#define | AI_PHY_LDO_CTRL0_LINREG_EN(x) (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LINREG_EN_MASK) |
#define | AI_PHY_LDO_CTRL0_LINREG_EN_MASK (0x1U) |
#define | AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT (0U) |
| #define | AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS(x) (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT)) & AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK) |
#define | AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK (0x2U) |
#define | AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT (1U) |
| #define | AI_PHY_LDO_CTRL0_LIMIT_EN(x) (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LIMIT_EN_MASK) |
#define | AI_PHY_LDO_CTRL0_LIMIT_EN_MASK (0x4U) |
#define | AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT (2U) |
| #define | AI_PHY_LDO_CTRL0_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT)) & AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK) |
#define | AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK (0x1F0U) |
#define | AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT (4U) |
| #define | AI_PHY_LDO_CTRL0_PHY_ISO_B(x) (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT)) & AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK) |
#define | AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK (0x8000U) |
#define | AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT (15U) |
#define | AI_BANDGAP_CTRL0_REFTOP_PWD(x) (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWD_MASK) |
#define | AI_BANDGAP_CTRL0_REFTOP_PWD_MASK (0x1U) |
#define | AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT (0U) |
| #define | AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD(x) |
#define | AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK (0x2U) |
#define | AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT (1U) |
| #define | AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP(x) (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK) |
#define | AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK (0x4U) |
#define | AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT (2U) |
| #define | AI_BANDGAP_CTRL0_REFTOP_LOWPOWER(x) (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK) |
#define | AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK (0x8U) |
#define | AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT (3U) |
| #define | AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF(x) |
#define | AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK (0x10U) |
#define | AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT (4U) |
| #define | AI_BANDGAP_CTRL0_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK) |
#define | AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK (0xE0U) |
#define | AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT (5U) |
| #define | AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ(x) (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK) |
#define | AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK (0x1C00U) |
#define | AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT (10U) |
#define | AI_RCOSC400M_CTRL0_REF_CLK_DIV(x) (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT)) & AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK) |
#define | AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK (0x3F000000U) |
#define | AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT (24U) |
#define | AI_PLL1G_CTRL0_HOLD_RING_OFF(x) (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK) |
#define | AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK (0x2000UL) |
#define | AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT (13U) |
#define | AI_PLL1G_CTRL0_POWER_UP(x) (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_POWER_UP_SHIFT)) & AI_PLL1G_CTRL0_POWER_UP_MASK) |
#define | AI_PLL1G_CTRL0_POWER_UP_MASK (0x4000UL) |
#define | AI_PLL1G_CTRL0_POWER_UP_SHIFT (14U) |
#define | AI_PLL1G_CTRL0_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_ENABLE_SHIFT)) & AI_PLL1G_CTRL0_ENABLE_MASK) |
#define | AI_PLL1G_CTRL0_ENABLE_MASK (0x8000UL) |
#define | AI_PLL1G_CTRL0_ENABLE_SHIFT (15U) |
#define | AI_PLL1G_CTRL0_BYPASS(x) (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_BYPASS_SHIFT)) & AI_PLL1G_CTRL0_BYPASS_MASK) |
#define | AI_PLL1G_CTRL0_BYPASS_MASK (0x10000UL) |
#define | AI_PLL1G_CTRL0_BYPASS_SHIFT (16U) |
#define | AI_PLL1G_CTRL0_PLL_REG_EN(x) (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLL1G_CTRL0_PLL_REG_EN_MASK) |
#define | AI_PLL1G_CTRL0_PLL_REG_EN_MASK (0x400000UL) |
#define | AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT (22U) |
#define | AI_PLLAUDIO_CTRL0_HOLD_RING_OFF(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK) |
#define | AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK (0x2000UL) |
#define | AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT (13U) |
#define | AI_PLLAUDIO_CTRL0_POWER_UP(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT)) & AI_PLLAUDIO_CTRL0_POWER_UP_MASK) |
#define | AI_PLLAUDIO_CTRL0_POWER_UP_MASK (0x4000UL) |
#define | AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT (14U) |
#define | AI_PLLAUDIO_CTRL0_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_ENABLE_SHIFT)) & AI_PLLAUDIO_CTRL0_ENABLE_MASK) |
#define | AI_PLLAUDIO_CTRL0_ENABLE_MASK (0x8000UL) |
#define | AI_PLLAUDIO_CTRL0_ENABLE_SHIFT (15U) |
#define | AI_PLLAUDIO_CTRL0_BYPASS(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_BYPASS_SHIFT)) & AI_PLLAUDIO_CTRL0_BYPASS_MASK) |
#define | AI_PLLAUDIO_CTRL0_BYPASS_MASK (0x10000UL) |
#define | AI_PLLAUDIO_CTRL0_BYPASS_SHIFT (16U) |
#define | AI_PLLAUDIO_CTRL0_PLL_REG_EN(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK) |
#define | AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK (0x400000UL) |
#define | AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT (22U) |
#define | AI_PLLVIDEO_CTRL0_HOLD_RING_OFF(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK) |
#define | AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK (0x2000UL) |
#define | AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT (13U) |
#define | AI_PLLVIDEO_CTRL0_POWER_UP(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT)) & AI_PLLVIDEO_CTRL0_POWER_UP_MASK) |
#define | AI_PLLVIDEO_CTRL0_POWER_UP_MASK (0x4000UL) |
#define | AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT (14U) |
#define | AI_PLLVIDEO_CTRL0_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_ENABLE_SHIFT)) & AI_PLLVIDEO_CTRL0_ENABLE_MASK) |
#define | AI_PLLVIDEO_CTRL0_ENABLE_MASK (0x8000UL) |
#define | AI_PLLVIDEO_CTRL0_ENABLE_SHIFT (15U) |
#define | AI_PLLVIDEO_CTRL0_BYPASS(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_BYPASS_SHIFT)) & AI_PLLVIDEO_CTRL0_BYPASS_MASK) |
#define | AI_PLLVIDEO_CTRL0_BYPASS_MASK (0x10000UL) |
#define | AI_PLLVIDEO_CTRL0_BYPASS_SHIFT (16U) |
#define | AI_PLLVIDEO_CTRL0_PLL_REG_EN(x) (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK) |
#define | AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK (0x400000UL) |
#define | AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT (22U) |
