RTEMS 6.1
Data Structures | Macros | Typedefs
griommu-regs.h File Reference
This header file defines the GRIOMMU register block interface. More...
#include <stdint.h>
struct  griommu
 This structure defines the GRIOMMU register block memory map. More...
#define GRIOMMU_CAP0_A   0x80000000U
#define GRIOMMU_CAP0_AC   0x40000000U
#define GRIOMMU_CAP0_CA   0x20000000U
#define GRIOMMU_CAP0_CP   0x10000000U
#define GRIOMMU_CAP0_NARB_SHIFT   20
#define GRIOMMU_CAP0_NARB_MASK   0xf00000U
#define GRIOMMU_CAP0_NARB_GET(_reg)
#define GRIOMMU_CAP0_NARB_SET(_reg, _val)
#define GRIOMMU_CAP0_NARB(_val)
#define GRIOMMU_CAP0_CS   0x80000U
#define GRIOMMU_CAP0_FT_SHIFT   17
#define GRIOMMU_CAP0_FT_MASK   0x60000U
#define GRIOMMU_CAP0_FT_GET(_reg)
#define GRIOMMU_CAP0_FT_SET(_reg, _val)
#define GRIOMMU_CAP0_FT(_val)
#define GRIOMMU_CAP0_ST   0x10000U
#define GRIOMMU_CAP0_I   0x8000U
#define GRIOMMU_CAP0_IT   0x4000U
#define GRIOMMU_CAP0_IA   0x2000U
#define GRIOMMU_CAP0_IP   0x1000U
#define GRIOMMU_CAP0_MB   0x100U
#define GRIOMMU_CAP0_GRPS_SHIFT   4
#define GRIOMMU_CAP0_GRPS_MASK   0xf0U
#define GRIOMMU_CAP0_GRPS_GET(_reg)
#define GRIOMMU_CAP0_GRPS_SET(_reg, _val)
#define GRIOMMU_CAP0_GRPS(_val)
#define GRIOMMU_CAP0_MSTS_SHIFT   0
#define GRIOMMU_CAP0_MSTS_MASK   0xfU
#define GRIOMMU_CAP0_MSTS_GET(_reg)
#define GRIOMMU_CAP0_MSTS_SET(_reg, _val)
#define GRIOMMU_CAP0_MSTS(_val)
#define GRIOMMU_CAP1_CADDR_SHIFT   20
#define GRIOMMU_CAP1_CADDR_MASK   0xfff00000U
#define GRIOMMU_CAP1_CADDR_GET(_reg)
#define GRIOMMU_CAP1_CADDR_SET(_reg, _val)
#define GRIOMMU_CAP1_CADDR(_val)
#define GRIOMMU_CAP1_CMASK_SHIFT   16
#define GRIOMMU_CAP1_CMASK_MASK   0xf0000U
#define GRIOMMU_CAP1_CMASK_GET(_reg)
#define GRIOMMU_CAP1_CMASK_SET(_reg, _val)
#define GRIOMMU_CAP1_CMASK(_val)
#define GRIOMMU_CAP1_CTAGBITS_SHIFT   8
#define GRIOMMU_CAP1_CTAGBITS_MASK   0xff00U
#define GRIOMMU_CAP1_CTAGBITS_GET(_reg)
#define GRIOMMU_CAP1_CTAGBITS_SET(_reg, _val)
#define GRIOMMU_CAP1_CTAGBITS(_val)
#define GRIOMMU_CAP1_CISIZE_SHIFT   5
#define GRIOMMU_CAP1_CISIZE_MASK   0xe0U
#define GRIOMMU_CAP1_CISIZE_GET(_reg)
#define GRIOMMU_CAP1_CISIZE_SET(_reg, _val)
#define GRIOMMU_CAP1_CISIZE(_val)
#define GRIOMMU_CAP1_CLINES_SHIFT   0
#define GRIOMMU_CAP1_CLINES_MASK   0x1fU
#define GRIOMMU_CAP1_CLINES_GET(_reg)
#define GRIOMMU_CAP1_CLINES_SET(_reg, _val)
#define GRIOMMU_CAP1_CLINES(_val)
#define GRIOMMU_CAP2_TMASK_SHIFT   24
#define GRIOMMU_CAP2_TMASK_MASK   0xff000000U
#define GRIOMMU_CAP2_TMASK_GET(_reg)
#define GRIOMMU_CAP2_TMASK_SET(_reg, _val)
#define GRIOMMU_CAP2_TMASK(_val)
#define GRIOMMU_CAP2_MTYPE_SHIFT   18
#define GRIOMMU_CAP2_MTYPE_MASK   0xc0000U
#define GRIOMMU_CAP2_MTYPE_GET(_reg)
#define GRIOMMU_CAP2_MTYPE_SET(_reg, _val)
#define GRIOMMU_CAP2_MTYPE(_val)
