RTEMS 6.1
#define TIM_EVENTSOURCE_UPDATE   TIM_EGR_UG
#define TIM_EVENTSOURCE_CC1   TIM_EGR_CC1G
#define TIM_EVENTSOURCE_CC2   TIM_EGR_CC2G
#define TIM_EVENTSOURCE_CC3   TIM_EGR_CC3G
#define TIM_EVENTSOURCE_CC4   TIM_EGR_CC4G
#define TIM_EVENTSOURCE_COM   TIM_EGR_COMG
#define TIM_EVENTSOURCE_TRIGGER   TIM_EGR_TG
#define TIM_EVENTSOURCE_BREAK   TIM_EGR_BG
#define TIM_EVENTSOURCE_BREAK2   TIM_EGR_B2G
◆ TIM_EVENTSOURCE_BREAK
A break event is generated
◆ TIM_EVENTSOURCE_BREAK2
A break 2 event is generated
◆ TIM_EVENTSOURCE_CC1
A capture/compare event is generated on channel 1
◆ TIM_EVENTSOURCE_CC2
A capture/compare event is generated on channel 2
◆ TIM_EVENTSOURCE_CC3
A capture/compare event is generated on channel 3
◆ TIM_EVENTSOURCE_CC4
A capture/compare event is generated on channel 4
◆ TIM_EVENTSOURCE_COM
A commutation event is generated
◆ TIM_EVENTSOURCE_TRIGGER
A trigger event is generated
◆ TIM_EVENTSOURCE_UPDATE
Reinitialize the counter and generates an update of the registers
