RTEMS 6.1
Data Structures | Enumerator | Variables
Flexspi_edma
struct  _flexspi_edma_handle
 FLEXSPI DMA transfer handle, users should not touch the content of the handle. More...
edma_handle_t_flexspi_edma_handle::txDmaHandle
edma_handle_t_flexspi_edma_handle::rxDmaHandle
size_t _flexspi_edma_handle::transferSize
flexspi_edma_transfer_nsize_t _flexspi_edma_handle::nsize
uint8_t _flexspi_edma_handle::nbytes
uint8_t _flexspi_edma_handle::count
uint32_t _flexspi_edma_handle::state
flexspi_edma_callback_t _flexspi_edma_handle::completionCallback
void * _flexspi_edma_handle::userData
Driver version
enum  _flexspi_edma_ntransfer_size {
  kFLEXPSI_EDMAnSize1Bytes = 0x1U , kFLEXPSI_EDMAnSize2Bytes = 0x2U , kFLEXPSI_EDMAnSize4Bytes = 0x4U , kFLEXPSI_EDMAnSize8Bytes = 0x8U ,
  kFLEXPSI_EDMAnSize32Bytes = 0x20U
 eDMA transfer configuration More...
typedef struct _flexspi_edma_handle flexspi_edma_handle_t
typedef void(* flexspi_edma_callback_t) (FLEXSPI_Type *base, flexspi_edma_handle_t *handle, status_t status, void *userData)
 FLEXSPI eDMA transfer callback function for finish and error.
typedef enum _flexspi_edma_ntransfer_size flexspi_edma_transfer_nsize_t
#define FSL_FLEXSPI_EDMA_DRIVER_VERSION   (MAKE_VERSION(2, 3, 2))
 FLEXSPI EDMA driver version 2.3.2.
FLEXSPI eDMA Transactional
void FLEXSPI_TransferCreateHandleEDMA (FLEXSPI_Type *base, flexspi_edma_handle_t *handle, flexspi_edma_callback_t callback, void *userData, edma_handle_t *txDmaHandle, edma_handle_t *rxDmaHandle)
 Initializes the FLEXSPI handle for transfer which is used in transactional functions and set the callback.
void FLEXSPI_TransferUpdateSizeEDMA (FLEXSPI_Type *base, flexspi_edma_handle_t *handle, flexspi_edma_transfer_nsize_t nsize)
 Update FLEXSPI EDMA transfer source data transfer size(SSIZE) and destination data transfer size(DSIZE).
status_t FLEXSPI_TransferEDMA (FLEXSPI_Type *base, flexspi_edma_handle_t *handle, flexspi_transfer_t *xfer)
 Transfers FLEXSPI data using an eDMA non-blocking method.
void FLEXSPI_TransferAbortEDMA (FLEXSPI_Type *base, flexspi_edma_handle_t *handle)
 Aborts the transfer data using eDMA.
status_t FLEXSPI_TransferGetTransferCountEDMA (FLEXSPI_Type *base, flexspi_edma_handle_t *handle, size_t *count)
 Gets the transferred counts of transfer.
◆ _flexspi_edma_ntransfer_size
Source/Destination data transfer size is 1 byte every time
Source/Destination data transfer size is 2 bytes every time
Source/Destination data transfer size is 4 bytes every time
Source/Destination data transfer size is 8 bytes every time
Source/Destination data transfer size is 32 bytes every time
◆ FLEXSPI_TransferAbortEDMA()
void FLEXSPI_TransferAbortEDMA ( FLEXSPI_Type base,
flexspi_edma_handle_t handle
This function aborts the transfer data using eDMA.
