parameters
bPadvEnPadding value 0xFF/0x00.
◆ HSMCI_ProofEnable()
void HSMCI_ProofEnable ( Hsmci pRMci,
uint8_t  bRdProof,
uint8_t  bWrProof
Parameters
bRdProofRead proof enable/disable.
bWrProofWrite proof enable/disable.
◆ HSMCI_Read()
uint32_t HSMCI_Read ( Hsmci pRMci)
Parameters
Returns
MCI receive data register.
◆ HSMCI_ReadFifo()
void HSMCI_ReadFifo ( Hsmci pRMci,
uint8_t *  pdwData,
uint32_t  dwSize
Read from FIFO.
Parameters
pdwDataPointer to data buffer.
dwSizeSize of data buffer (in DWord).
◆ HSMCI_Reset()
void HSMCI_Reset ( Hsmci pRMci,
uint8_t  bBackup
Parameters
mciPointer to a Hsmci instance
bBackupBackup registers values to keep previous settings, including _MR, _SDCR, _DTOR, _CSTOR, _DMA and _CFG.
◆ HSMCI_Select()
void HSMCI_Select ( Hsmci pRMci,
uint8_t  bSlot,
uint8_t  bBusWidth
Select slot.
Parameters
bSlotSlot ID (0~3 for A~D).
◆ HSMCI_SendCmd()
void HSMCI_SendCmd ( Hsmci pRMci,
uint32_t  dwCmd,
uint32_t  dwArg
Send command.
Parameters
dwCmdCommand register value.
dwArgArgument register value.
◆ HSMCI_SetBlockCount()
void HSMCI_SetBlockCount ( Hsmci pRMci,
uint16_t  wBlkCnt
Parameters
wBlkCntBlock(byte) count.
◆ HSMCI_SetBlockLen()
void HSMCI_SetBlockLen ( Hsmci pRMci,
uint16_t  wBlkSize
Set block length.
Count is reset to 0.
Parameters
wBlkSizeBlock size.
◆ HSMCI_SetBusWidth()
void HSMCI_SetBusWidth ( Hsmci pRMci,
uint8_t  bBusWidth
Parameters
bBusWidth1,4 or 8 (bits).
◆ HSMCI_SetSlot()
void HSMCI_SetSlot ( Hsmci pRMci,
uint8_t  bSlot
Set slot.
Parameters
◆ HSMCI_Write()
void HSMCI_Write ( Hsmci pRMci,
uint32_t  dwData
Parameters
◆ HSMCI_WriteFifo()
void HSMCI_WriteFifo ( Hsmci pRMci,
uint8_t *  pdwData,
uint32_t  dwSize
Write to FIFO.
Parameters
dwSizeSize of data buffer (In DWord).
