This group contains register bit definitions.
More...
◆ GRPCI2_CTRL_BUS_NUMBER
| #define GRPCI2_CTRL_BUS_NUMBER |
_val | ) |
Value: ( ( ( _val ) << GRPCI2_CTRL_BUS_NUMBER_SHIFT ) & \
GRPCI2_CTRL_BUS_NUMBER_MASK )
◆ GRPCI2_CTRL_BUS_NUMBER_GET
| #define GRPCI2_CTRL_BUS_NUMBER_GET |
_reg | ) |
Value: ( ( ( _reg ) & GRPCI2_CTRL_BUS_NUMBER_MASK ) >> \
◆ GRPCI2_CTRL_BUS_NUMBER_SET
| #define GRPCI2_CTRL_BUS_NUMBER_SET |
_reg, |
_val |
Value: ( ( ( _reg ) & ~GRPCI2_CTRL_BUS_NUMBER_MASK ) | \
GRPCI2_CTRL_BUS_NUMBER_MASK ) )
◆ GRPCI2_CTRL_DEVICE_INT_MASK
| #define GRPCI2_CTRL_DEVICE_INT_MASK |
_val | ) |
Value: ( ( ( _val ) << GRPCI2_CTRL_DEVICE_INT_MASK_SHIFT ) & \
GRPCI2_CTRL_DEVICE_INT_MASK_MASK )
◆ GRPCI2_CTRL_DEVICE_INT_MASK_GET
| #define GRPCI2_CTRL_DEVICE_INT_MASK_GET |
_reg | ) |
Value: ( ( ( _reg ) & GRPCI2_CTRL_DEVICE_INT_MASK_MASK ) >> \
◆ GRPCI2_CTRL_DEVICE_INT_MASK_SET
| #define GRPCI2_CTRL_DEVICE_INT_MASK_SET |
_reg, |
_val |
Value: ( ( ( _reg ) & ~GRPCI2_CTRL_DEVICE_INT_MASK_MASK ) | \
GRPCI2_CTRL_DEVICE_INT_MASK_MASK ) )
◆ GRPCI2_CTRL_HOST_INT_MASK
| #define GRPCI2_CTRL_HOST_INT_MASK |
_val | ) |
Value: ( ( ( _val ) << GRPCI2_CTRL_HOST_INT_MASK_SHIFT ) & \
GRPCI2_CTRL_HOST_INT_MASK_MASK )
◆ GRPCI2_CTRL_HOST_INT_MASK_GET
| #define GRPCI2_CTRL_HOST_INT_MASK_GET |
_reg | ) |
Value: ( ( ( _reg ) & GRPCI2_CTRL_HOST_INT_MASK_MASK ) >> \
◆ GRPCI2_CTRL_HOST_INT_MASK_SET
| #define GRPCI2_CTRL_HOST_INT_MASK_SET |
_reg, |
_val |
Value: ( ( ( _reg ) & ~GRPCI2_CTRL_HOST_INT_MASK_MASK ) | \
GRPCI2_CTRL_HOST_INT_MASK_MASK ) )
