RTEMS 6.1
Files | Data Structures | Macros | Functions
This group contains the Strong APA Scheduler implementation. More...
file  schedulerstrongapa.h
 This header file provides the interfaces of the Strong APA Scheduler.
file  schedulerstrongapa.c
 This source file contains the implementation of _Scheduler_strong_APA_Add_processor(), _Scheduler_strong_APA_Allocate_processor(), _Scheduler_strong_APA_Ask_for_help(), _Scheduler_strong_APA_Block(), _Scheduler_strong_APA_Do_ask_for_help(), _Scheduler_strong_APA_Do_enqueue(), _Scheduler_strong_APA_Do_set_affinity(), _Scheduler_strong_APA_Do_update(), _Scheduler_strong_APA_Enqueue(), _Scheduler_strong_APA_Enqueue_scheduled(), _Scheduler_strong_APA_Extract_from_ready(), _Scheduler_strong_APA_Extract_from_scheduled(), _Scheduler_strong_APA_Find_highest_ready(), _Scheduler_strong_APA_Get_highest_ready(), _Scheduler_strong_APA_Get_lowest_reachable(), _Scheduler_strong_APA_Get_lowest_scheduled(), _Scheduler_strong_APA_Has_ready(), _Scheduler_strong_APA_Initialize(), _Scheduler_strong_APA_Insert_ready(), _Scheduler_strong_APA_Move_from_ready_to_scheduled(), _Scheduler_strong_APA_Move_from_scheduled_to_ready(), _Scheduler_strong_APA_Node_initialize(), _Scheduler_strong_APA_Reconsider_help_request(), _Scheduler_strong_APA_Register_idle(), _Scheduler_strong_APA_Remove_processor(), _Scheduler_strong_APA_Set_affinity(), _Scheduler_strong_APA_Set_scheduled(), _Scheduler_strong_APA_Start_idle(), _Scheduler_strong_APA_Unblock(), _Scheduler_strong_APA_Update_priority(), _Scheduler_strong_APA_Withdraw_node(), _Scheduler_strong_APA_Make_sticky(), _Scheduler_strong_APA_Clean_sticky(), and _Scheduler_strong_APA_Yield().
struct  Scheduler_strong_APA_Node
 Scheduler node specialization for Strong APA schedulers. More...
struct  Scheduler_strong_APA_CPU
 CPU related variables and a CPU_Control to implement BFS. More...
struct  Scheduler_strong_APA_Context
 Scheduler context and node definition for Strong APA scheduler. More...
#define SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY   255
#define SCHEDULER_STRONG_APA_ENTRY_POINTS
 Entry points for the Strong APA Scheduler.
void _Scheduler_strong_APA_Initialize (const Scheduler_Control *scheduler)
 Initializes the scheduler.
void _Scheduler_strong_APA_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes the node with the given priority.
void _Scheduler_strong_APA_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Blocks the thread.
void _Scheduler_strong_APA_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Unblocks the thread.
void _Scheduler_strong_APA_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the node.
bool _Scheduler_strong_APA_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help.
void _Scheduler_strong_APA_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help request.
void _Scheduler_strong_APA_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws the node.
void _Scheduler_strong_APA_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Makes the node sticky.
void _Scheduler_strong_APA_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Cleans the sticky property from the node.
void _Scheduler_strong_APA_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
void _Scheduler_strong_APA_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds the idle thread to a processor.
Thread_Control_Scheduler_strong_APA_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu.
void _Scheduler_strong_APA_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Performs a yield operation.
void _Scheduler_strong_APA_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu)
 Starts an idle thread.
Status_Control _Scheduler_strong_APA_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, const Processor_mask *affinity)
 Sets the affinity .
This is an implementation of the Strong APA scheduler defined by Cerqueira et al. in Linux's Processor Affinity API, Refined: Shifting Real-Time Tasks Towards Higher Schedulability.
The scheduled and ready nodes are accessed via the Scheduler_strong_APA_Context::Ready which helps in backtracking when a node which is executing on a CPU gets blocked. New node is allocated to the cpu by checking all the executing nodes in the affinity set of the node and the subsequent nodes executing on the processors in its affinity set.
◆ SCHEDULER_STRONG_APA_ENTRY_POINTS
Value:
_Scheduler_default_Pin_or_unpin_not_supported, \
void _Scheduler_strong_APA_Yield(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition: schedulerstrongapa.c:879
Thread_Control * _Scheduler_strong_APA_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Definition: schedulerstrongapa.c:1101
void _Scheduler_strong_APA_Block(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Blocks the thread.
Definition: schedulerstrongapa.c:898
void _Scheduler_strong_APA_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Definition: schedulerstrongapa.c:1119
void _Scheduler_strong_APA_Make_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition: schedulerstrongapa.c:1020
void _Scheduler_strong_APA_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition: schedulerstrongapa.c:945
Status_Control _Scheduler_strong_APA_Set_affinity(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, const Processor_mask *affinity)
Sets the affinity .
Definition: schedulerstrongapa.c:1140
void _Scheduler_strong_APA_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Definition: schedulerstrongapa.c:1067
void _Scheduler_strong_APA_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition: schedulerstrongapa.c:927
void _Scheduler_strong_APA_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition: schedulerstrongapa.c:981
void _Scheduler_strong_APA_Start_idle(const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu)
Definition: schedulerstrongapa.c:1083
bool _Scheduler_strong_APA_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Asks for help.
