RTEMS 6.1
The System Lock Mutex Support helps to implement directives which use data structures compatible with the data structures defined by the Newlib provided <sys/lock.h> header file. More...
Files | |
| file | muteximpl.h |
| This header file provides the interfaces of the System Lock Mutex Support. | |
| struct | Mutex_Control |
| struct | Mutex_recursive_Control |