#define GRIOMMU_CAP2_TTYPE_SHIFT   16
#define GRIOMMU_CAP2_TTYPE_MASK   0x30000U
#define GRIOMMU_CAP2_TTYPE_GET(_reg)
#define GRIOMMU_CAP2_TTYPE_SET(_reg, _val)
#define GRIOMMU_CAP2_TTYPE(_val)
#define GRIOMMU_CAP2_TTAGBITS_SHIFT   8
#define GRIOMMU_CAP2_TTAGBITS_MASK   0xff00U
#define GRIOMMU_CAP2_TTAGBITS_GET(_reg)
#define GRIOMMU_CAP2_TTAGBITS_SET(_reg, _val)
#define GRIOMMU_CAP2_TTAGBITS(_val)
#define GRIOMMU_CAP2_ISIZE_SHIFT   5
#define GRIOMMU_CAP2_ISIZE_MASK   0xe0U
#define GRIOMMU_CAP2_ISIZE_GET(_reg)
#define GRIOMMU_CAP2_ISIZE_SET(_reg, _val)
#define GRIOMMU_CAP2_ISIZE(_val)
#define GRIOMMU_CAP2_TLBENT_SHIFT   0
#define GRIOMMU_CAP2_TLBENT_MASK   0x1fU
#define GRIOMMU_CAP2_TLBENT_GET(_reg)
#define GRIOMMU_CAP2_TLBENT_SET(_reg, _val)
#define GRIOMMU_CAP2_TLBENT(_val)
#define GRIOMMU_CTRL_PGSZ_SHIFT   18
#define GRIOMMU_CTRL_PGSZ_MASK   0x1c0000U
#define GRIOMMU_CTRL_PGSZ_GET(_reg)
#define GRIOMMU_CTRL_PGSZ_SET(_reg, _val)
#define GRIOMMU_CTRL_PGSZ(_val)
#define GRIOMMU_CTRL_LB   0x20000U
#define GRIOMMU_CTRL_SP   0x10000U
#define GRIOMMU_CTRL_ITR_SHIFT   12
#define GRIOMMU_CTRL_ITR_MASK   0xf000U
#define GRIOMMU_CTRL_ITR_GET(_reg)
#define GRIOMMU_CTRL_ITR_SET(_reg, _val)
#define GRIOMMU_CTRL_ITR(_val)
#define GRIOMMU_CTRL_DP   0x800U
#define GRIOMMU_CTRL_SIV   0x400U
#define GRIOMMU_CTRL_HPROT_SHIFT   8
#define GRIOMMU_CTRL_HPROT_MASK   0x300U
#define GRIOMMU_CTRL_HPROT_GET(_reg)
#define GRIOMMU_CTRL_HPROT_SET(_reg, _val)
#define GRIOMMU_CTRL_HPROT(_val)
#define GRIOMMU_CTRL_AU   0x80U
#define GRIOMMU_CTRL_WP   0x40U
#define GRIOMMU_CTRL_DM   0x20U
#define GRIOMMU_CTRL_GS   0x10U
#define GRIOMMU_CTRL_CE   0x8U
#define GRIOMMU_CTRL_PM_SHIFT   1
#define GRIOMMU_CTRL_PM_MASK   0x6U
#define GRIOMMU_CTRL_PM_GET(_reg)
#define GRIOMMU_CTRL_PM_SET(_reg, _val)
#define GRIOMMU_CTRL_PM(_val)
#define GRIOMMU_CTRL_EN   0x1U
#define GRIOMMU_FLUSH_FGRP_SHIFT   4
#define GRIOMMU_FLUSH_FGRP_MASK   0xf0U
#define GRIOMMU_FLUSH_FGRP_GET(_reg)
#define GRIOMMU_FLUSH_FGRP_SET(_reg, _val)
#define GRIOMMU_FLUSH_FGRP(_val)
#define GRIOMMU_FLUSH_GF   0x2U
#define GRIOMMU_FLUSH_F   0x1U
#define GRIOMMU_STATUS_PE   0x20U
#define GRIOMMU_STATUS_DE   0x10U
#define GRIOMMU_STATUS_FC   0x8U
#define GRIOMMU_STATUS_FL   0x4U
#define GRIOMMU_STATUS_AD   0x2U
#define GRIOMMU_STATUS_TE   0x1U
#define GRIOMMU_IMASK_PEI   0x20U
#define GRIOMMU_IMASK_FCI   0x8U
#define GRIOMMU_IMASK_FLI   0x4U
#define GRIOMMU_IMASK_ADI   0x2U
#define GRIOMMU_IMASK_TEI   0x1U
#define GRIOMMU_AHBFAS_FADDR_31_5_SHIFT   5
#define GRIOMMU_AHBFAS_FADDR_31_5_MASK   0xffffffe0U
#define GRIOMMU_AHBFAS_FADDR_31_5_GET(_reg)
#define GRIOMMU_AHBFAS_FADDR_31_5_SET(_reg, _val)
#define GRIOMMU_AHBFAS_FADDR_31_5(_val)
#define GRIOMMU_AHBFAS_FW   0x10U
#define GRIOMMU_AHBFAS_FMASTER_SHIFT   0
