RTEMS 6.1
Example Board Support Package. More...
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. | |
| rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
| rtems_vector_number | vector, | ||
| int | type | ||
This method installs an interrupt handle.
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
