RTEMS 6.1
Data Structures | Enumerator | Variables
Cmp
struct  _cmp_config
 Configures the comparator. More...
struct  _cmp_filter_config
 Configures the filter. More...
struct  _cmp_dac_config
 Configures the internal DAC. More...
bool _cmp_config::enableCmp
cmp_hysteresis_mode_t _cmp_config::hysteresisMode
bool _cmp_config::enableHighSpeed
bool _cmp_config::enableInvertOutput
bool _cmp_config::useUnfilteredOutput
bool _cmp_config::enablePinOut
uint8_t _cmp_filter_config::filterCount
uint8_t _cmp_filter_config::filterPeriod
cmp_reference_voltage_source_t _cmp_dac_config::referenceVoltageSource
uint8_t _cmp_dac_config::DACValue
Driver version
enum  _cmp_interrupt_enable { kCMP_OutputRisingInterruptEnable = CMP_SCR_IER_MASK , kCMP_OutputFallingInterruptEnable = CMP_SCR_IEF_MASK }
 Interrupt enable/disable mask. More...
enum  _cmp_status_flags { kCMP_OutputRisingEventFlag = CMP_SCR_CFR_MASK , kCMP_OutputFallingEventFlag = CMP_SCR_CFF_MASK , kCMP_OutputAssertEventFlag = CMP_SCR_COUT_MASK }
 Status flags' mask. More...
enum  _cmp_hysteresis_mode { kCMP_HysteresisLevel0 = 0U , kCMP_HysteresisLevel1 = 1U , kCMP_HysteresisLevel2 = 2U , kCMP_HysteresisLevel3 = 3U }
 CMP Hysteresis mode. More...
enum  _cmp_reference_voltage_source { kCMP_VrefSourceVin1 = 0U , kCMP_VrefSourceVin2 = 1U }
 CMP Voltage Reference source. More...
typedef enum _cmp_hysteresis_mode cmp_hysteresis_mode_t
typedef enum _cmp_reference_voltage_source cmp_reference_voltage_source_t
typedef struct _cmp_config cmp_config_t
typedef struct _cmp_filter_config cmp_filter_config_t
typedef struct _cmp_dac_config cmp_dac_config_t
#define FSL_CMP_DRIVER_VERSION   (MAKE_VERSION(2, 0, 2))
 CMP driver version 2.0.2.
Initialization
void CMP_Init (CMP_Type *base, const cmp_config_t *config)
 Initializes the CMP.
void CMP_Deinit (CMP_Type *base)
 De-initializes the CMP module.
void CMP_GetDefaultConfig (cmp_config_t *config)
 Initializes the CMP user configuration structure.
void CMP_SetInputChannels (CMP_Type *base, uint8_t positiveChannel, uint8_t negativeChannel)
 Sets the input channels for the comparator.
Advanced Features
void CMP_SetFilterConfig (CMP_Type *base, const cmp_filter_config_t *config)
void CMP_SetDACConfig (CMP_Type *base, const cmp_dac_config_t *config)
void CMP_EnableInterrupts (CMP_Type *base, uint32_t mask)
 Enables the interrupts.
void CMP_DisableInterrupts (CMP_Type *base, uint32_t mask)
 Disables the interrupts.
Results
uint32_t CMP_GetStatusFlags (CMP_Type *base)
 Gets the status flags.
void CMP_ClearStatusFlags (CMP_Type *base, uint32_t mask)
 Clears the status flags.
◆ _cmp_hysteresis_mode
Hysteresis level 0.
Hysteresis level 1.
Hysteresis level 2.
Hysteresis level 3.
◆ _cmp_interrupt_enable
Comparator interrupt enable rising.
Comparator interrupt enable falling.
◆ _cmp_reference_voltage_source
kCMP_VrefSourceVin1
Vin1 is selected as a resistor ladder network supply reference Vin.
kCMP_VrefSourceVin2
Vin2 is selected as a resistor ladder network supply reference Vin.
◆ _cmp_status_flags
Status flags' mask.
Rising-edge on the comparison output has occurred.
Falling-edge on the comparison output has occurred.
Return the current value of the analog comparator output.
◆ CMP_ClearStatusFlags()
void CMP_ClearStatusFlags ( CMP_Type base,
uint32_t  mask
Parameters
baseCMP peripheral base address.
maskMask value for the flags. See "_cmp_status_flags".
brief Clears the status flags.
param base CMP peripheral base address. param mask Mask value for the flags. See "_cmp_status_flags".
