RTEMS 6.1
| #define TIM_TRGO2_ENABLE TIM_CR2_MMS2_0 |
TIMx_CR1.CEN bit is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC1 (TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0) |
Capture or a compare match 1 is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC1REF TIM_CR2_MMS2_2 |
OC1REF signal is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC2REF (TIM_CR2_MMS2_2 | TIM_CR2_MMS2_0) |
OC2REF signal is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC3REF (TIM_CR2_MMS2_2 | TIM_CR2_MMS2_1) |
OC3REF signal is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC4REF (TIM_CR2_MMS2_2 | TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0) |
OC4REF signal is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC4REF_RISING_OC6REF_FALLING (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2 | TIM_CR2_MMS2_0) |
OC4REF rising or OC6REF falling edges generate pulses on TRGO2
| #define TIM_TRGO2_OC4REF_RISING_OC6REF_RISING (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2) |
OC4REF or OC6REF rising edges generate pulses on TRGO2
| #define TIM_TRGO2_OC4REF_RISINGFALLING (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_1) |
OC4REF rising or falling edges generate pulses on TRGO2
| #define TIM_TRGO2_OC5REF TIM_CR2_MMS2_3 |
OC5REF signal is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC5REF_RISING_OC6REF_FALLING (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2 | TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0) |
OC5REF or OC6REF rising edges generate pulses on TRGO2
| #define TIM_TRGO2_OC5REF_RISING_OC6REF_RISING (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2 |TIM_CR2_MMS2_1) |
| #define TIM_TRGO2_OC6REF (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_0) |
OC6REF signal is used as trigger output (TRGO2)
| #define TIM_TRGO2_OC6REF_RISINGFALLING (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0) |
OC6REF rising or falling edges generate pulses on TRGO2
| #define TIM_TRGO2_RESET 0x00000000U |
TIMx_EGR.UG bit is used as trigger output (TRGO2)
| #define TIM_TRGO2_UPDATE TIM_CR2_MMS2_1 |
Update event is used as trigger output (TRGO2)
