RTEMS 6.1
| struct | _flexio_camera_type |
| Define structure of configuring the FlexIO Camera device. More... | |
| struct | _flexio_camera_config |
| Define FlexIO Camera user configuration structure. More... | |
| struct | _flexio_camera_transfer |
| Define FlexIO Camera transfer structure. More... | |
| FLEXIO_Type * | _flexio_camera_type::flexioBase |
| uint32_t | _flexio_camera_type::datPinStartIdx |
| uint32_t | _flexio_camera_type::pclkPinIdx |
| uint32_t | _flexio_camera_type::hrefPinIdx |
| uint32_t | _flexio_camera_type::shifterStartIdx |
| uint32_t | _flexio_camera_type::shifterCount |
| uint32_t | _flexio_camera_type::timerIdx |
| bool | _flexio_camera_config::enablecamera |
| bool | _flexio_camera_config::enableInDoze |
| bool | _flexio_camera_config::enableInDebug |
| bool | _flexio_camera_config::enableFastAccess |
| uint32_t | _flexio_camera_transfer::dataAddress |
| uint32_t | _flexio_camera_transfer::dataNum |
Driver version | |
| enum | { kStatus_FLEXIO_CAMERA_RxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_CAMERA, 0) , kStatus_FLEXIO_CAMERA_RxIdle = MAKE_STATUS(kStatusGroup_FLEXIO_CAMERA, 1) } |
| Error codes for the Camera driver. More... | |
| enum | _flexio_camera_status_flags { kFLEXIO_CAMERA_RxDataRegFullFlag = 0x1U , kFLEXIO_CAMERA_RxErrorFlag = 0x2U } |
| Define FlexIO Camera status mask. More... | |
| typedef struct _flexio_camera_type | FLEXIO_CAMERA_Type |
| Define structure of configuring the FlexIO Camera device. | |
| typedef struct _flexio_camera_config | flexio_camera_config_t |
| Define FlexIO Camera user configuration structure. | |
| typedef struct _flexio_camera_transfer | flexio_camera_transfer_t |
| Define FlexIO Camera transfer structure. | |
| #define | FSL_FLEXIO_CAMERA_DRIVER_VERSION (MAKE_VERSION(2, 1, 3)) |
| FlexIO Camera driver version 2.1.3. | |
| #define | FLEXIO_CAMERA_PARALLEL_DATA_WIDTH (8U) |
| Define the Camera CPI interface is constantly 8-bit width. | |
Initialization and configuration | |
| void | FLEXIO_CAMERA_Init (FLEXIO_CAMERA_Type *base, const flexio_camera_config_t *config) |
| Ungates the FlexIO clock, resets the FlexIO module, and configures the FlexIO Camera. | |
| void | FLEXIO_CAMERA_Deinit (FLEXIO_CAMERA_Type *base) |
| Resets the FLEXIO_CAMERA shifer and timer config. | |
| void | FLEXIO_CAMERA_GetDefaultConfig (flexio_camera_config_t *config) |
| Gets the default configuration to configure the FlexIO Camera. The configuration can be used directly for calling the FLEXIO_CAMERA_Init(). Example: | |
Status | |
| uint32_t | FLEXIO_CAMERA_GetStatusFlags (FLEXIO_CAMERA_Type *base) |
| Gets the FlexIO Camera status flags. | |
| void | FLEXIO_CAMERA_ClearStatusFlags (FLEXIO_CAMERA_Type *base, uint32_t mask) |
| Clears the receive buffer full flag manually. | |
Interrupts | |
| void | FLEXIO_CAMERA_EnableInterrupt (FLEXIO_CAMERA_Type *base) |
| Switches on the interrupt for receive buffer full event. | |
| void | FLEXIO_CAMERA_DisableInterrupt (FLEXIO_CAMERA_Type *base) |
| Switches off the interrupt for receive buffer full event. | |
| anonymous enum |
| void FLEXIO_CAMERA_ClearStatusFlags | ( | FLEXIO_CAMERA_Type * | base, |
| uint32_t | mask | ||
| base | Pointer to the device. |
| mask | status flag The parameter can be any combination of the following values:
| void FLEXIO_CAMERA_Deinit | ( | FLEXIO_CAMERA_Type * | base | ) |
| base | Pointer to FLEXIO_CAMERA_Type structure |
| void FLEXIO_CAMERA_DisableInterrupt | ( | FLEXIO_CAMERA_Type * | base | ) |
| void FLEXIO_CAMERA_EnableInterrupt | ( | FLEXIO_CAMERA_Type * | base | ) |
| void FLEXIO_CAMERA_GetDefaultConfig | ( | flexio_camera_config_t * | config | ) |
| config | Pointer to the flexio_camera_config_t structure |
| uint32_t FLEXIO_CAMERA_GetStatusFlags | ( | FLEXIO_CAMERA_Type * | base | ) |
| void FLEXIO_CAMERA_Init | ( | FLEXIO_CAMERA_Type * | base, |
| const flexio_camera_config_t * | config | ||
| config | Pointer to flexio_camera_config_t structure |
| uint32_t _flexio_camera_transfer::dataAddress |
Transfer buffer
| uint32_t _flexio_camera_transfer::dataNum |
Transfer num
| uint32_t _flexio_camera_type::datPinStartIdx |
First data pin (D0) index for flexio_camera. Then the successive following FLEXIO_CAMERA_DATA_WIDTH-1 pins are used as D1-D7.
| bool _flexio_camera_config::enablecamera |
Enable/disable FlexIO Camera TX & RX.
| bool _flexio_camera_config::enableFastAccess |
Enable/disable fast access to FlexIO registers, fast access requires the FlexIO clock to be at least twice the frequency of the bus clock.
| bool _flexio_camera_config::enableInDebug |
Enable/disable FlexIO operation in debug mode
| bool _flexio_camera_config::enableInDoze |
Enable/disable FlexIO operation in doze mode
| FLEXIO_Type* _flexio_camera_type::flexioBase |
FlexIO module base address.
| uint32_t _flexio_camera_type::hrefPinIdx |
Horizontal sync pin (HREF) index for flexio_camera.
| uint32_t _flexio_camera_type::pclkPinIdx |
Pixel clock pin (PCLK) index for flexio_camera.
| uint32_t _flexio_camera_type::shifterCount |
The count of shifters that are used as flexio_camera data FIFO.
| uint32_t _flexio_camera_type::shifterStartIdx |
First shifter index used for flexio_camera data FIFO.
| uint32_t _flexio_camera_type::timerIdx |
Timer index used for flexio_camera in FlexIO.
