RTEMS 6.1
Files | Data Structures | Functions
spec:/score/smp/val/fatal-start-on-not-online-processor
Tests a fatal error. More...
file  tr-fatal-start-on-not-online-processor.c
file  tr-fatal-start-on-not-online-processor.h
struct  ScoreSmpValFatalStartOnNotOnlineProcessor_Context
 Test context for spec:/score/smp/val/fatal-start-on-not-online-processor test case. More...
bool __real__CPU_SMP_Start_processor (uint32_t cpu_index)
bool __wrap__CPU_SMP_Start_processor (uint32_t cpu_index)
void ScoreSmpValFatalStartOnNotOnlineProcessor_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
This test case performs the following actions:
◆ ScoreSmpValFatalStartOnNotOnlineProcessor_Run()
void ScoreSmpValFatalStartOnNotOnlineProcessor_Run ( rtems_fatal_source  source,
Parameters
sourceis fatal source.
codeis fatal code.
