RTEMS 6.1
| struct | _acmp_config |
| Configuration for ACMP. More... | |
| struct | _acmp_channel_config |
| Configuration for channel. More... | |
| struct | _acmp_filter_config |
| Configuration for filter. More... | |
| struct | _acmp_dac_config |
| Configuration for DAC. More... | |
| struct | _acmp_round_robin_config |
| Configuration for round robin mode. More... | |
Driver version | |
| enum | _acmp_interrupt_enable { kACMP_OutputRisingInterruptEnable = (1U << 0U) , kACMP_OutputFallingInterruptEnable = (1U << 1U) , kACMP_RoundRobinInterruptEnable = (1U << 2U) } |
| Interrupt enable/disable mask. More... | |
| enum | _acmp_status_flags { kACMP_OutputRisingEventFlag = CMP_C0_CFR_MASK , kACMP_OutputFallingEventFlag = CMP_C0_CFF_MASK , kACMP_OutputAssertEventFlag = CMP_C0_COUT_MASK } |
| Status flag mask. More... | |
| enum | _acmp_hysteresis_mode { kACMP_HysteresisLevel0 = 0U , kACMP_HysteresisLevel1 = 1U , kACMP_HysteresisLevel2 = 2U , kACMP_HysteresisLevel3 = 3U } |
| Comparator hard block hysteresis control. More... | |
| enum | _acmp_reference_voltage_source { kACMP_VrefSourceVin1 = 0U , kACMP_VrefSourceVin2 = 1U } |
| CMP Voltage Reference source. More... | |
| enum | _acmp_fixed_port { kACMP_FixedPlusPort = 0U , kACMP_FixedMinusPort = 1U } |
| Fixed mux port. More... | |
| typedef enum _acmp_hysteresis_mode | acmp_hysteresis_mode_t |
| Comparator hard block hysteresis control. | |
| typedef enum _acmp_reference_voltage_source | acmp_reference_voltage_source_t |
| CMP Voltage Reference source. | |
| typedef enum _acmp_fixed_port | acmp_fixed_port_t |
| Fixed mux port. | |
| typedef struct _acmp_config | acmp_config_t |
| Configuration for ACMP. | |
| typedef struct _acmp_channel_config | acmp_channel_config_t |
| Configuration for channel. | |
| typedef struct _acmp_filter_config | acmp_filter_config_t |
| Configuration for filter. | |
| typedef struct _acmp_dac_config | acmp_dac_config_t |
| Configuration for DAC. | |
| typedef struct _acmp_round_robin_config | acmp_round_robin_config_t |
| Configuration for round robin mode. | |
| #define | FSL_ACMP_DRIVER_VERSION (MAKE_VERSION(2U, 0U, 6U)) |
| ACMP driver version 2.0.6. | |
| #define | CMP_C0_CFx_MASK (CMP_C0_CFR_MASK | CMP_C0_CFF_MASK) |
| The mask of status flags cleared by writing 1. | |
| #define | CMP_C1_CHNn_MASK 0xFF0000U /* C1_CHN0 - C1_CHN7. */ |
| #define | CMP_C2_CHnF_MASK 0xFF0000U /* C2_CH0F - C2_CH7F. */ |
Initialization and deinitialization | |
| void | ACMP_Init (CMP_Type *base, const acmp_config_t *config) |
| Initializes the ACMP. | |
| void | ACMP_Deinit (CMP_Type *base) |
| Deinitializes the ACMP. | |
| void | ACMP_GetDefaultConfig (acmp_config_t *config) |
| Gets the default configuration for ACMP. | |
Basic Operations | |
| void | ACMP_Enable (CMP_Type *base, bool enable) |
| Enables or disables the ACMP. | |
| void | ACMP_SetChannelConfig (CMP_Type *base, const acmp_channel_config_t *config) |
| Sets the channel configuration. | |
Advanced Operations | |
| void | ACMP_EnableDMA (CMP_Type *base, bool enable) |
| Enables or disables DMA. | |
| void | ACMP_EnableWindowMode (CMP_Type *base, bool enable) |
| Enables or disables window mode. | |
| void | ACMP_SetFilterConfig (CMP_Type *base, const acmp_filter_config_t *config) |
| Configures the filter. | |
| void | ACMP_SetDACConfig (CMP_Type *base, const acmp_dac_config_t *config) |
| Configures the internal DAC. | |
| void | ACMP_SetRoundRobinConfig (CMP_Type *base, const acmp_round_robin_config_t *config) |
| Configures the round robin mode. | |
| void | ACMP_SetRoundRobinPreState (CMP_Type *base, uint32_t mask) |
| Defines the pre-set state of channels in round robin mode. | |
| void | ACMP_ClearRoundRobinStatusFlags (CMP_Type *base, uint32_t mask) |
| Clears the channel input changed flags in round robin mode. | |
Interrupts | |
| void | ACMP_EnableInterrupts (CMP_Type *base, uint32_t mask) |
| Enables interrupts. | |
| void | ACMP_DisableInterrupts (CMP_Type *base, uint32_t mask) |
| Disables interrupts. | |
Status | |
| uint32_t | ACMP_GetStatusFlags (CMP_Type *base) |
| Gets status flags. | |
| void | ACMP_ClearStatusFlags (CMP_Type *base, uint32_t mask) |
| Clears status flags. | |
| typedef struct _acmp_channel_config acmp_channel_config_t |
The comparator's port can be input from channel mux or DAC. If port input is from channel mux, detailed channel number for the mux should be configured.
