RTEMS 6.1
| #define | TIM_TRGO_RESET 0x00000000U |
| #define | TIM_TRGO_ENABLE TIM_CR2_MMS_0 |
| #define | TIM_TRGO_UPDATE TIM_CR2_MMS_1 |
| #define | TIM_TRGO_OC1 (TIM_CR2_MMS_1 | TIM_CR2_MMS_0) |
| #define | TIM_TRGO_OC1REF TIM_CR2_MMS_2 |
| #define | TIM_TRGO_OC2REF (TIM_CR2_MMS_2 | TIM_CR2_MMS_0) |
| #define | TIM_TRGO_OC3REF (TIM_CR2_MMS_2 | TIM_CR2_MMS_1) |
| #define | TIM_TRGO_OC4REF (TIM_CR2_MMS_2 | TIM_CR2_MMS_1 | TIM_CR2_MMS_0) |
| #define TIM_TRGO_ENABLE TIM_CR2_MMS_0 |
TIMx_CR1.CEN bit is used as trigger output (TRGO)
| #define TIM_TRGO_OC1 (TIM_CR2_MMS_1 | TIM_CR2_MMS_0) |
Capture or a compare match 1 is used as trigger output (TRGO)
| #define TIM_TRGO_OC1REF TIM_CR2_MMS_2 |
OC1REF signal is used as trigger output (TRGO)
| #define TIM_TRGO_OC2REF (TIM_CR2_MMS_2 | TIM_CR2_MMS_0) |
OC2REF signal is used as trigger output(TRGO)
| #define TIM_TRGO_OC3REF (TIM_CR2_MMS_2 | TIM_CR2_MMS_1) |
OC3REF signal is used as trigger output(TRGO)
| #define TIM_TRGO_OC4REF (TIM_CR2_MMS_2 | TIM_CR2_MMS_1 | TIM_CR2_MMS_0) |
OC4REF signal is used as trigger output(TRGO)
| #define TIM_TRGO_RESET 0x00000000U |
TIMx_EGR.UG bit is used as trigger output (TRGO)
| #define TIM_TRGO_UPDATE TIM_CR2_MMS_1 |
Update event is used as trigger output (TRGO)
