RTEMS 6.1
This group contains the implementation to support directive attributes. More...
Files | |
| file | attr.h |
| This header file provides Classic API directive attributes. | |
| file | attrimpl.h |
| This header file provides the implementation interfaces of the Directive Attributes support. | |
| #define | ATTRIBUTES_NOT_SUPPORTED 0 |
| #define | ATTRIBUTES_REQUIRED RTEMS_FLOATING_POINT |
| #define ATTRIBUTES_NOT_SUPPORTED 0 |
This attribute constant indicates the attributes that are not supportable given the hardware configuration.
| #define ATTRIBUTES_REQUIRED RTEMS_FLOATING_POINT |
This attribute constant indicates the attributes that are required given the hardware configuration.
