RTEMS 6.1
| #define | __HAL_SMARTCARD_RESET_HANDLE_STATE(__HANDLE__) |
| Reset SMARTCARD handle states. | |
| #define | __HAL_SMARTCARD_FLUSH_DRREGISTER(__HANDLE__) |
| Flush the Smartcard Data registers. | |
| #define | __HAL_SMARTCARD_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
| Clear the specified SMARTCARD pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_PEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_PEF) |
| Clear the SMARTCARD PE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_FEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_FEF) |
| Clear the SMARTCARD FE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_NEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_NEF) |
| Clear the SMARTCARD NE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_OREFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_OREF) |
| Clear the SMARTCARD ORE pending flag. | |
| #define | __HAL_SMARTCARD_CLEAR_IDLEFLAG(__HANDLE__) __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_IDLEF) |
| Clear the SMARTCARD IDLE pending flag. | |
| #define | __HAL_SMARTCARD_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
| Check whether the specified Smartcard flag is set or not. | |
| #define | __HAL_SMARTCARD_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified SmartCard interrupt. | |
| #define | __HAL_SMARTCARD_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified SmartCard interrupt. | |
| #define | __HAL_SMARTCARD_GET_IT(__HANDLE__, __INTERRUPT__) |
| Check whether the specified SmartCard interrupt has occurred or not. | |
| #define | __HAL_SMARTCARD_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified SmartCard interrupt source is enabled or not. | |
| #define | __HAL_SMARTCARD_CLEAR_IT(__HANDLE__, __IT_CLEAR__) ((__HANDLE__)->Instance->ICR |= (uint32_t)(__IT_CLEAR__)) |
| Clear the specified SMARTCARD ISR flag, in setting the proper ICR register flag. | |
| #define | __HAL_SMARTCARD_SEND_REQ(__HANDLE__, __REQ__) ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
| Set a specific SMARTCARD request flag. | |
| #define | __HAL_SMARTCARD_ONE_BIT_SAMPLE_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
| Enable the SMARTCARD one bit sample method. | |
| #define | __HAL_SMARTCARD_ONE_BIT_SAMPLE_DISABLE(__HANDLE__) |
| Disable the SMARTCARD one bit sample method. | |
| #define | __HAL_SMARTCARD_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
| Enable the USART associated to the SMARTCARD Handle. | |
| #define | __HAL_SMARTCARD_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
| Disable the USART associated to the SMARTCARD Handle. | |
| #define __HAL_SMARTCARD_CLEAR_FEFLAG | ( | __HANDLE__ | ) | __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_FEF) |
| __HANDLE__ | specifies the SMARTCARD Handle. |
| None |
| #define __HAL_SMARTCARD_CLEAR_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| ) | ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
| __FLAG__ | specifies the flag to check. This parameter can be any combination of the following values:
| None |
| #define __HAL_SMARTCARD_CLEAR_IDLEFLAG | ( | __HANDLE__ | ) | __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_IDLEF) |
| None |
| #define __HAL_SMARTCARD_CLEAR_IT | ( | __HANDLE__, | |
| __IT_CLEAR__ | |||
| ) | ((__HANDLE__)->Instance->ICR |= (uint32_t)(__IT_CLEAR__)) |
| __IT_CLEAR__ | specifies the interrupt clear register flag that needs to be set to clear the corresponding interrupt. This parameter can be one of the following values:
| None |
| #define __HAL_SMARTCARD_CLEAR_NEFLAG | ( | __HANDLE__ | ) | __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_NEF) |
| None |
| #define __HAL_SMARTCARD_CLEAR_OREFLAG | ( | __HANDLE__ | ) | __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_OREF) |
| None |
| #define __HAL_SMARTCARD_CLEAR_PEFLAG | ( | __HANDLE__ | ) | __HAL_SMARTCARD_CLEAR_FLAG((__HANDLE__), SMARTCARD_CLEAR_PEF) |
| None |
| #define __HAL_SMARTCARD_DISABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
| None |
| #define __HAL_SMARTCARD_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the SMARTCARD interrupt to disable. This parameter can be one of the following values:
| None |
| #define __HAL_SMARTCARD_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
| None |
| #define __HAL_SMARTCARD_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the SMARTCARD interrupt to enable. This parameter can be one of the following values:
| None |
| #define __HAL_SMARTCARD_FLUSH_DRREGISTER | ( | __HANDLE__ | ) |
| None |
| #define __HAL_SMARTCARD_GET_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| ) | (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of FLAG (TRUE or FALSE). |
| #define __HAL_SMARTCARD_GET_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the SMARTCARD interrupt to check. This parameter can be one of the following values:
| The | new state of INTERRUPT (SET or RESET). |
| #define __HAL_SMARTCARD_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the SMARTCARD interrupt source to check. This parameter can be one of the following values:
| #define __HAL_SMARTCARD_ONE_BIT_SAMPLE_DISABLE | ( | __HANDLE__ | ) |
| None |
| #define __HAL_SMARTCARD_ONE_BIT_SAMPLE_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
| None |
| #define __HAL_SMARTCARD_RESET_HANDLE_STATE | ( | __HANDLE__ | ) |
| __HANDLE__ | SMARTCARD handle. |
| None |
| #define __HAL_SMARTCARD_SEND_REQ | ( | __HANDLE__, | |
| __REQ__ | |||
| ) | ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
| __REQ__ | specifies the request flag to set This parameter can be one of the following values:
| None |
