RTEMS 6.1
Files | Macros | Functions
Hurricane Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_SHARED_HANDLER_SUPPORT   1
#define CPU_CLOCK_RATE_MHZ   (200)
#define CLOCKS_PER_MICROSECOND   ( CPU_CLOCK_RATE_MHZ ) /* equivalent to CPU clock speed in MHz */
#define rtems_bsp_delay(microseconds)
#define RAM_START   0
#define RAM_END   0x100000
void WriteDisplay (char *string)
uint32_t mips_get_timer (void)
void init_tlb (void)
void resettlb (int i)
◆ rtems_bsp_delay
#define rtems_bsp_delay (   microseconds)
Value:
uint32_t _end_clock = \
mips_get_timer() + microseconds * CLOCKS_PER_MICROSECOND; \
_end_clock %= 0x100000000; /* make sure result is 32 bits */ \
/* handle timer overflow, if necessary */ \
while ( _end_clock < mips_get_timer() ); \
while ( _end_clock > mips_get_timer() ); \