| typedef enum _acmp_hysteresis_mode acmp_hysteresis_mode_t |
See chip data sheet to get the actual hysteresis value with each level.
| enum _acmp_status_flags |
| void ACMP_ClearRoundRobinStatusFlags | ( | CMP_Type * | base, |
| uint32_t | mask | ||
| base | ACMP peripheral base address. |
| mask | Mask of channel index. Available range is channel0:0x01 to channel7:0x80. |
brief Clears the channel input changed flags in round robin mode.
param base ACMP peripheral base address. param mask Mask of channel index. Available range is channel0:0x01 to channel7:0x80.
| void ACMP_ClearStatusFlags | ( | CMP_Type * | base, |
| mask | Status flags mask. See "_acmp_status_flags". |
brief Clears status flags.
param base ACMP peripheral base address. param mask Status flags mask. See "_acmp_status_flags".
| void ACMP_Deinit | ( | CMP_Type * | base | ) |
brief Deinitializes the ACMP.
| void ACMP_DisableInterrupts | ( | CMP_Type * | base, |
| mask | Interrupts mask. See "_acmp_interrupt_enable". |
brief Disables interrupts.
param base ACMP peripheral base address. param mask Interrupts mask. See "_acmp_interrupt_enable".
| void ACMP_Enable | ( | CMP_Type * | base, |
| bool | enable | ||
| enable | True to enable the ACMP. |
brief Enables or disables the ACMP.
param base ACMP peripheral base address. param enable True to enable the ACMP.
| void ACMP_EnableDMA | ( | CMP_Type * | base, |
| bool | enable | ||
| enable | True to enable DMA. |
brief Enables or disables DMA.
param base ACMP peripheral base address. param enable True to enable DMA.
| void ACMP_EnableInterrupts | ( | CMP_Type * | base, |
Enables interrupts.
brief Enables interrupts.
| void ACMP_EnableWindowMode | ( | CMP_Type * | base, |
| bool | enable | ||
| enable | True to enable window mode. |
brief Enables or disables window mode.
param base ACMP peripheral base address. param enable True to enable window mode.
| void ACMP_GetDefaultConfig | ( | acmp_config_t * | config | ) |
This function initializes the user configuration structure to default value. The default value are:
Example:
| config | Pointer to ACMP configuration structure. |
brief Gets the default configuration for ACMP.
Example: code config->enableHighSpeed = false; config->enableInvertOutput = false; config->useUnfilteredOutput = false; config->enablePinOut = false; config->enableHysteresisBothDirections = false; config->hysteresisMode = kACMP_hysteresisMode0; endcode
param config Pointer to ACMP configuration structure.
| uint32_t ACMP_GetStatusFlags | ( | CMP_Type * | base | ) |
Gets status flags.
brief Gets status flags.
param base ACMP peripheral base address. return Status flags asserted mask. See "_acmp_status_flags".
| void ACMP_Init | ( | CMP_Type * | base, |
| const acmp_config_t * | config | ||
The default configuration can be got by calling ACMP_GetDefaultConfig().
brief Initializes the ACMP.
param base ACMP peripheral base address. param config Pointer to ACMP configuration structure.
| void ACMP_SetChannelConfig | ( | CMP_Type * | base, |
| const acmp_channel_config_t * | config | ||
Note that the plus/minus mux's setting is only valid when the positive/negative port's input isn't from DAC but from channel mux.
Example:
| config | Pointer to channel configuration structure. |
brief Sets the channel configuration.
Example: code acmp_channel_config_t configStruct = {0}; configStruct.positivePortInput = kACMP_PortInputFromDAC; configStruct.negativePortInput = kACMP_PortInputFromMux; configStruct.minusMuxInput = 1U; ACMP_SetChannelConfig(CMP0, &configStruct); endcode
param base ACMP peripheral base address. param config Pointer to channel configuration structure.
| void ACMP_SetDACConfig | ( | CMP_Type * | base, |
| const acmp_dac_config_t * | config | ||
Example:
| config | Pointer to DAC configuration structure. "NULL" is for disabling the feature. |
brief Configures the internal DAC.
