RTEMS 6.1
Files | Data Structures | Functions
Semaphore Handler
This group contains the Semaphore Handler implementation. More...
file  coresem.h
 This header file provides interfaces of the Semaphore Handler which are used by the implementation and the Application Configuration.
file  coresemimpl.h
 This header file provides interfaces of the Semaphore Handler which are only used by the implementation.
file  coresem.c
 This source file contains the implementation of _CORE_semaphore_Initialize().
struct  CORE_semaphore_Control
void _CORE_semaphore_Initialize (CORE_semaphore_Control *the_semaphore, uint32_t initial_value)
 Initializes the semaphore based on the parameters passed.
This handler encapsulates functionality which provides the foundation Semaphore services used in all of the APIs supported by RTEMS.
◆ _CORE_semaphore_Initialize()
void _CORE_semaphore_Initialize ( CORE_semaphore_Control the_semaphore,
This package is the implementation of the CORE Semaphore Handler. This core object utilizes standard Dijkstra counting semaphores to provide synchronization and mutual exclusion capabilities.
This routine initializes the semaphore based on the parameters passed.
Parameters
[out]the_semaphoreThe semaphore to initialize.
initial_valueThe initial count of the semaphore.
