RTEMS 6.1
PCI trace Ctrl signal pattern register (TCP)
This group contains register bit definitions. More...
#define GRPCI2_TCP_CBE_3_0_SHIFT   16
#define GRPCI2_TCP_CBE_3_0_MASK   0xf0000U
#define GRPCI2_TCP_CBE_3_0_GET(_reg)
#define GRPCI2_TCP_CBE_3_0_SET(_reg, _val)
#define GRPCI2_TCP_CBE_3_0(_val)
#define GRPCI2_TCP_FRAME   0x8000U
#define GRPCI2_TCP_IRDY   0x4000U
#define GRPCI2_TCP_TRDY   0x2000U
#define GRPCI2_TCP_STOP   0x1000U
#define GRPCI2_TCP_DEVSEL   0x800U
#define GRPCI2_TCP_PAR   0x400U
#define GRPCI2_TCP_PERR   0x200U
#define GRPCI2_TCP_SERR   0x100U
#define GRPCI2_TCP_IDSEL   0x80U
#define GRPCI2_TCP_REQ   0x40U
#define GRPCI2_TCP_GNT   0x20U
#define GRPCI2_TCP_LOCK   0x10U
#define GRPCI2_TCP_RST   0x8U
◆ GRPCI2_TCP_CBE_3_0
#define GRPCI2_TCP_CBE_3_0 (   _val)
Value:
( ( ( _val ) << GRPCI2_TCP_CBE_3_0_SHIFT ) & \
GRPCI2_TCP_CBE_3_0_MASK )
◆ GRPCI2_TCP_CBE_3_0_GET
#define GRPCI2_TCP_CBE_3_0_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_TCP_CBE_3_0_MASK ) >> \
◆ GRPCI2_TCP_CBE_3_0_SET
#define GRPCI2_TCP_CBE_3_0_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_TCP_CBE_3_0_MASK ) | \
GRPCI2_TCP_CBE_3_0_MASK ) )