Parameters
baseFLEXSPI peripheral base address.
handlePointer to flexspi_edma_handle_t structure
brief Aborts the transfer data using eDMA.
param base FLEXSPI peripheral base address. param handle Pointer to flexspi_edma_handle_t structure
◆ FLEXSPI_TransferCreateHandleEDMA()
void FLEXSPI_TransferCreateHandleEDMA ( FLEXSPI_Type base,
flexspi_edma_handle_t handle,
void *  userData,
edma_handle_t txDmaHandle,
edma_handle_t rxDmaHandle
Parameters
callbackFLEXSPI callback, NULL means no callback.
userDataUser callback function data.
txDmaHandleUser requested DMA handle for TX DMA transfer.
rxDmaHandleUser requested DMA handle for RX DMA transfer.
brief Initializes the FLEXSPI handle for transfer which is used in transactional functions and set the callback.
param base FLEXSPI peripheral base address param handle Pointer to flexspi_edma_handle_t structure param callback FLEXSPI callback, NULL means no callback. param userData User callback function data. param txDmaHandle User requested DMA handle for TX DMA transfer. param rxDmaHandle User requested DMA handle for RX DMA transfer.
◆ FLEXSPI_TransferEDMA()
status_t FLEXSPI_TransferEDMA ( FLEXSPI_Type base,
flexspi_transfer_t xfer
This function writes/receives data to/from the FLEXSPI transmit/receive FIFO. This function is non-blocking.
Parameters
xferFLEXSPI transfer structure.
Return values
kStatus_FLEXSPI_BusyFLEXSPI is busy transfer.
kStatus_InvalidArgumentThe watermark configuration is invalid, the watermark should be power of 2 to do successfully EDMA transfer.
kStatus_SuccessFLEXSPI successfully start edma transfer.
brief Transfers FLEXSPI data using an eDMA non-blocking method.
This function writes/receives data to/from the FLEXSPI transmit/receive FIFO. This function is non-blocking. param base FLEXSPI peripheral base address. param handle Pointer to flexspi_edma_handle_t structure param xfer FLEXSPI transfer structure. retval kStatus_FLEXSPI_Busy FLEXSPI is busy transfer. retval kStatus_InvalidArgument The watermark configuration is invalid, the watermark should be power of 2 to do successfully EDMA transfer. retval kStatus_Success FLEXSPI successfully start edma transfer.
◆ FLEXSPI_TransferGetTransferCountEDMA()
status_t FLEXSPI_TransferGetTransferCountEDMA ( FLEXSPI_Type base,
size_t *  count
Parameters
handlePointer to flexspi_edma_handle_t structure.
countBytes transfer.
Return values
kStatus_SuccessSucceed get the transfer count.
kStatus_NoTransferInProgressThere is not a non-blocking transaction currently in progress.
◆ FLEXSPI_TransferUpdateSizeEDMA()
void FLEXSPI_TransferUpdateSizeEDMA ( FLEXSPI_Type base,
Parameters
nsizeFLEXSPI DMA transfer data transfer size(SSIZE/DSIZE), by default the size is kFLEXPSI_EDMAnSize1Bytes(one byte).
See also
flexspi_edma_transfer_nsize_t .
brief Update FLEXSPI EDMA transfer source data transfer size(SSIZE) and destination data transfer size(DSIZE).
param base FLEXSPI peripheral base address param handle Pointer to flexspi_edma_handle_t structure param nsize FLEXSPI DMA transfer data transfer size(SSIZE/DSIZE), by default the size is kFLEXPSI_EDMAnSize1Bytes(one byte). see flexspi_edma_transfer_nsize_t .
Variable Documentation
◆ completionCallback
A callback function called after the eDMA transfer is finished.
◆ count
The transfer data count in a DMA request.
◆ nbytes
eDMA minor byte transfer count initially configured.
◆ nsize
eDMA SSIZE/DSIZE in each transfer.
◆ rxDmaHandle
edma_handle_t* _flexspi_edma_handle::rxDmaHandle
eDMA handler for FLEXSPI Rx.
◆ state
Internal state for FLEXSPI eDMA transfer.
◆ transferSize
Bytes need to transfer.
◆ txDmaHandle
edma_handle_t* _flexspi_edma_handle::txDmaHandle
eDMA handler for FLEXSPI Tx.
◆ userData
void* _flexspi_edma_handle::userData
User callback parameter