◆ CMP_Deinit()
void CMP_Deinit ( CMP_Type base)
This function de-initializes the CMP module. The operations included are as follows.
  • Disabling the CMP module.
  • Disabling the clock for CMP module.
This function disables the clock for the CMP. Note that for some devices, multiple CMP instances share the same clock gate. In this case, before disabling the clock for the CMP, ensure that all the CMP instances are not used.
Parameters
brief De-initializes the CMP module.
◆ CMP_DisableInterrupts()
void CMP_DisableInterrupts ( CMP_Type base,
uint32_t  mask
Parameters
maskMask value for interrupts. See "_cmp_interrupt_enable".
brief Disables the interrupts.
param base CMP peripheral base address. param mask Mask value for interrupts. See "_cmp_interrupt_enable".
◆ CMP_EnableInterrupts()
void CMP_EnableInterrupts ( CMP_Type base,
uint32_t  mask
Parameters
brief Enables the interrupts.
◆ CMP_GetDefaultConfig()
void CMP_GetDefaultConfig ( cmp_config_t config)
This function initializes the user configuration structure to these default values.
config->enableCmp = true;
config->hysteresisMode = kCMP_HysteresisLevel0;
config->enableHighSpeed = false;
config->enableInvertOutput = false;
config->useUnfilteredOutput = false;
config->enablePinOut = false;
config->enableTriggerMode = false;
@ kCMP_HysteresisLevel0
Definition: fsl_cmp.h:53
Definition: deflate.c:114
Parameters
configPointer to the configuration structure.
brief Initializes the CMP user configuration structure.
This function initializes the user configuration structure to these default values. code config->enableCmp = true; config->hysteresisMode = kCMP_HysteresisLevel0; config->enableHighSpeed = false; config->enableInvertOutput = false; config->useUnfilteredOutput = false; config->enablePinOut = false; config->enableTriggerMode = false; endcode param config Pointer to the configuration structure.
◆ CMP_GetStatusFlags()
uint32_t CMP_GetStatusFlags ( CMP_Type base)
Parameters
Returns
Mask value for the asserted flags. See "_cmp_status_flags".
brief Gets the status flags.
return Mask value for the asserted flags. See "_cmp_status_flags".
◆ CMP_Init()
void CMP_Init ( CMP_Type base,
const cmp_config_t config
This function initializes the CMP module. The operations included are as follows.
  • Enabling the clock for CMP module.
  • Configuring the comparator.
  • Enabling the CMP module. Note that for some devices, multiple CMP instances share the same clock gate. In this case, to enable the clock for any instance enables all CMPs. See the appropriate MCU reference manual for the clock assignment of the CMP.
Parameters
brief Initializes the CMP.
param base CMP peripheral base address. param config Pointer to the configuration structure.
◆ CMP_SetDACConfig()
void CMP_SetDACConfig ( CMP_Type base,
const cmp_dac_config_t config
Parameters
configPointer to the configuration structure. "NULL" disables the feature.
brief Configures the internal DAC.
param base CMP peripheral base address. param config Pointer to the configuration structure. "NULL" disables the feature.
◆ CMP_SetFilterConfig()
void CMP_SetFilterConfig ( CMP_Type base,
const cmp_filter_config_t config
Parameters
brief Configures the filter.
◆ CMP_SetInputChannels()
void CMP_SetInputChannels ( CMP_Type base,
This function sets the input channels for the comparator. Note that two input channels cannot be set the same way in the application. When the user selects the same input from the analog mux to the positive and negative port, the comparator is disabled automatically.
Parameters
positiveChannelPositive side input channel number. Available range is 0-7.
negativeChannelNegative side input channel number. Available range is 0-7.
brief Sets the input channels for the comparator.
param base CMP peripheral base address. param positiveChannel Positive side input channel number. Available range is 0-7. param negativeChannel Negative side input channel number. Available range is 0-7.
Variable Documentation
◆ DACValue
Value for the DAC Output Voltage. Available range is 0-63.
◆ enableCmp
Enable the CMP module.
◆ enableHighSpeed
Enable High-speed (HS) comparison mode.
◆ enableInvertOutput
Enable the inverted comparator output.
◆ enablePinOut
The comparator output is available on the associated pin.
◆ filterCount
Filter Sample Count. Available range is 1-7; 0 disables the filter.
◆ filterPeriod
Filter Sample Period. The divider to the bus clock. Available range is 0-255.
◆ hysteresisMode
◆ referenceVoltageSource
Supply voltage reference source.
◆ useUnfilteredOutput
Set the compare output(COUT) to equal COUTA(true) or COUT(false).
