RTEMS 6.1
Modules | Macros | Functions | Variables
Xilinx Virtex-5 Board Support Package. More...
 Virtex 5 - MMU Support
 MMU support.
#define BSP_INTERRUPT_STACK_SIZE   (16 * 1024)
#define BSP_Convert_decrementer(_value)    ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
int BSP_disconnect_clock_handler (void)
int BSP_connect_clock_handler (void)
 Clock Tick Device Driver.
void zero_bss (void)
unsigned int BSP_bus_frequency
unsigned int BSP_processor_frequency
unsigned int BSP_time_base_divisor
◆ BSP_connect_clock_handler()
int BSP_connect_clock_handler ( void  )
This routine utilizes the Decrementer Register common to the PPC family.
The tick frequency is directly programmed to the configured number of microseconds per tick.
