RTEMS 6.1
Modules | Files | Macros | Variables
spec:/testsuites/terminate
This validation test suite contains a test case for the system termination procedure. More...
 spec:/score/interr/val/terminate
 Tests system termination procedure.
file  ts-terminate.c
#define CONFIGURE_MAXIMUM_PROCESSORS   2
#define CONFIGURE_INITIAL_EXTENSIONS
#define CONFIGURE_DISABLE_BSP_SETTINGS
const char rtems_test_name [] = "TestsuitesTerminate"
 Each test must define a test name string.
◆ CONFIGURE_INITIAL_EXTENSIONS
Value:
{ .fatal = FatalExtension0 }, \
{ .fatal = FatalExtension1 }
