RTEMS 6.1
This group contains the architecture-independent support modules shared across all BSPs. More...
Modules | |
| BSP-Specific Fatal Codes | |
| This group contains fatal codes for RTEMS_FATAL_SOURCE_BSP. | |
| Bootcard | |
| Standard system startup. | |
| Console Driver Support | |
| This group contains the console driver support modules. | |
| Default BSP Initial Extension | |
| This group contains the default BSP initial extension. | |
| GRLIB | |
| Driver support for GRLIB IP Library. | |
| Linker Symbols and Sections | |
| This group provides support for BSP-specific linker symbols and sections. | |
| MicroMonitor | |
| shared_umon MicroMonitor (uMon) Bootloader Support | |
| RTC | |
| Set the RTC. | |
| Task Stack Allocator | |
| Task stack initialization, allocation and free functions. | |
| U_BOOT Support | |
| U_BOOT Support Package. | |
Files | |
| file | irq-default.h |
| file | utility.h |
| This header file provides utility macros for BSPs. | |
| file | xil-compat-common.h |
| This header file provides a minimal shim for Xilinx drivers. | |
| file | arm-generic-timer.h |
| Header defining architecture-specific clock functions. | |
| file | xilinx_zynqmp.h |
| Xilinx Zynq Ultrascale+ MPSoC Peripheral memory map. | |
| file | bspfatal-default.c |
| This source file contains the implementation of bsp_fatal_extension(). | |
| file | bspsmp-arm-psci.c |
| PSCI-based BSP CPU start. | |
| #define | BSP_INTERRUPT_VECTOR_COUNT 0 |
| This constant defines the default interrupt vector count. | |
| #define BSP_INTERRUPT_VECTOR_COUNT 0 |
By default, no interrupt vectors are supported and all related directives return RTEMS_INVALID_ID.
