RTEMS 6.1
This group contains the I/O Manager implementation. More...
Files | |
| file | ioimpl.h |
| This header file provides interfaces used by the I/O Manager implementation. | |
| file | io.c |
| This source file contains the definition of _IO_All_drivers_initialized and implementation of _IO_Initialize_all_drivers(). | |
| file | ioclose.c |
| This source file contains the implementation of rtems_io_close(). | |
| file | iocontrol.c |
| This source file contains the implementation of rtems_io_control(). | |
| file | iodefault.c |
| This source file contains a definition of _IO_Driver_address_table and _IO_Number_of_drivers with zero drivers. | |
| file | ioinitialize.c |
| This source file contains the implementation of rtems_io_initialize(). | |
| file | ioopen.c |
| This source file contains the implementation of rtems_io_open(). | |
| file | ioread.c |
| This source file contains the implementation of rtems_io_read(). | |
| file | ioregisterdriver.c |
| This source file contains the implementation of rtems_io_register_driver(). | |
| file | iounregisterdriver.c |
| This source file contains the implementation of rtems_io_unregister_driver(). | |
| file | iowrite.c |
| This source file contains the implementation of rtems_io_write(). | |
| void | _IO_Initialize_all_drivers (void) |
| Initialization of all device drivers. | |
| const size_t | _IO_Number_of_drivers |
| rtems_driver_address_table | _IO_Driver_address_table [] |
| bool | _IO_All_drivers_initialized |
| void _IO_Initialize_all_drivers | ( | void | ) |
Initializes all device drivers.
