This group contains the gocv support.
More...
| RTEMS_LINKER_ROSET_DECLARE (gcov_info, const struct gcov_info *) |
| void | _Gcov_Dump_info (IO_Put_char put_char, void *arg) |
| | Dumps the gcov information as a binary gcfn and gcda data stream using the put character handler.
| void | _Gcov_Dump_info_base64 (IO_Put_char put_char, void *arg) |
| | Dumps the gcov information as a base64 encoded gcfn and gcda data stream using the put character handler.
◆ _Gcov_Dump_info()
| void _Gcov_Dump_info |
IO_Put_char |
put_char, |
void * |
arg |
- Parameters
| put_char | is the put character handler used to output the data stream. |
| arg | is the argument passed to the put character handler. |
◆ _Gcov_Dump_info_base64()
| void _Gcov_Dump_info_base64 |
IO_Put_char |
put_char, |
void * |
arg |
- Parameters