#define GRIOMMU_AHBFAS_FMASTER_MASK   0xfU
#define GRIOMMU_AHBFAS_FMASTER_GET(_reg)
#define GRIOMMU_AHBFAS_FMASTER_SET(_reg, _val)
#define GRIOMMU_AHBFAS_FMASTER(_val)
#define GRIOMMU_MSTCFG_VENDOR_SHIFT   24
#define GRIOMMU_MSTCFG_VENDOR_MASK   0xff000000U
#define GRIOMMU_MSTCFG_VENDOR_GET(_reg)
#define GRIOMMU_MSTCFG_VENDOR_SET(_reg, _val)
#define GRIOMMU_MSTCFG_VENDOR(_val)
#define GRIOMMU_MSTCFG_DEVICE_SHIFT   12
#define GRIOMMU_MSTCFG_DEVICE_MASK   0xfff000U
#define GRIOMMU_MSTCFG_DEVICE_GET(_reg)
#define GRIOMMU_MSTCFG_DEVICE_SET(_reg, _val)
#define GRIOMMU_MSTCFG_DEVICE(_val)
#define GRIOMMU_MSTCFG_BS   0x10U
#define GRIOMMU_MSTCFG_GROUP_SHIFT   0
#define GRIOMMU_MSTCFG_GROUP_MASK   0xfU
#define GRIOMMU_MSTCFG_GROUP_GET(_reg)
#define GRIOMMU_MSTCFG_GROUP_SET(_reg, _val)
#define GRIOMMU_MSTCFG_GROUP(_val)
#define GRIOMMU_GRPCTRL_BASE_31_4_SHIFT   4
#define GRIOMMU_GRPCTRL_BASE_31_4_MASK   0xfffffff0U
#define GRIOMMU_GRPCTRL_BASE_31_4_GET(_reg)
#define GRIOMMU_GRPCTRL_BASE_31_4_SET(_reg, _val)
#define GRIOMMU_GRPCTRL_BASE_31_4(_val)
#define GRIOMMU_GRPCTRL_P   0x2U
#define GRIOMMU_GRPCTRL_AG   0x1U
#define GRIOMMU_DIAGCTRL_DA   0x80000000U
#define GRIOMMU_DIAGCTRL_RW   0x40000000U
#define GRIOMMU_DIAGCTRL_DP   0x200000U
#define GRIOMMU_DIAGCTRL_TP   0x100000U
#define GRIOMMU_DIAGCTRL_SETADDR_SHIFT   0
#define GRIOMMU_DIAGCTRL_SETADDR_MASK   0x7ffffU
#define GRIOMMU_DIAGCTRL_SETADDR_GET(_reg)
#define GRIOMMU_DIAGCTRL_SETADDR_SET(_reg, _val)
#define GRIOMMU_DIAGCTRL_SETADDR(_val)
#define GRIOMMU_DIAGD_CDATAN_SHIFT   0
#define GRIOMMU_DIAGD_CDATAN_MASK   0xffffffffU
#define GRIOMMU_DIAGD_CDATAN_GET(_reg)
#define GRIOMMU_DIAGD_CDATAN_SET(_reg, _val)
#define GRIOMMU_DIAGD_CDATAN(_val)
#define GRIOMMU_DIAGT_TAG_SHIFT   1
#define GRIOMMU_DIAGT_TAG_MASK   0xfffffffeU
#define GRIOMMU_DIAGT_TAG_GET(_reg)
#define GRIOMMU_DIAGT_TAG_SET(_reg, _val)
#define GRIOMMU_DIAGT_TAG(_val)
#define GRIOMMU_DIAGT_V   0x1U
#define GRIOMMU_DERRI_DPERRINJ_SHIFT   0
#define GRIOMMU_DERRI_DPERRINJ_MASK   0xffffffffU
#define GRIOMMU_DERRI_DPERRINJ_GET(_reg)
#define GRIOMMU_DERRI_DPERRINJ_SET(_reg, _val)
#define GRIOMMU_DERRI_DPERRINJ(_val)
#define GRIOMMU_TERRI_TPERRINJ_SHIFT   0
#define GRIOMMU_TERRI_TPERRINJ_MASK   0xffffffffU
#define GRIOMMU_TERRI_TPERRINJ_GET(_reg)
#define GRIOMMU_TERRI_TPERRINJ_SET(_reg, _val)
#define GRIOMMU_TERRI_TPERRINJ(_val)
#define GRIOMMU_ASMPCTRL_FC   0x40000U
#define GRIOMMU_ASMPCTRL_SC   0x20000U
#define GRIOMMU_ASMPCTRL_MC   0x10000U
#define GRIOMMU_ASMPCTRL_GRPACCSZCTRL_SHIFT   0
#define GRIOMMU_ASMPCTRL_GRPACCSZCTRL_MASK   0xffffU
#define GRIOMMU_ASMPCTRL_GRPACCSZCTRL_GET(_reg)
#define GRIOMMU_ASMPCTRL_GRPACCSZCTRL_SET(_reg, _val)
#define GRIOMMU_ASMPCTRL_GRPACCSZCTRL(_val)
typedef struct griommu griommu
