RTEMS 6.1
#define I386_DISABLE_INLINE_ISR_DISABLE_ENABLE
This handler encapulates the functionality (primarily conditional feature defines) related to paravirtualization on the i386.
Paravirtualization on the i386 makes the following assumptions:
◆ I386_DISABLE_INLINE_ISR_DISABLE_ENABLE
In a paravirtualized environment, RTEMS executes in user space and cannot disable/enable external exceptions (e.g. interrupts). The BSP which acts as an adapter to the hosting environment will provide the interrupt enable/disable methods.
