RTEMS 6.1
Modules | Files | Data Structures | Typedefs
This group contains the GRIOMMU interfaces. More...
 AHB failing access register (AHBFAS)
 This group contains register bit definitions.
 ASMP access control registers 0 - 3 (ASMPCTRL)
 Capability register 0 (CAP0)
 Capability register 1 (CAP1)
 Capability register 2 (CAP2)
 Control register (CTRL)
 Data RAM error injection register (DERRI)
 Diagnostic cache access data register 0 - 7 (DIAGD)
 Diagnostic cache access register (DIAGCTRL)
 Diagnostic cache access tag register (DIAGT)
 Group control register 0 - 7 (GRPCTRL)
 Interrupt mask register (IMASK)
 Master configuration register 0 - 9 (MSTCFG)
 Status register (STATUS)
 TLB/cache flush register (FLUSH)
 Tag RAM error injection register (TERRI)
file  griommu-regs.h
 This header file defines the GRIOMMU register block interface.
struct  griommu
 This structure defines the GRIOMMU register block memory map. More...
typedef struct griommu griommu
