RTEMS 6.1
Files | Data Structures | Macros | Enumerations | Functions
Read-Write Lock
This group contains the Read-Write Lock implementation. More...
file  corerwlockimpl.h
 This header file provides interfaces of the Read-Write Lock which are only used by the implementation.
file  corerwlock.c
 This source file contains the implementation of _CORE_RWLock_Initialize().
file  corerwlockobtainread.c
 This source file contains the implementation of _CORE_RWLock_Seize_for_reading().
file  corerwlockobtainwrite.c
 This source file contains the implementation of _CORE_RWLock_Seize_for_writing().
file  corerwlockrelease.c
 This source file contains the implementation of _CORE_RWLock_Surrender().
struct  CORE_RWLock_Control
#define CORE_RWLOCK_TQ_OPERATIONS   &_Thread_queue_Operations_FIFO
#define CORE_RWLOCK_THREAD_WAITING_FOR_READ   0
#define CORE_RWLOCK_THREAD_WAITING_FOR_WRITE   1
enum  CORE_RWLock_States { CORE_RWLOCK_UNLOCKED , CORE_RWLOCK_LOCKED_FOR_READING , CORE_RWLOCK_LOCKED_FOR_WRITING }
void _CORE_RWLock_Initialize (CORE_RWLock_Control *the_rwlock)
 Initializes a RWlock.
Status_Control _CORE_RWLock_Seize_for_reading (CORE_RWLock_Control *the_rwlock, bool wait, Thread_queue_Context *queue_context)
 Obtains RWLock for reading.
Status_Control _CORE_RWLock_Seize_for_writing (CORE_RWLock_Control *the_rwlock, bool wait, Thread_queue_Context *queue_context)
 Obtains RWLock for writing.
Status_Control _CORE_RWLock_Surrender (CORE_RWLock_Control *the_rwlock)
 Releases the RWLock.
◆ CORE_RWLOCK_THREAD_WAITING_FOR_READ
This is used to denote that a thread is blocking waiting for read-only access to the RWLock.
◆ CORE_RWLOCK_THREAD_WAITING_FOR_WRITE
This is used to denote that a thread is blocking waiting for write-exclusive access to the RWLock.
◆ CORE_RWLock_States
RWLock State.
This indicates the the RWLock is not currently locked.
This indicates the the RWLock is currently locked for reading.
◆ _CORE_RWLock_Initialize()
void _CORE_RWLock_Initialize ( CORE_RWLock_Control the_rwlock)
This routine initializes the RWLock.
Parameters
[out]the_rwlockis the RWLock to initialize.
◆ _CORE_RWLock_Seize_for_reading()
Status_Control _CORE_RWLock_Seize_for_reading ( CORE_RWLock_Control the_rwlock,
bool  wait,
Thread_queue_Context queue_context
This routine attempts to obtain the RWLock for read access.
Parameters
[in,out]the_rwlockis the RWLock to wait for
waitIndicates whether the calling thread is willing to wait.
queue_contextThe thread queue context.
Return values
STATUS_SUCCESSFULThe RWlock was successfully seized.
STATUS_UNAVAILABLEThe RWlock is currently locked for writing and the calling thread is not willing to wait.
STATUS_TIMEOUTA timeout occurred.
◆ _CORE_RWLock_Seize_for_writing()
Status_Control _CORE_RWLock_Seize_for_writing ( CORE_RWLock_Control the_rwlock,
bool  wait,
This routine attempts to obtain the RWLock for write exclusive access.
Parameters
[in,out]the_rwlockThe RWLock to wait for.
Return values
STATUS_SUCCESSFULThe RWLock was successfully obtained for write exclusive access.
STATUS_UNAVAILABLEThe RWlock is currently locked and the calling thread is not willing to wait.
◆ _CORE_RWLock_Surrender()
Status_Control _CORE_RWLock_Surrender ( CORE_RWLock_Control the_rwlock)
This routine manually releases the_rwlock. All of the threads waiting for the RWLock will be readied.
Parameters
[in,out]the_rwlockThe RWLock to surrender.
Returns
STATUS_SUCCESSFUL This method is always successful.
