RTEMS 6.1
Bit rate calculation helper Macros
#define __LL_SWPMI_CALC_BITRATE_PRESCALER(__FSWP__, __FSWPCLK__)   ((uint32_t)(((__FSWPCLK__) / ((__FSWP__) * 4)) - 1))
 Helper macro to calculate bit rate value to set in BRR register (LL_SWPMI_SetBitRatePrescaler function)
◆ __LL_SWPMI_CALC_BITRATE_PRESCALER
#define __LL_SWPMI_CALC_BITRATE_PRESCALER (   __FSWP__,
  __FSWPCLK__
Note
ex: __LL_SWPMI_CALC_BITRATE_PRESCALER(2000000, 80000000);
Parameters
__FSWP__Within the following range: from 100 Kbit/s up to 2Mbit/s (in bit/s)
__FSWPCLK__PCLK or HSI frequency (in Hz)
Return values
Bitrateprescaler (BRR register)
