RTEMS 6.1
This group contains the EDF Scheduler implementation. More...
Files | |
| file | scheduleredf.h |
| This header file provides interfaces of the EDF Scheduler which are used by the implementation and the Application Configuration. | |
| file | scheduleredfimpl.h |
| This header file provides interfaces of the EDF Scheduler which are only used by the implementation. | |
| file | scheduleredf.c |
| This source file contains the implementation of _Scheduler_EDF_Initialize(). | |
| file | scheduleredfblock.c |
| This source file contains the implementation of _Scheduler_EDF_Block(). | |
| file | scheduleredfchangepriority.c |
| This source file contains the implementation of _Scheduler_EDF_Update_priority(). | |
| file | scheduleredfnodeinit.c |
| This source file contains the implementation of _Scheduler_EDF_Node_initialize(). | |
| file | scheduleredfreleasejob.c |
| This source file contains the implementation of _Scheduler_EDF_Map_priority(), _Scheduler_EDF_Unmap_priority(), _Scheduler_EDF_Release_job(), and _Scheduler_EDF_Cancel_job(). | |
| file | scheduleredfschedule.c |
| This source file contains the implementation of _Scheduler_EDF_Schedule(). | |
| file | scheduleredfunblock.c |
| This source file contains the implementation of _Scheduler_EDF_Unblock(). | |
| file | scheduleredfyield.c |
| This source file contains the implementation of _Scheduler_EDF_Yield(). | |
| struct | Scheduler_EDF_Context |
| struct | Scheduler_EDF_Node |
| Scheduler node specialization for EDF schedulers. More... | |
| #define | SCHEDULER_EDF_MAXIMUM_PRIORITY INT_MAX |
| #define | SCHEDULER_EDF_ENTRY_POINTS |
| #define | SCHEDULER_EDF_PRIO_MSB 0x8000000000000000 |
| void | _Scheduler_EDF_Initialize (const Scheduler_Control *scheduler) |
| Initializes EDF scheduler. | |
| void | _Scheduler_EDF_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Removes the blocking thread from the ready queue and schedules is only again if the thread is executing or the heir thread. | |
| void | _Scheduler_EDF_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Sets the heir thread to be the next ready thread in the rbtree ready queue. | |
| void | _Scheduler_EDF_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes an EDF specific scheduler node of the_thread. | |
| void | _Scheduler_EDF_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Performs an unblocking of the thread. | |
| void | _Scheduler_EDF_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the scheduler node. | |
| Priority_Control | _Scheduler_EDF_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Gets the mapped priority map of the priority control. | |
| Priority_Control | _Scheduler_EDF_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Gets the unmapped priority map of the priority control. | |
| void | _Scheduler_EDF_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Executes a thread yield for the thread. | |
| void | _Scheduler_EDF_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
| Releases a EDF job. | |
| void | _Scheduler_EDF_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| Cancels a job and removes the thread from the queue context. | |
| #define SCHEDULER_EDF_ENTRY_POINTS |
Entry points for the Earliest Deadline First Scheduler.
| #define SCHEDULER_EDF_PRIO_MSB 0x8000000000000000 |
This is just a most significant bit of Priority_Control type. It distinguishes threads which are deadline driven (priority represented by a lower number than SCHEDULER_EDF_PRIO_MSB) from those ones who do not have any deadlines and thus are considered background tasks.
| void _Scheduler_EDF_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Scheduler_Node * | node | ||
| [in,out] | scheduler | The scheduler for the operation. |
| the_thread | The thread to operate upon. | |
| [in,out] | node | The scheduler node for this thread. |
| void _Scheduler_EDF_Cancel_job | ( | const Scheduler_Control * | scheduler, |
| Priority_Node * | priority_node, | ||
| Thread_queue_Context * | queue_context | ||
| scheduler | The scheduler instance. | |
| the_thread | The thread for the operation. | |
| [in,out] | priority_node | The corresponding priority node. |
| [in,out] | queue_context | The thread queue context. |
| void _Scheduler_EDF_Initialize | ( | const Scheduler_Control * | scheduler | ) |
This routine initializes the EDF scheduler.
| [in,out] | scheduler | The scheduler instance. |
| Priority_Control _Scheduler_EDF_Map_priority | ( | const Scheduler_Control * | scheduler, |
| Priority_Control | priority | ||
| scheduler | Not used in this operation. |
| priority | The priority control to get the priority map of. |
| void _Scheduler_EDF_Node_initialize | ( | const Scheduler_Control * | scheduler, |
| Scheduler_Node * | node, | ||
| node | The node being initialized. |
| the_thread | The thread of the node. |
| priority | The thread priority. |
| void _Scheduler_EDF_Release_job | ( | const Scheduler_Control * | scheduler, |
| uint64_t | deadline, | ||
Releases a EDF job.
| scheduler | The scheduler instance | |
| the_thread | The thread | |
| [in,out] | priority_node | The priority node for the operation. |
| deadline | The deadline for the job. | |
| void _Scheduler_EDF_Schedule | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread | ||
This kernel routine sets the heir thread to be the next ready thread in the rbtree ready queue.
| the_thread | The thread being scheduled. |
| void _Scheduler_EDF_Unblock | ( | const Scheduler_Control * | scheduler, |
| the_thread | The unblocking thread. May be set as new heir. | |
| [in,out] | node | The scheduler node for the thread. |
| Priority_Control _Scheduler_EDF_Unmap_priority | ( | const Scheduler_Control * | scheduler, |
| void _Scheduler_EDF_Update_priority | ( | const Scheduler_Control * | scheduler, |
| [in,out] | node | The priority node to update the priority of. |
| void _Scheduler_EDF_Yield | ( | const Scheduler_Control * | scheduler, |
| the_thread | The thread that performs the yield. | |
