RTEMS 6.1
| #define | SYSCFG_CELL_CODE ((uint32_t)0x00000000) |
| #define | SYSCFG_REGISTER_CODE SYSCFG_CCCSR_CS |
| #define | IS_SYSCFG_CODE_SELECT(SELECT) |
| #define | IS_SYSCFG_CODE_CONFIG(CONFIG) ((CONFIG) < (0x10UL)) |
| #define IS_SYSCFG_CODE_SELECT | ( | SELECT | ) |
| #define SYSCFG_CELL_CODE ((uint32_t)0x00000000) |
Select Code from the cell
| #define SYSCFG_REGISTER_CODE SYSCFG_CCCSR_CS |
Code from the SYSCFG compensation cell code register
