RTEMS 6.1
Files | Data Structures | Macros | Variables
Barrier Manager
This group contains the Barrier Manager implementation. More...
file  barrier.h
 This header file defines the Barrier Manager API.
file  barrierdata.h
 This header file provides data structures used by the implementation and the Application Configuration to define _Barrier_Information.
file  barrierimpl.h
 This header file provides the implementation interfaces of the Barrier Manager.
file  barrier.c
 This source file contains a definition of the _Barrier_Information with zero objects.
file  barriercreate.c
 This source file contains the implementation of rtems_barrier_create() and the Barrier Manager system initialization.
file  barrierdelete.c
 This source file contains the implementation of rtems_barrier_delete().
file  barrierident.c
 This source file contains the implementation of rtems_barrier_ident().
file  barrierrelease.c
 This source file contains the implementation of rtems_barrier_release().
file  barrierwait.c
 This source file contains the implementation of rtems_barrier_wait().
struct  Barrier_Control
#define BARRIER_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Barrier objects.
Objects_Information _Barrier_Information
 The Classic Barrier objects information.
◆ BARRIER_INFORMATION_DEFINE
#define BARRIER_INFORMATION_DEFINE (   max)
Value:
_Barrier, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_BARRIERS, \
max, \
NULL \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:123
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:449
Definition: barrierdata.h:58
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