Example: code acmp_dac_config_t configStruct = {0}; configStruct.referenceVoltageSource = kACMP_VrefSourceVin1; configStruct.DACValue = 20U; configStruct.enableOutput = false; configStruct.workMode = kACMP_DACWorkLowSpeedMode; ACMP_SetDACConfig(CMP0, &configStruct); endcode
param base ACMP peripheral base address. param config Pointer to DAC configuration structure. "NULL" is for disabling the feature.
| void ACMP_SetFilterConfig | ( | CMP_Type * | base, |
| const acmp_filter_config_t * | config | ||
The filter can be enabled when the filter count is bigger than 1, the filter period is greater than 0 and the sample clock is from divided bus clock or the filter is bigger than 1 and the sample clock is from external clock. Detailed usage can be got from the reference manual.
Example:
| config | Pointer to filter configuration structure. |
brief Configures the filter.
Example: code acmp_filter_config_t configStruct = {0}; configStruct.filterCount = 5U; configStruct.filterPeriod = 200U; configStruct.enableSample = false; ACMP_SetFilterConfig(CMP0, &configStruct); endcode
param base ACMP peripheral base address. param config Pointer to filter configuration structure.
| void ACMP_SetRoundRobinConfig | ( | CMP_Type * | base, |
| const acmp_round_robin_config_t * | config | ||
Example:
| config | Pointer to round robin mode configuration structure. "NULL" is for disabling the feature. |
brief Configures the round robin mode.
Example: code acmp_round_robin_config_t configStruct = {0}; configStruct.fixedPort = kACMP_FixedPlusPort; configStruct.fixedChannelNumber = 3U; configStruct.checkerChannelMask = 0xF7U; configStruct.sampleClockCount = 0U; configStruct.delayModulus = 0U; ACMP_SetRoundRobinConfig(CMP0, &configStruct); endcode param base ACMP peripheral base address. param config Pointer to round robin mode configuration structure. "NULL" is for disabling the feature.
| void ACMP_SetRoundRobinPreState | ( | CMP_Type * | base, |
Note: The pre-state has different circuit with get-round-robin-result in the SOC even though they are same bits. So get-round-robin-result can't return the same value as the value are set by pre-state.
| mask | Mask of round robin channel index. Available range is channel0:0x01 to channel7:0x80. |
brief Defines the pre-set state of channels in round robin mode.
param base ACMP peripheral base address. param mask Mask of round robin channel index. Available range is channel0:0x01 to channel7:0x80.
| uint32_t _acmp_round_robin_config::checkerChannelMask |
Mask of checker channel index. Available range is channel0:0x01 to channel7:0x80 for round-robin checker.
| uint32_t _acmp_dac_config::DACValue |
Value for DAC Output Voltage. Available range is 0-255.
| uint32_t _acmp_round_robin_config::delayModulus |
Comparator and DAC initialization delay modulus.
| bool _acmp_config::enableHighSpeed |
Enable High Speed (HS) comparison mode.
| bool _acmp_config::enableInvertOutput |
Enable inverted comparator output.
| bool _acmp_config::enablePinOut |
The comparator output is available on the associated pin.
| bool _acmp_filter_config::enableSample |
Using external SAMPLE as sampling clock input, or using divided bus clock.
| uint32_t _acmp_filter_config::filterCount |
Filter Sample Count. Available range is 1-7, 0 would cause the filter disabled.
| uint32_t _acmp_filter_config::filterPeriod |
Filter Sample Period. The divider to bus clock. Available range is 0-255.
| uint32_t _acmp_round_robin_config::fixedChannelNumber |
Indicates which channel is fixed in the fixed mux port.
| acmp_fixed_port_t _acmp_round_robin_config::fixedPort |
Fixed mux port.
| acmp_hysteresis_mode_t _acmp_config::hysteresisMode |
Hysteresis mode.
| uint32_t _acmp_channel_config::minusMuxInput |
Minus mux input channel(0~7).
| uint32_t _acmp_channel_config::plusMuxInput |
Plus mux input channel(0~7).
| acmp_reference_voltage_source_t _acmp_dac_config::referenceVoltageSource |
Supply voltage reference source.
| uint32_t _acmp_round_robin_config::sampleClockCount |
Specifies how many round-robin clock cycles(0~3) later the sample takes place.
| bool _acmp_config::useUnfilteredOutput |
Set compare output(COUT) to equal COUTA(true) or COUT(false).
