RTEMS 6.1
| void | SystemInit (void) |
| Setup the microcontroller system. Initialize the System and update the SystemFrequency variable. | |
| void | SystemCoreClockUpdate (void) |
| Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable contains the core clock , it can be used by the user application to setup the SysTick timer or configure other parameters. | |
| void SystemCoreClockUpdate | ( | void | ) |
Updates the SystemCoreClock variable.
Updates the SystemCoreClock with current core Clock retrieved from cpu registers.
(*) CSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value 4 MHz) but the real value may vary depending on the variations in voltage and temperature. (**) HSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value 64 MHz) but the real value may vary depending on the variations in voltage and temperature.
(***)HSE_VALUE is a constant defined in stm32h7xx_hal.h file (default value 25 MHz), user has to ensure that HSE_VALUE is same as the real frequency of the crystal used. Otherwise, this function may have wrong result.
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| None |
| void SystemInit | ( | void | ) |
Setup the microcontroller system. Initialize the System and update the SystemCoreClock variable.
Setup the microcontroller system Initialize the FPU setting, vector table location and External memory configuration.
Setup the microcontroller system Initialize the FPU setting and vector table location configuration.
| None |
| None |
| None |
| None |
| None |
| None |