Definition: schedulerstrongapa.c:966
void _Scheduler_strong_APA_Clean_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition: schedulerstrongapa.c:1035
void _Scheduler_strong_APA_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Withdraws the node.
Definition: schedulerstrongapa.c:997
void _Scheduler_strong_APA_Initialize(const Scheduler_Control *scheduler)
Definition: schedulerstrongapa.c:870
void _Scheduler_default_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Does nothing.
Definition: schedulerdefaultreleasejob.c:44
void _Scheduler_default_Node_destroy(const Scheduler_Control *scheduler, Scheduler_Node *node)
Does nothing.
Definition: schedulerdefaultnodedestroy.c:45
Priority_Control _Scheduler_default_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP().
Definition: schedulerdefaultmappriority.c:43
void _Scheduler_default_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Does nothing.
Definition: schedulerdefaultschedule.c:43
Priority_Control _Scheduler_default_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP().
Definition: schedulerdefaultmappriority.c:51
void _Scheduler_default_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Does nothing.
Definition: schedulerdefaultreleasejob.c:59
◆ _Scheduler_strong_APA_Add_processor()
void _Scheduler_strong_APA_Add_processor ( const Scheduler_Control scheduler,
Thread_Control idle
Parameters
schedulerThe scheduler control instance.
[in,out]Theidle thread to add to the processor.
◆ _Scheduler_strong_APA_Ask_for_help()
bool _Scheduler_strong_APA_Ask_for_help ( const Scheduler_Control scheduler,
Thread_Control the_thread,
Scheduler_Node node
Asks for help.
Parameters
the_threadThe thread that asks for help.
nodeThe node of the_thread.
Return values
trueThe request for help was successful.
falseThe request for help was not successful.
◆ _Scheduler_strong_APA_Block()
void _Scheduler_strong_APA_Block ( const Scheduler_Control scheduler,
Scheduler_Node node
Blocks the thread.
Parameters
[in,out]the_threadThe thread to block.
[in,out]nodeThe node of the thread to block.
◆ _Scheduler_strong_APA_Clean_sticky()
void _Scheduler_strong_APA_Clean_sticky ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
scheduleris the scheduler of the node.
[in,out]the_threadis the thread owning the node.
[in,out]nodeis the scheduler node to clean the sticky property.
◆ _Scheduler_strong_APA_Initialize()
void _Scheduler_strong_APA_Initialize ( const Scheduler_Control scheduler)
Parameters
schedulerThe scheduler to initialize.
◆ _Scheduler_strong_APA_Make_sticky()
void _Scheduler_strong_APA_Make_sticky ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
[in,out]nodeis the scheduler node to make sticky.
Parameters
◆ _Scheduler_strong_APA_Node_initialize()
void _Scheduler_strong_APA_Node_initialize ( const Scheduler_Control scheduler,
Scheduler_Node node,
Parameters
[out]nodeThe node to initialize.
the_threadThe thread of the node to initialize.
priorityThe priority for node.
◆ _Scheduler_strong_APA_Reconsider_help_request()
void _Scheduler_strong_APA_Reconsider_help_request ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
the_threadThe thread to reconsider the help request of.
[in,out]nodeThe node of the_thread
◆ _Scheduler_strong_APA_Remove_processor()
Thread_Control * _Scheduler_strong_APA_Remove_processor ( const Scheduler_Control scheduler,
struct Per_CPU_Control cpu
Parameters
schedulerThe scheduler instance.
cpuThe cpu control to remove from scheduler.
Returns
The idle thread of the processor.
◆ _Scheduler_strong_APA_Set_affinity()
Status_Control _Scheduler_strong_APA_Set_affinity ( const Scheduler_Control scheduler,
Thread_Control thread,
Scheduler_Node node_base,
const Processor_mask *  affinity
Sets the affinity .
Parameters
the_threadThe thread to yield.
[in,out]nodeThe node of the_thread.
◆ _Scheduler_strong_APA_Start_idle()
void _Scheduler_strong_APA_Start_idle ( const Scheduler_Control scheduler,
Thread_Control idle,
Parameters
[in,out]the_threadAn idle thread.
cpuThe cpu for the operation.
◆ _Scheduler_strong_APA_sticky()
void _Scheduler_strong_APA_sticky ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
◆ _Scheduler_strong_APA_Unblock()
void _Scheduler_strong_APA_Unblock ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
[in,out]the_threadThe thread to unblock.
[in,out]nodeThe node of the thread to unblock.
◆ _Scheduler_strong_APA_Update_priority()
void _Scheduler_strong_APA_Update_priority ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
the_threadThe thread for the operation.
[in,out]nodeThe node to update the priority of.
◆ _Scheduler_strong_APA_Withdraw_node()
void _Scheduler_strong_APA_Withdraw_node ( const Scheduler_Control scheduler,
Withdraws the node.
Parameters
[in,out]the_threadThe thread to change the state to next_state.
[in,out]nodeThe node to withdraw.
next_stateThe next state for the_thread.
◆ _Scheduler_strong_APA_Yield()
void _Scheduler_strong_APA_Yield ( const Scheduler_Control scheduler,
Scheduler_Node node
Parameters
