RTEMS 6.1
PCI trace PCI AD state register (TADS)
This group contains register bit definitions. More...
#define GRPCI2_TADS_SIGNAL_SHIFT   0
#define GRPCI2_TADS_SIGNAL_MASK   0xffffffffU
#define GRPCI2_TADS_SIGNAL_GET(_reg)
#define GRPCI2_TADS_SIGNAL_SET(_reg, _val)
#define GRPCI2_TADS_SIGNAL(_val)
◆ GRPCI2_TADS_SIGNAL
#define GRPCI2_TADS_SIGNAL (   _val)
Value:
( ( ( _val ) << GRPCI2_TADS_SIGNAL_SHIFT ) & \
GRPCI2_TADS_SIGNAL_MASK )
◆ GRPCI2_TADS_SIGNAL_GET
#define GRPCI2_TADS_SIGNAL_GET (   _reg)
Value:
( ( ( _reg ) & GRPCI2_TADS_SIGNAL_MASK ) >> \
◆ GRPCI2_TADS_SIGNAL_SET
#define GRPCI2_TADS_SIGNAL_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRPCI2_TADS_SIGNAL_MASK ) | \
GRPCI2_TADS_SIGNAL_MASK ) )
